| Review by Sawdustmaker | posted 639 days ago | 381 views | 0 times favorited | 10 comments | ![]() |
I purchased this sander after reading numerous other post and reviews. Several post I’ve seen talked about the tracking adjustment screw and the spring being weak with the need for constant readjustment. I have not found that to be true with mine at all. The unit is kind of wide for my hand but I’ve found like others that the place where the cord enters the unit is a good location for holding it and works fine for controlling the unit. I don’t have a large shop but I’ve used it numerous times and it is not as heavy as most due to its size. I found that Wood Craft carried the finer grit belts. I use a belt sander cleaning stick often and have yet to replace a belt. I also purchased The Porter Cable hose and have little to no problems when I’m running it with my dust collector. The hose also fits the Porter Cable plate joiner. Changing the belts takes very little time with little needs for tracking adjustment. I would recommend this sander to any wood worker. Its size allows the user to get into much smaller spaces than any belt sander I’ve seen on the market.
-- Brian, Virginia Beach
10 comments so far
home | projects | blog
25873 posts in 1300 days
posted 639 days ago
I’ve heard good comments about this sander from others. So it’s nice to know that it’s so good. I might pick one up. My sander has crapped out. really it keeps breaking belts.
Bill
2561 posts in 1061 days
posted 639 days ago
I have had one of these sanders for more than a year, and it is great. The tracking is very good, and it is a nice size for getting into all kinds of areas. The one drawback I have seen is the case can get warm when using it for awhile. In the winter it is a good way to warm up your hands, but in the summer it can almost be too warm to hold.
Because of its size, I use it more than the larger DeWalt belt sander in the shop.
Good job Brian.
DaveH
372 posts in 678 days
posted 624 days ago
I have one of these. Gets a little warm when you use it. It’s a little heavy for one handed use. My hand gets tired of holding it if I run it very long. I always try this sander before I go to my 4” belt because it is lighter and easier to control. Haven’t had any problems with paper alignment. Would I buy another? Maybe, but first I’d take a good look at the competitors products.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
rikkor
11335 posts in 774 days
posted 624 days ago
Thanks for the review. I will be in the market for a BS soon.
Douglas Bordner
3427 posts in 963 days
posted 623 days ago
I want one!
Don Alexander
3 posts in 588 days
posted 558 days ago
I have had mine for a year now. It works great but the case gets way hot whille using it. The first time this happened, I thought it was broken.
-- Don Alexander, Jacksonville, Florida
throttle
9 posts in 487 days
posted 401 days ago
I Love this belt sander and would also highly recomend it for anybody who sands more than measures…...
-- "Throttle"
Steelmum
347 posts in 862 days
posted 342 days ago
I just bought this sander, and it is perfect. Small enough to handle smaller jobs. Changing the paper was very easy. It does get very warm.
-- Berta in NC
Todd A. Clippinger
5655 posts in 999 days
posted 342 days ago
I love this sander and use it all the time.
I find this very easy to handle with one hand, but that is in comparison to using my Bosch 3×21 belt sander with one hand (which I was doing before this purchase.) Actually it does fit my hand very well.
I would also keep a larger belt sander in the shop. As you can guess, my other sander is the Bosch.
All of the belts that came with the sander broke almost immediately. Fortunately I also bought a variety of sanding belts and they were just fine.
I hook mine up to dust collection and I think that drawing air through the tool during it’s use helps it run cooler. I have not had the heat issue.
I clean my sanding belts with compressed air and it works well at removing dust and crud build-up.
saw4fun
61 posts in 239 days
posted 224 days ago
I have been wanting a good belt sander for quite sometime, and read this review this morning. Needless to say I went and bought one. What can I say?? .... Im Thrilled!! Don’t know how I managed without one for so long..
-- There is no such thing as scrap wood! Rastus NE www.nativelumber.net
