Sharpen your throwaway planer knives
Review by Deulen posted 10-09-2010 04:28 PM 15451 views 9 times favorited 28 comments Add to Favorites Watch
Sharpen your throwaway planer knives Sharpen your throwaway planer knives Sharpen your throwaway planer knives Click the pictures to enlarge them
If you are going to throwaway your planer knives then please send them to me and keep it “Green”. The new “Deulen” Jointer/Planer Knife Sharpener will remove nicks, sharpen, and hone a razor sharp edge in minutes. They come in 6” and 12” lengths or can be fastened end to end for up to 26” knives. You can see a demo video and purchase yours at: http://exoticwoodveneerplus.com/.
Handsomely made of Exotic Hardwood, Machined Brass, and Stainless Steel. Just place the knives in the brass slots, tighten the set screws, then lap back and forth on PSA sandpaper over glass for a razor sharp edge. Remove nicks, sharpen, and hone to a razor sharp edge. Way sharper then sending them out. We always sharpen and hone block planes, and chisels. With your machine spinning at 7000 RPMs honking off the hardest woods on the planet, ask yourself this: Why don’t you sharpen and hone your Jointer/or Planer knives before using them? Cat got your tongue? Why buy an expensive machine and then tear it up buy putting a butter knife in it? I took my new invention to the international woodworking show in Atlanta, Georgia last August and sold out. They come in 6” (49.95) and 12” (89.95) lengths. The six-inch model sharpens 3” to 8” knives. The twelve-inch model sharpens 8” to 15” knives. They can be fastened end to end for longer lengths. Dan Deulen 360-573-0305 or 360-601-1744. Tell your friends!
-- Daniel M Deulen
View Deulen's profile
Deulen
52 posts in 3024 days
28 comments so far
View Chinitorama's profile
Chinitorama
105 posts in 3418 days
#1 posted 10-09-2010 07:50 PM
Nice review Dan! Another example of something so simple, yet nobody seems to have thought of it before.
-J.
View Broglea's profile
Broglea
685 posts in 3210 days
#2 posted 10-10-2010 01:55 AM
Dan nice product. I made a jig like this earlier in the year to sharpen my jointer knives. The only draw back is that it takes for ever to sharpen them.
View 8iowa's profile
8iowa
1581 posts in 3880 days
#3 posted 10-10-2010 04:02 AM
Question:
Are all “throw-away” blades capable of being sharpened. I know that some blades are only hard enough on the surface and once this is ground away the softer steel won’t hold an edge.
It takes a certain amount of carbon in the steel to produce the fine grains that can be sharpened to a keen edge.
View jim C's profile
jim C
1472 posts in 3217 days
#4 posted 10-10-2010 05:55 AM
From my background in Tool & Die, I’m guessing, unless you found a planer at K-Mart, made in China, the blades in all respectable planers are Hight Speed Steel (HSS). They are probably A-2 or S-7, (air hardened) 60-62 RC or even an M-series steel upwards of 66 RC. They are all hardened thru and thru.
Throwaway blades would be “case” or “surfaced” hardened, and generally would not be ground after heat treatment. I can’t believe anyone would produce these other than for lawn mower blades.
Therefore “throwaway” blades on this post refer to the inability to sharpen them yourself, and instead take the easy (expensive route) and purchase new ones.
View Dusty56's profile
Dusty56
11822 posts in 3807 days
#5 posted 10-10-2010 07:44 AM
what do you do when you have a three knife system to keep everything balanced and the same dimensions ?
Well , now that I’ve watched your video , I see that you answered my question. However , you are still sharpening blade #1 twice on the same grit in your video when you insert blade #3 before moving on to the next grit and then when you double up the blades in the 12” holder , you are taking off more metal on the single blade as it is travelling twice as much as the ones on the other side of the holder. It looks like a well made tool , but I can get my knives sharpened 5 times for the price of your 6” holder , and seeing as I already have a spare set of knives , I am never without sharp ones.
This isn’t a product review , but merely a sales pitch and belongs in one of the forums sections.
Deulen
#6 posted 10-10-2010 08:27 PM
Hey guys, I want to thank all you for your post. I admit not knowing whether this wasn’t the appropriate place I apologize. I’m a fifth generation wood worker who can build a nice guitar, properly harvest a Black Walnut tree, or build a spiral staircase but, I type with two fingers and don’t spend much time on the computer. So with that said, I’ll try to answer all of the comments or questions about this tool in the order of the posts. 1- Broglea you mentioned that it takes forever to sharpen your own knives. I can sharpen a set of knives in less time than it takes you to drive them to the sharpening center and back. You still have to wait for the phone call that they are done and drive back and return them to your shop for installation. My system doesn’t require an automobile, insurance, gas, or travel time. I’m not an anti-send out guy. The reason for my invention was to help woodworkers produce a better quality cut than sending them out. I’m not sure why you don’t hone your blades before using them. My tool is merely an option for those who want a better smoother cut with less tear-out.
