| Review by rikkor | posted 638 days ago | 469 views | 0 times favorited | 7 comments | ![]() |
- Lee Valley The Little Victor Plane
- Brand: Lee Valley | Category: Hand Planes
I bought this little plane mostly on a whim. I am simply amazed by how useful it has turned out to be. It is easy to use either one or two handed. It has Lee Valley quality throughout. The iron was very sharp when I got it. It has a cast iron body that just feels right. I believe the current price is about $35.00.
7 comments so far
home | projects | blog
25811 posts in 1299 days
posted 638 days ago
Looks like a great plane Rikkor. Thanks for the psot.
14181 posts in 1060 days
posted 638 days ago
it’s cute.. what more do you need?? :D
and what do you use it on?
sharad
721 posts in 703 days
posted 638 days ago
I can understand how thrilled u must have been after using the small plane. Recently I have also used a similar plane manufactured by Anant, a local company. It was great pleasure to use it while repairing my Back saw handle. I repented why I did not get it earlier. Here the cost is about $3 ! yes Three dollars. If u want I can send u one.
Sharad
-- patanjali
Eric
784 posts in 683 days
posted 638 days ago
Nice! Looks like what my mini plane would rather be…
-- Eric at http://adventuresinwoodworking.com
RickH
18 posts in 647 days
posted 638 days ago
This is a neat little plane. I too own one, and find that with a sharpened and honed blade it cuts very well.
However – I have found that it is very hard to adjust the blade precisely. When I try to tighten the adjusting screw it often slides the blade around a little since the end of it makes direct contact on the blade, and there is no chip breaker – or washer – to act as a go-between. I tried polishing the end of the adjuster screw, and added a bit of grease there, which helped, but it is still frustrating to try and lock down the blade to be in even alignment across the base with minimal projection.
Veritas also makes the same plane as a squirrel tail palm plane, and I think that would give you more control in use. Lee-Nielsen also makes a very similar small plane – the Model Maker’s Block Plane – in a squirel tail version with a 7/8” blade, but it has a better blade lock mechanisim – more traditional chip breaker thumb-screw tightening system. If I had to buy another I would likely get that one instead – even though it costs $65 – because of the ease in blade adjustment and because it comes with a full 1/8” thick blade.
-- Rick - OC, CA
rikkor
11335 posts in 773 days
posted 624 days ago
Because of computer problems I was given dispensation by Martin to use manufacturer’s photos for the Leap day review contest. Now that the computer issues are resolved I will post actual photos of my items.
20780 posts in 721 days
posted 609 days ago
Rikkor,
Thanks for the review. I will have to look into one of these. I have been adding to my plane collection recently and this one is in my price range and, from your review, looks like a useful tool.
Thanks for the post.
