| Review by John Franklin | posted 986 days ago | 1871 views | 0 times favorited | 6 comments | ![]() |
- Sprayway Woodworker's Dry Coating Lubricant
- Brand: Sprayway | Category: Other
I bought this a year or more ago and it sat on the shelf.
This past weekend I had to drill several 2” + holes with forstner bits which usually means lots of shallow cuts and smoke and heat. I just happened to notice this can on the shelf, which I had pretty much forgotten about.
This lube led to no smoke and I could take deeper “cuts” – e.g. 3/4” ply in maybe 4 plunges instead of 6-8 without.
I also had a lot of pocket holes to drill this weekend and I sprayed this every so often on the bit – whenever I did the holes definitely drilled faster.
It did leave a white film on the wood which sanded off easily. My pieces will be painted so I didn’t care much, but if I was staining, I would test a scrap piece to see if the lube interferes at all with the finish.
-- John Franklin - Central PA - http://affyx.wordpress.com
6 comments so far
helluvawreck
home | projects | blog
10390 posts in 1034 days
#1 posted 986 days ago
That sounds like it might be worth trying. I had to drill 4 1-18 holes this weekend to make a cut out handle. My bit didn’t smoke but it got warm. That would probably save some wear and tear on your bits, IMHO.
lew
8979 posts in 1923 days
#2 posted 986 days ago
JC, thanks for the review. I’ll have to try this stuff!
Lew
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
araldite
187 posts in 1572 days
#3 posted 986 days ago
They say it contains no silicone or oil.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
richgreer
4474 posts in 1242 days
#4 posted 986 days ago
I may give this a try.
However, let me suggest to all that nothing beats a really sharp Forstner bit and it is not that hard to sharpen your own bits. I would suggest that you use this product in addition to sharpening and not in lieu of sharpening.
ken_c
188 posts in 1330 days
#5 posted 985 days ago
sounds like you have been running to high of RPM’s for the bit size…
Pimzedd
334 posts in 1972 days
#6 posted 985 days ago
Where did you get it?
-- Bill - Mesquite, TX --- "Everything with a power cord eventually winds up in the trash.” John Sarge , timber framer and blacksmith instructor at Tillers International school
