The search has ended
Review by Routerisstillmyname posted 08-26-2010 03:10 AM 8244 views 5 times favorited 20 comments Add to Favorites Watch
The search has ended The search has ended The search has ended Click the pictures to enlarge them
WOW, what can I say. This is another pleasant surprise from Freud.
In my search for a super thin kerf saw blade under 20. The Demo demon @ $15.00 although not designed for table saw and ripping gets my 5 star.
Gives extremely clean cut with not too slow but steady feed rate and at 1/16 kerf, No waste and oh my, almost no dust. You can see the cut is practically glue ready.
Since this is 7 ¼ blade and super thin, I don’t recommend using it on any stock thicker than 3/4 It may deflect but you do get full 2 inches at maximum height. So, if you want to save on $$ and dust and waste ..you might want to give it a try.
-- Router è ancora il mio nome.
View Routerisstillmyname's profile
Routerisstillmyname
763 posts in 3708 days
20 comments so far
View JoelB's profile
JoelB
18 posts in 3572 days
#1 posted 08-26-2010 04:15 AM
I use similar super-thin-kerf blades from Frued and I am equally impressed. The blades slice through hard maple like it is not even there. Not much dust and best of all you only lose a 1/16th of an inch as opposed to the 1/8 I lose with my Ridge Carbide. I only wish there was a way to get a 10” diam version of a super thin blade like this. I have a lot of 3” thick maple I need to slice up.
Routerisstillmyname
#2 posted 08-26-2010 04:45 AM
I’ve tried several of these 7 1/4 but none come close to Freud. You might want to try flipping over the cut with the same side on the fence.
View jcees's profile
jcees
1070 posts in 3998 days
#3 posted 08-26-2010 06:43 AM
Grand idea!
-- When one tugs at a single thing in nature, he finds it attached to the rest of the world. -- John Muir
View Dchip's profile
Dchip
271 posts in 3451 days
#4 posted 08-26-2010 03:32 PM
Thanks for the review, I’m definitely gonna give this a try. Where did you buy the blade?
Edit:
Nevermind, I found it at HD. It seems you have done some research in the 7 1/4’’ thin-kerf blade market. How does this blade compare to the standard freud diablo
http://www.homedepot.com/Tools-Hardware-Power-Tool-Accessories-Saw-Blades/Diablo/h_d1/N-5yc1vZb8n9ZgeZ1xqd/R-100008676/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
Thanks again.
-- Dan Chiappetta, NYC, http://www.9x7woodworks.com
Routerisstillmyname
#5 posted 08-26-2010 05:29 PM
yes, I got it at HD. the difference between this and the other diablo 7 1/4” is this blade uses new lock-tooth technology which it wasn’t the main selling point for me but the they are set deeper and are slightly longer which means it does have more carbide and the most important thing for me was the pyramid tooth geometry. it’s < left-right-center>. super tracking no saw marks.
If they would make this in 10” with 30 teeth and leave the thickness as is it would be Awesome. it would be the ultimate rip blade.
Dchip
#6 posted 08-26-2010 05:30 PM
Thanks for the info, I will be checking these blades out this weekend.
View sawblade1's profile
sawblade1
754 posts in 3226 days
#7 posted 08-26-2010 05:35 PM
They do make it in a 10” blade it is called a glue line rip, I love Freud Blades and use them on all of my circular style ( ie. table, miter saw) and they perform great, Look ma no blade marks or tear-outs !!!!!!!!
-- Proverbs Ch:3 vs 5,6,7 Trust in the lord with all thine heart and lean not unto your own understanding but in all your ways aknowledge him and he shall direct your path elmerthomas81@neo.rr.com
View Chinitorama's profile
Chinitorama
105 posts in 3498 days
#8 posted 08-26-2010 06:10 PM
Thanks for the review! Was wondering about these blades after seeing one at HD last week. I agree with sawblade1 about the Glue Line Rip. Awesome blades, but they cost like 7x as much as this one. Plus the Glue Line makes a 1/8”+ kerf. $15? I’m getting one of these next for sure.
View AaronK's profile
AaronK
1507 posts in 3663 days
#9 posted 08-26-2010 06:37 PM
thanks for the review. I was wondering about this type of thing ever since I saw it on Matthias Wandel’s site.
any idea of how the blade deflects under pressure? How square are your cuts? also have you tried using it to crosscut?
Dchip
#10 posted 08-26-2010 06:41 PM
Even the 10’’ thin-kerf glue line rip is 3/32’’, whereas I believe this is only 1/16’’ aka 2/32’’. Doesn’t seem like a big difference, but could definitely help on underpowered saws. The difference b/w 1/8’’ and 3/32’’ is pretty big I’ve noticed. Plus, the lighter weight probably makes a big noise difference. My 2 cents.
Routerisstillmyname
#11 posted 08-26-2010 06:49 PM
I’m sure it will deflect under pressure even a thick kerf 10” blades do. not about to screw this one up yet ;-) cuts are 100% square as long as the board has a 100% flat surface and the blade is 100% at 90 degree and the fence is 100% at 90 degree ;-) I got this for ripping and not crosscutting, I use Diablo 80T for crosscuts.
Yes I know about the glue line thin kerf blade LM75R. but it’s not the same thing. for one thing it costs. $60.00. and the second thing is, the plate is 0.71 and the kerf is 0.091 which is even better than their other thin kerf but this blade has plate 0.040 ad kerf 0.065.
it doesn’t get any better than this for $15.00
View AnthonyC's profile
AnthonyC
50 posts in 3105 days
#12 posted 08-26-2010 07:36 PM
I just used their plywood finish blade in my circ saw to break down some MDF for my router cabinet. It was exactly like cutting through butter. I could not even tell when it engaged the wood.
I still use wider blades in the TS, but Freud has me sold on their circular saw blades now!
-- Amateur woodworker, professional mess-maker.
Routerisstillmyname
#13 posted 08-26-2010 07:55 PM
As i said in my other CS review, If you want sharpness, quality, longevity and PRICE, Freud has the best saw blades and router bits.
AaronK
#14 posted 08-26-2010 09:50 PM
cool. thanks again for the info.
View Dusty56's profile
Dusty56
11822 posts in 3887 days
#15 posted 08-26-2010 11:17 PM
I also use the Freud 7 1/4” blades in my TS for both ripping and cross cutting. They save a lot of pricey , exotic wood in the long run .
Nice review and great to see some real pictures instead of downloaded product photos : )
Thank you !