2- 8Iowa you asked if all throwaway knives could be re-sharpened. I don’t know yet. I’m asking you to send me your knives so I can test them. I have sharpened a set of 18” Woodmaster Planer knives successfully after the owner threw away six sets at $160.00 per set. After sharpening them he installed them and called me to tell me he will probably get two more sharpenings on that same set. They were very badly nicked and had a serious bend in one of them so I put a shim behind the bent section to straighten before I could sharpen them. He said even the holder was bent. I have 3 sets of Ridgid 13” throwaways that have hit several nails so, like the Woodmaster set it’s a good challenge. I hope to get some results from the owner as I sharpened one set while he waited as well as a six-inch three knife jointer set. After sharpening the six-inch set he was quite convinced not to put jointer knives in his jointer before honing them. He could see the difference from the original factory edge and just smiled. Jim ceriale answered the quality of steel question for me. Thanks Jim!
3- Dusty56- My video shows the alternation of the blades to keep them balanced. Blade #1 does get sharpened twice but then so does #2 and #3 consecutively. It’s not perfect but has worked for me for thirty years. Again you state that if two knives are on one side and the third is on the opposite side that the lone knife is traveling twice as far. If you glue three six-inch sticks together, two on one side and one centered on the other side you can perhaps see by marking the starting and ending point on each of the three sticks and measure their travel. That might help you see that they all travel the same distance. And as far as having two sets of knives, you eliminate your three-knife dilemma because you can wait till both sets are dull before sharpening them and do two at a time. Dusty, I’m not so lucky as you when it comes to nicks. I can get several in a day when milling a few hundred board feet of lumber. Perhaps you can share your no-nick secret with us. I’m an old-fashioned beat up high-miler that likes doing things myself. Rather than driving somewhere and back twice and waiting days to get my knives so I can continue my project, I just sharpen them. I have sold over three hundred tools so far with 100% positive feedback (Ebay, Craisgslist). If you’d like I can post some of the many. Sincerely, Dan Deulen
-- Daniel M Deulen
View Jamie Speirs's profile
Jamie Speirs
4168 posts in 2975 days
#7 posted 10-10-2010 08:37 PM
Dan I think it is great.
I always use a slip to keep my blades sharp. This
looks a lot easier.
Jamie
-- Who is the happiest of men? He who values the merits of others, and in their pleasure takes joy, even as though 'twere his own. --Johann Wolfgang von Goethe
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3704 days
#8 posted 10-10-2010 08:59 PM
Sorry not my blades !
I have a dedicated sharpener,and am not in the habit of giving good stuff away. The jig is just another gimick imho, and could be knocked up in a few hours by anyone here.So why pay over the odds for a bit of wood and a few screws? I don’t expect many will buy this , but some might copy it. Alistair
8iowa
#9 posted 10-10-2010 10:38 PM
Daniel:
Thank you for your offer to sharpen my planer knives. I have a jig that I use with the conical disk that works well, taking off just a few thousandths, just enough to create a new sharp edge.
The reason for my asking the question above is that my blades, which cost $109 a set (3), have a hardened M2 edge laminated to lower carbon steel. As such I can sharpen them to a maxium of taking off 1/16” in width, which will take a long time. I’m not convinced that the “disposable” blades for all of the common benchtop planers, selling for half as much, can withstand very much sharpening without getting into softer steel.
Deulen
#10 posted 10-10-2010 11:06 PM
8iowa, I posted so that I might get a few other brands to see how it works on them. I can’t afford to buy every planer with throwaway knives to test them. I make everyone of my tools in my home shop. I’m not some big company. I’m head of operations, my wife is C.E.O. and, our world headquarters is located in Washington State (in the shop out back). When I first created my jig I was unaware there were throwaway knives. I’m a hands on, you have to show me guy (My grandmother is from Iowa). I can’t know for sure until I try it myself. So if you have a friend with throwaways, I’ll be glad to test them. I’ve done Woodmaster and Rigid. I will post both positive and negative results that I find. I’ll try to contact the many happy customers who have thanked me so there will be some posts of actual users instead of supposition and innuendo. Thanks, Dan
-- Daniel M Deulen
Deulen
#11 posted 10-10-2010 11:52 PM
Hi again, This tool is my work and I’m very proud of not only what it does but, the workmanship as well. This is the first time I’ve had negative feedback about my work. I did have one guy in Atlanta say he doesn’t need his knives that sharp. I prefer to say nothing at all rather than attack some one’s work or character. I was also taught that it’s much better to say nothing and seem a fool, rather than open your mouth and let out all doubt. If you can make a finer tool then do it. I’d love to see how much better you can do. I didn’t realize Lumberjocks was supposed to be a roast. If you negative people are looking to run woodworkers off this sight, mission accomplished. This is my last post. Here’s another site of mine (eBay) that you can leave negative feedback. Oh! you can’t leave feedback until you actually use the products I sell.
