Well built, reliable, great performing machine
Review by JLYoung posted 637 days ago 1413 views 1 time favorited 10 comments Add to Favorites Watch
Well built, reliable, great performing machine No-picture-s No-picture-s Click the pictures to enlarge them
I bought this planer about a year and a half ago and it has served me very well. The cutter head lock has pretty much eliminated snipe. The only time I get it is if I try and feed a wide board though without first jointing one face. (I know this is not the proper way, but if a board is short and wide, won’t fit on my jointer and I’m taking off 1/4” I figure I can flatten it quite well by continuously flipping it around). The blades on this planer apparently aren’t meant to be sharpened but thrown away and replaced. I’ve yet to change the blades out of mine so I can’t comment on how difficult it is to do. This planer should be used with a dust collector. I used it for awhile in my basement shop without a dust collector and you end up with so many chips inside the machine that you get dimples in the wood from the blades driving the chips in. Add a dust collector and that problem dissappears.
The three knife cutter head cuts very smooth and I have very little work to do to scrape off the milling marks. I could almost put the finish on right off the planer.
View JLYoung's profile
JLYoung
26 posts in 679 days
10 comments so far
14167 posts in 1058 days
posted 637 days ago
I love ours as well.. not that I have any experience with any other machine so I can’t compare.
But I figure if I can use it, it must be good :)
View pashley's profile
pashley
530 posts in 615 days
posted 594 days ago
I was able to easily take my blades out and sharpen them. Reinstalling is a snap.
-- http://newmissionworkshop.com
View Loren's profile
347 posts in 546 days
posted 544 days ago
I have one of the older ones with the resharpenable blades,
which a prefer because I have a knife grinder. Mine has
a 2-knife cutterhead and knife-setting jigs that come with
it.
After several years of intermittent use (I had other planers
as well so I didn’t use this always) the feed mechanism broke.
I took the machine apart – which took a while – and discovered
a delicate sprocket had broken in half. The sprocket has
a lot of pressure put on it by this machine and it’s not
super-sturdy. The replacement part was under $10 and frankly
I’m surprised the first one lasted as long as it did.
Planer is back in service and produces nice results as long
as you respect it’s limitations. It’s a nice surface finisher
in general.
Dust collection isn’t all that great. Chips get stuck in the sides,
pile up and need to be cleaned out if you want to plane thin
stock. It’s tempting to cut holes in the plastic sides to
make cleanout easier.
Perhaps the newer ones have better dust collection.
-- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html
View Denappy's profile
Denappy
62 posts in 580 days
posted 446 days ago
I recently purchased this same machine and agree, for the price it works great with little or no adjustment out of the box. I have been really pleased with the results!
-- -=Den
View SawdustWrangler's profile
SawdustWrangler
62 posts in 296 days
posted 293 days ago
I just picked up this planer on clearance for $300. I am very impressed with its performance thus far. Amen on the multitude of chips. Shopvac worked well in reducing the waste volume. Very strong and smooth machine.
-- Chris, South Carolina
Craftsman on the lake
818 posts in 335 days
posted 258 days ago
Ditto on this planer. I recently picked it up as a closeout item at Lowes for 4300. Running large fir and smaller oak pieces through it after jointing. No snipe and the finish is almost burnished smooth. Lots of chips though, dust collection or shop vac is a must. If not.. get a shovel you’ll need it.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://web.me.com/deceiver6/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
View Sinister's profile
Sinister
18 posts in 368 days
posted 88 days ago
I bought this planer about 5 years ago and it has been a reliable workhorse in my shop. That is until this weekend, when all of a sudden it would crank down but not up. On the Dewalt web page someone else posted this problem and it was suggested that the planer is out of parallel. Next weekend, I’ll try getting to the sprockets to see if I can fix it. I’d be interested to know if anyone else has had this problem and had success fixing it.
-- Patrick, Iowa City
17022 posts in 475 days
posted 88 days ago
congrats on the new tool may it last a thousand years and mill a million board ft. wow I make myself tired just thinking about it.
-- Jim from Heirloom Woodshop, custom furniture maker, woodworking school, heirloomwoodshop.com
25806 posts in 1298 days
posted 88 days ago
Great review. Thanks for writing it up.
Sinister
posted 73 days ago
In case anyone is interested, I figured out the problem. There is crack on the metal carriage that runs between the support posts on the “crank side” of the machine. When I crank down, the crack is pushed tight and it moves smoothly. When I crank up, the crack is pulled apart and it binds on the opposite side. Needless to say, I’m frustrated and shopping for a new machine.
