Couldnt be more dissapointed in my bostich compressor
Review by jordan32407 posted 08-14-2010 05:36 AM 3673 views 0 times favorited 10 comments Add to Favorites Watch
Couldnt be more dissapointed in my  bostich compressor No-picture-s No-picture-s Click the pictures to enlarge them
I bought this compressor thinking it was a good deal, I used, and a it a few times to blow up a car tire, then for a roof and a few pieces of trim work. Then the regulator (thing that controls outlet pressure) control stripped out. I beleive its because it is cheap and it cant handle the pressure in the tank being on it over time. and no i didnt leave the tank with pressure in it all the time. A quick fix to get you by if you cant for a new part or like in my case it gets stripped out, is to take a pair of vice grips and pull off that red nob you use to change the pressure, then take a metal tap and re tap it for a bolt then just tighten or loosen a bolt to change the pressure. But be advised that its not very sensitive after you do this and you will have to reset the pressure every once in a while throughout the day. So Again if your looking for a compressor this isnt it.
View jordan32407's profile
jordan32407
1 post in 2841 days
10 comments so far
View wseand's profile
wseand
2796 posts in 3040 days
#1 posted 08-14-2010 05:54 AM
I have never used the Bostitch but I have heard they can be trouble. A lot of the smaller cheaper compressors seem to be having trouble. I went through 2 Porter Cable 6 gall compressor and finally the third one works great. Thanks for the review.
27250 posts in 3820 days
#2 posted 08-14-2010 01:12 PM
Jordan, I am sorry that you had problems with your compressor. I bought this same compressor about 10 years ago and have never had any problems with it. I have often left it on in my shop for weeks at a time since I have gotten too lazy to drive a nail by hand anymore. :)
The only issue I have with it is in the placement of the shut off switch. It is positioned so that, if I am not careful, it gets tripped by hitting my leg when I am carrying the compressor to another location. I occasionally forget about it being off when I then plug in the compressor. Thanks for the review.
View Dennis Fletcher's profile
Dennis Fletcher
467 posts in 3053 days
#3 posted 08-14-2010 01:47 PM
Thanks for the review. I was looking at this set-up, since my twin tank compressor from Bostitch has been good. I thought this would be a lighter one to have.
-- http://www.ahomespecialist.net, Making design and application one. †
View Sailor's profile
Sailor
543 posts in 3263 days
#4 posted 08-14-2010 02:05 PM
Sorry to hear about your bad experience, I have bought a few of the cheaper pancakes and they do fail for some silly reason. Just recently I bought a small Makita air compressor and boy does it make the others look like peewee compressors. I have two of the pancakes from Lowe’s sitting around because of some sort of failure.
It’s the Makita MAC700 Big Bore 2.0 HP Air Compressor. This thing is really quiet and can push a framing nailer without a problem. It couldn’t keel up nailing together a long header, but that’s nailing more than 30 nails really quick. I love it and for $207 shipped to my door from Amazon, I felt it was a great deal.
-- Dothan, Alabama Check out my woodworking blog! http://woodworkingtrip.blogspot.com/ Also my Youtube Channel's Facebook page https://www.facebook.com/SailingAndSuch
View davidroberts's profile
davidroberts
1027 posts in 3484 days
#5 posted 08-14-2010 04:55 PM
I’ve been leary of Bostitch compressors but I’ve heard their nailers are ok. I discovered most pancake type
compressors are problematic. I did a lot of research and finally bought a twin-tank 2.5hp Makita, the next step up from Sailor’s. It is oiled but I believe the oil-free can be a problem. I needed to replace a lot of fence after Hurricane Ike. I can actually work along side it in a 400 sf garage and not be bothered with noise. It’s that quite, and noise was a major consideration. I drain it after every use to prevent rust. If your in the market I’d recommend giving this one or Sailor’s a look.
http://www.amazon.com/Makita-MAC2400-Big-Bore-Compressor/dp/B0001Q2VPK/ref=pd_cp_hi_2
-- Better woodworking through old hand tools.
View Ken90712's profile
Ken90712
17556 posts in 3187 days
#6 posted 08-14-2010 06:41 PM
I had three of thier nail guns and took all of them back and got Porter Cable. They always seemed to jam. Sorry to hear about your bad luck with them as well.
View richgreer's profile
richgreer
4541 posts in 3072 days
#7 posted 08-14-2010 08:01 PM
This review is about the compressor, but it is listed under the nailer, stapler combo heading. Your ranking lowers the average ranking for the combo.
One could interpret this as a bad rating for the whole combo including the nailer and stapler. I assume that is not what you intended.
As an FYI – I use a couple Bostitch nailers (but not their compressor) and I am very happy with them.
View jockmike2's profile
10635 posts in 4244 days
#8 posted 08-15-2010 01:19 AM
Check out my blog about this same compressor a couple years ago. I complained about it on here and man did I stick my foot in my mouth. Gary Blanchette the Superintendent of Product Developement contacted me personally by e-mail and apoligized and asked me what he could do to make it right, They sent me a whole new compressor with a new 23 gauge pin nailer. Then he followed up asking me if everything was ok. So contact him.
View ChuckM's profile
ChuckM
608 posts in 3664 days
#9 posted 12-31-2010 07:30 PM
For those who have a noisy compressor but aren’t ready to jump on a newer, better, and quieter compressor, try enclosing your compressors. The enclosure can be a dedicated box (lined with carpet inside), your cupboard, or just your stock sheets (placing your compressor behind your plywood sheets). I put mine in the far corner behind some lumber sheets and use it with a hose reel. Of course, I wear ear muffs all the time when I am in the shop using power tools (T/S, DC, and bench top belt sander are on a lot of the time anyway).
-- The time I enjoy wasting is not time wasted