Awesome tool, what a time and money saver!!!! Buyer: Member id honehe14 ( Feedback Score Of 20 ) Oct-02-10 15:37 New! DEULEN 6” Jointer/Planer Knife Sharpener (#250667722171) US $49.95 View Item New! DEULEN 6” Jointer/Planer Knife Sharpener
Beautiful design,think I’ll just look at it for a week,greatebayer AAA+++ Buyer: Member id graham2597 ( Feedback Score Of 266 ) Sep-23-10 17:59 New! DEULEN 12” Jointer/Planer Knife Sharpener Hardwood (#250649599355) US $89.95 View Item New! DEULEN 12” Jointer/Planer Knife Sharpener Hardwood
THANK YOU! MY HUSBAND IS VERY PLEASED WITH THE PURCHASE! Buyer: Member id csrcutie ( Feedback Score Of 430 ) Sep-19-10 20:15
Member id inventorswife ( 11103 )
Positive Feedback (last 12 months): 99.8% [How is Feedback Percentage calculated?]
This member is a Top-rated seller Consistently receives highest buyers’ ratings Ships items quickly Has earned a track record of excellent service
Goodbye Lumberjocks, sorry I stopped by. Sincerely, Dan Deulen
-- Daniel M Deulen
View MarkwithaK's profile
MarkwithaK
370 posts in 3297 days
#12 posted 10-12-2010 05:17 AM
I just think that it is rather biased to “review” your own product.
-- If at first you don't succeed then maybe skydiving isn't for you.
8iowa
#13 posted 10-12-2010 03:00 PM
I tried to be polite to the guy by asking a legitimate technical question.
He should have expected some “negitivity” (his words) when he used LJ’s review section to promote/sell his own product. None-the-less, he has apparently left LJ in a huff.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3993 days
#14 posted 10-12-2010 03:43 PM
It’s true that this post was a bit of self-promotion, and felt a little spammy being in the reviews section.
However, there are a ton of commercially made jigs and tools on the market that most people here could make (think tenon jigs and coping sleds) ... yet Rockler and Woodcraft sell a bunch of them. Some woodworkers would rather buy something like that than to make it themselves.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
Deulen
#15 posted 10-12-2010 07:22 PM
Hi Lumberjockers! I want to apologize to many who use this site to learn and share their woodworking projects. Last Saturday I pulled my back muscles while working on my Band saw and had to get pain medication (Percocett) for my back pain. I couldn’t work in my shop so I went online to Craigslist to request local woodworkers who have throwaway planer knives to bring them over to my place to see if after my jig sharpens them, would they still plane lumber in there machines. My add didn’t mention where or how to buy them and I got a few calls from those who wanted to purchase them. So come Sunday when I posted on Lumberjocks I put buying info on it as well. All I was trying to get are some dull planer knives of different brands for testing. It’s unbelievable to me how difficult it is to obtain worthless knives. I had previously read in an L J forum of several people asking about what to do with their throwaway knives. I thought it would be a great source for me to get knives from different machines so I can test them. I have ran two adds on Craigslist. From the first add I had one person bring knives from an 18” Woodmaster. He has planed several hundred feet of 2×6 and it’s still cutting just fine. From my second C L add I had three guys asked where to buy them and one person (Chris) who brought knives over to get them sharpened. Chris brought over 1 set of three six-inch jointer knives and, 3 sets of Ridgid 13 ½ “ planer knives. He only had his planer and Jointer for one month and had already toasted all of the knives. He was reclaiming Oak that had hidden nails in them. He got the Oak for a great price but the planer knives are $30.00 per set. To make a long story short, tonight I’m taking the knives over to his place to see how they work in his Ridgid Planer. I’ll bring a magnet too! Dan Deulen
-- Daniel M Deulen
showing 1 through 15 of 28 comments
