Carter Bandsaw guides
Review by rikkor posted 638 days ago 961 views 1 time favorited 10 comments Add to Favorites Watch
Carter Bandsaw guides Carter Bandsaw guides No-picture-s Click the pictures to enlarge them
My main reason for getting a large bandsaw was for resawing boards up to eight inches wide. The performance I was getting from the Grizzly was less than satisfactory. Then, I was at a woodworking show, and the guy from Carter was sawing slices less than 1/8” thick, and very smooth from a chunk of walnut. He said it was due to guide bearings that were specifically designed for resawing. I had to have this! I almost choked when I saw the price, but I bought it anyway. It took about 45 minutes to install. Then I watched the video that was included on tuning the bandsaw, and did the tune-up. Now my saw cuts considerably better and more consistently than before. I recently sent for a Woodslicer blade based on comments from other LumberJocks, but haven’t installed it yet. (Unheated garage) I expect another improvement from the blade.
If Resawing is your game I would recommend the Carter bearings wholeheartedly.
View rikkor's profile
rikkor
11335 posts in 773 days
10 comments so far
20784 posts in 721 days
posted 638 days ago
I agree Rikkor. I have only done limited resawing on my bandsaw (installed in December) but it came outfitted with the Carter bearings and I couldn’t be more pleased with its performance. They are not cheap but are well worth the price.
View Mike Lingenfelter's profile
Mike Lingenfelter
458 posts in 1013 days
posted 638 days ago
I’ve been looking at this guide for my Grizzly band saw too. It’s starting to move closer to the top of my tool list. Thanks for the review.
-- http://theinquisitivewoodworker.com/
View reible's profile
reible
21 posts in 660 days
posted 635 days ago
A big thumbs up for these guides! I had a friend who kept telling me how great they were… I looked at the price and said that is almost more then what I paid for my saw back in the early 70’s you’ve got to be crazy…
A few years later I was debating replacing the saw and figured the guides might save me a few $$ if they really worked. They did and it turned out I was the crazy one for not doing it sooner!
One thing that I noticed the moment I turned the saw on was how much noise the old guides were generating. The second thing was how much better cut I could get after the change over. This past winter I added the “other” Carter option that helps with free style cutting, they call it the Stabilizer™. Waiting for winter to end so I can give it a try… (also an unheated garage shop).
Ed
-- Knight of the Shopsmith
View tenontim's profile
tenontim
1319 posts in 643 days
posted 635 days ago
I’ve never tried these guides, I have the BAND ROLLER brand, which work fine. They are only the two side guides. The thing that impresses me about the Carter guides is the rear roller, which takes the load of the saw blade on it’s edge, instead of it’s side, like most original equipment guides. Bearings are not meant to carry a load on the side of the bearing, but on the edge. I think the reason I didn’t go with these was because the cut down on the thickness of wood that would fit under the guide. I thinking of upgrading to a riser block, so that won’t be a problem, and I think I will also upgrade to this type of guide system.
-- Tim -- http://tmuli.com
View PanamaJack's profile
PanamaJack
4447 posts in 976 days
posted 635 days ago
Lookin’ into these now. Sounds like a great catch.
-- Carpe Lignum - Seize The Wood,
View Chris 's profile
Chris
1470 posts in 890 days
posted 631 days ago
I have been considering these for my Jet14” (especially since the lower thrust bearing seized yesterday). I think I will purchasing a set real soon. Thanks for the review….
-- Chris
rikkor
posted 623 days ago
Because of computer problems I was given dispensation by Martin to use manufacturer’s photos for the Leap day review contest. Now that the computer issues are resolved I will post actual photos of my items.
Carter bearings
Carter bearings
View odie's profile
odie
1604 posts in 739 days
posted 183 days ago
WOW, I finally used mine on my Ricon 14” deluxe bandsaw. With a 3/4” blade these guides make so easy to resaw at least an 8” piece so far. It was so straight and true.
View MedicKen's profile
MedicKen
485 posts in 361 days
posted 154 days ago
Now that you have had the guides for better than a year, how are they holding up? I am restoring a Rockwell 14” bandsaw and have ordered a conversion kit from Carter. The kit includes both upper and lower guides and a new hex shank guide bar.
25811 posts in 1299 days
posted 154 days ago
I have the same type guides (Also Carter) on my 19” bandsaw. I’ve had them for 4 years and I’m very happy with them.
