Mini Grinder
Review by rimfire7891 posted 08-28-2010 05:36 AM 7034 views 0 times favorited 4 comments Add to Favorites Watch
Mini Grinder No-picture-s No-picture-s Click the pictures to enlarge them
Although mostly used in the auto industry they are very handy in the wood shop.
The 1/4’’ angle die grinder with a 3M Roloc head installed. the discs install with 1/2 turn on 1/2 turn off
Lots of sanding discs available the 36 and 50 grit are great for smoothing and blending edges on anything with curves. Fast, noisy, and dusty. FND Can’t have everything.
Different grits are available in 2” , 3”, 4” diameter the Scotch Brite pads, great for cleaning up rusty tools or polishing the face of a hammer. Work great on aluminium with a little WD40 as lube
I find the 2” size the most handy, available by each and large quantities are cheaper per. Once you use one you will wonder how you got along without it.
Any 1/4 angle die grinder will do. The better ones are quieter and use less air per output. Just remember to add a few drops of oil a the tool so you don’t contaminate you hose.
One tool in my shop that is pretty well permanently attached to the air hose. Have use it on the lathe, both metal and wood turning for buffing and polishing.
Great tool and attachments.
Thanks
-- Playing with wood and metal for the last 50 years, driving and building Land Cruisers for the last 40. Experience is what you get when you don't know what you are doing.
View rimfire7891's profile
rimfire7891
123 posts in 3106 days
4 comments so far
View antmjr's profile
antmjr
262 posts in 3387 days
#1 posted 08-28-2010 03:46 PM
I say “thanks”!
Strangely I have never thought of such tools; recently I have asked here some information about electric angle grinders
My air compressor has 2HP, 150 liter/minute with 10 bar at most. Is it enough for this mini grinder?
-- Antonio
rimfire7891
#2 posted 08-28-2010 04:36 PM
Hi Ant,
These little things really suck a lot of air for their size. I think your compressor will be fine except that you won’t be able to run continuously. You will have to wait and let the compressor catch up. I have a 13 CFM compressor and it can just keep up .They run best at about 90 PSI which is about 6.5 bar.
Very useful and I think over looked tool for woodworking.
Thanks jb
View Russ's profile
Russ
142 posts in 3402 days
#3 posted 08-28-2010 05:18 PM
Great little tool, saw it on woodturners show and knew it was perfect for wooden spoons but it does use a lot of air so i need to upgrade my compressor.
-- Happiness is being covered in sawdust
View Don Niermann  's profile
Don Niermann
219 posts in 4176 days
#4 posted 09-02-2010 08:54 PM
Is there a part number on it?
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
