Believe The Hype!
Review by Ryan Brown posted 983 days ago 5719 views 6 times favorited 17 comments Add to Favorites Watch
Believe The Hype! No-picture-s No-picture-s Click the pictures to enlarge them
The Wood Slicer bandsaw blades from Highland Woodworking are awesome.
When I first purchased my “Rikon 14 deluxe bandsaw my local Woodcraft store said that the 1/2” blade that came with it was pretty good. I took their advice on that, and also purchased a 3/4” 3TPI Timber Wolf blade for resawing. Both seemed to work, but my results were so-so.
For the first real challenge I resawed some green cherry logs for turning blanks. I started with the blade that came with the saw. Meh. It really felt like I had to give the wood a lot of pressure to get the blade to cut, which meant I was putting a lot of pressure on the guides and blade. The cuts were slow and uneven. A lot of dust was captures on the inside of the blade, resulting in a lot of scraping the hardened dust off of the blade and wheels. I took that blade off and decided it was only worthy for cutting up re-purposing.
The Timber Wolf blade definitely cut better, but I still felt like I had to push the wood too hard to get it to cut. I’d even tried changing blade speeds to see if that would help. It didn’t. I noticed that this blade also caught a lot of the shavings/dust and it was a pain to clean the wheels and blade up afterward. Even cutting cross-grain or with the grain I’m not impressed with it.
Which brings me to the Wood Slicer bandsaw blade from Highland Woodworking. I bought a 1/2” blade on the advice of one of the store reps and mounted it on my bandsaw. It easily sliced through dry 6” thick red oak. Walnut, no problem. I use Renaissance Wax on my cast iron to make the wood glide across the top, and with this blade, there was barely any resistance at all from the blade. Even with faster feed rates in hard woods it cuts like a hot knife through butter! I was also very surprised at how much quieter the blade is compared to the stock blade and the Timber Wolf.
The finish of the cuts were also very, very smooth. Although not recommended for cutting green wood, I decided to cut up some greeen cherry logs into bowl blanks just to see how it compared. The blade cut through 8” thick cherry like it was only 1/2” thick. It was still very quiet compared to the other blades, and there was no buildup of the green wood on the inside of the blade and on the tires.
Even though the Wood Slicer is marketed as a resaw blade, it also cuts cross grain very well. As far as I’m concerned, this is the only blade I’ll ever use. It’s quiet, inexpensive, sharp and it cuts so well it’s almost like the wood feeds itself through the blade. Here are the specs and details about the blade from Highland Woodworking.
“It is so choice. If you have the means, I highly recommend picking one up.” – Ferris Bueller
-- If you can't fix it with a hammer, you have an electrical problem. Roanoke, VA
View Ryan Brown's profile
Ryan Brown
72 posts in 1358 days
17 comments so far
View CampD's profile
CampD
1017 posts in 1654 days
#1 posted 983 days ago
Nice review, I have to order one .
-- Doug...
View swirt's profile
swirt
1864 posts in 1140 days
#2 posted 983 days ago
Nice review. I have the same wood slicer blade and similar results. Nice to have you compare it side by side with the TImberwolf as I have often wondered which was better. Now I know.
View ken_c's profile
ken_c
188 posts in 1330 days
#3 posted 983 days ago
Thanks – I will make it my next one based on this review….
View TheDane's profile
TheDane
2675 posts in 1831 days
#4 posted 983 days ago
I have had exactly the same experience with the Highland Wood Slicers. They are top drawer.
View Eric_S's profile
Eric_S
1522 posts in 1363 days
#5 posted 983 days ago
I had one as well and absolutely loved it for everything. Cuts like butter I was able to resaw 8” cherry boards with ease and do crosscuts. The saw blade has since dulled and needed to be replaced. Due to time constraints(couldn’t wait to order it), I went to Woodcraft and picked up a low tension timberwolf blade for resawing some veneers. It definitely didn’t seem to cut as well as the woodslicer but was still very good. I plan on purchasing another woodslicer shortly. These blades are awesome!
-- - Eric Indianapolis, IN
3808 posts in 2189 days
#6 posted 983 days ago
i love em!
View PurpLev's profile
PurpLev
7741 posts in 1816 days
#7 posted 983 days ago
yup. it IS that good.
I only swap it when I need to do small radius cuts. otherwise it’s my all-purpose blade.
View brunob's profile
brunob
2275 posts in 2337 days
#8 posted 983 days ago
Ditto to all.
-- Bruce from Central New York...now, if you'll pardon me, I have some sawdust to make.
View cwdance1's profile
cwdance1
1139 posts in 1427 days
#9 posted 983 days ago
Thanks for that review as I was going to order the timber blades.
View Luke's profile
Luke
450 posts in 1462 days
#10 posted 983 days ago
Ditto. Own the same, very nice.
-- LAS, http://www.abettersign.com
View Gerry's profile
Gerry
228 posts in 1408 days
#11 posted 982 days ago
I have the same saw and blade, and have great results as well!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
View John Gray's profile
John Gray
2366 posts in 2053 days
#12 posted 981 days ago
I have the Wood Slicer bandsaw blade, 1/2” 3-4 tpi, and I’ll probably never use another makers blade. It does a wonderful job resawing. Thanks for the post/review!!!!!
View TheGravedigger's profile
TheGravedigger
963 posts in 2192 days
#13 posted 980 days ago
Looks like most of us are in agreement. I’ll take the Wood Slicer over the Timberwolf as well.
-- Robert - Visit my woodworking blog: http://littlegoodpieces.wordpress.com
View Doer's profile
Doer
22 posts in 991 days
#14 posted 979 days ago
I have a 1/2” Wood Slicer on my Powermatic 81 20” saw and it cuts Hard Rock Maple better than most blades cut white pine.
View Tdazzo's profile
Tdazzo
44 posts in 1017 days
#15 posted 978 days ago
Thanks for the review. I’ve been looking for a good resaw blade but I don’t have a lot of bandsaw experience (let alone re-sawing) so I wasn’t sure if I should have been happy with the blade I chose. Sounds pretty clear to me now.
-- "If you can't do something smart, do something right." -- Sheppard Book
