Excellent planer, but get the extended tables
Review by Vrtigo1 posted 1018 days ago 2450 views 0 times favorited 15 comments Add to Favorites Watch
Excellent planer, but get the extended tables No-picture-s No-picture-s Click the pictures to enlarge them
This is my first planer, so I don’t have anything to compare it to, but it works great. All of the controls are easy to use, two speeds (different # of CPI for dimensioning or finishing). I like the fact that the cutter head is connected to the base with 4 risers instead of two like the DW734 and DW733 as well as the Ridgid and Ryobi planers they carry at Lowes and Home Depot. The depth adjustment is extremely easy to use and once I set it, it hasn’t moved once.
The top is easy to remove using the included wrench that stores in a recess located on the top of the machine. I haven’t had to change the blades yet, but it doesn’t appear to be difficult.
The machine is heavy – it is still portable, but it’s not something that I’d want to move every day. When I’m not using mine, I store it on a shelf below my workbench and I usually have someone help me lift it to the table top if there’s someone nearby.
This thing generates a TON of wood chips, probably the most of any tool in my shop. I made the mistake of running it without any dust collection right after I got it to try it out, and spent the next half hour sweeping my entire shop.
I use mine with a 4” flex hose directly connected to my DC and it catches 100% of the chips and about 90% of the dust. I haven’t tried using it with a shopvac, but I doubt it could keep up with the volume of chips this thing spits out.
The quality of the cut is very good, but I do end up with snipe on the end of boards. DeWalt makes an accessory kit that has extended in/outfeed tables, and I’d highly recommend them. I’d almost say that they should be included in the box.
View Vrtigo1's profile
Vrtigo1
420 posts in 1158 days
15 comments so far
View lew's profile
lew
8974 posts in 1922 days
#1 posted 1018 days ago
Thanks for the review.
I agree with you about the extension tables. They are worth the money.
As for chip collection, I made one of these. I don’t have a dust collector and my shop vac is too small for the amount of chips this planer produces.
-- Lew- Time traveler. Purveyor of the world's finest custom rolling pins!
View AaronK's profile
AaronK
1365 posts in 1631 days
#2 posted 1018 days ago
I have an older Ryobi model, and fine tuning the performance of that depended heavily on proper setting of the in/out tables. This model is definitely sweet, better than mine, but the snipe is not surprising. If you’re not so concerned about portability, you can set up your planer with long and rigid in/out tables – much longer and more rigid than the ones they will sell you. you can set them to be exactly coplanar with the planer bed, and your snipe will disappear. I’m even thinking of doing that with mine – removing the factory tables and building my own. check the archives here – lots of people have done similar things.
View spclPatrolGroup's profile
spclPatrolGroup
159 posts in 1061 days
#3 posted 1018 days ago
I have heard great thins about this planner, ther only knock on it was the longevity of the knifes, I know there are a lot of companies that make replacement knifes for them, but has anyone had this problem?
-- Dave, Fargo ND "Bad spellers of the world, UNTIE!!"
View TLE's profile
TLE
25 posts in 1615 days
#4 posted 1018 days ago
I have one of these also and the knives have been very durable – they’ve well outlasted the jointer knives on the same wood. However, I see this machine as a “lightweight” portable and finishing planer and I take very light cuts and more of them. If I have to match pieces to previously dimensioned stock I measure the boards with a caliper for the last pass and set the cut with my dial indicator – the planer will give me a match within a mill or two.
I also have the accessory infeed and outfeed tables and they are very convenient. The best help you can give yourself to eliminate snipe, though, is to just hold up the boards yourself until they are well into the maching (fully controlled by the fore and aft rollers) and then hold up the board on the outfeed side through the completion of the cut. If you do this reasonable well you probbaly won’t even need the additional tables.
Tim
View ChrisForthofer's profile
ChrisForthofer
153 posts in 1233 days
#5 posted 1018 days ago
For replacement knives for the Dewalt check this out http://www.infinitytools.com/DeWalt-DW734-DW735-Planer-Knives/products/1649/ they make both a HSS and Carbide tipped set of knives for it. I havent tried a set yet but they will be going on once the originals give up the ghost.
Chris.
-- -Director of slipshod craftsmanship and attention deficit woodworking
View richgreer's profile
richgreer
4474 posts in 1241 days
#6 posted 1018 days ago
I have no doubt that this is a very good planer. I have had the 733 for about 10 years and it has performed flawlessly. I’ve looked at the 735 and I can see noticeable improvements over the 733.
However, if the 733 ever failed me, I think I would get the 734. As good as the 735 is, for me, it is hard to justify the extra cost.
View ChuckC's profile
ChuckC
547 posts in 1101 days
#7 posted 1018 days ago
I have this planer too and it has served me well for just over a year now. Good luck!
View AuroraWoodworks's profile
AuroraWoodworks
191 posts in 1289 days
#8 posted 1018 days ago
I love my 735. I agree that the outfeed tables should come with the planer. That is my one big complaint with DeWalt tools. Seems like most of thier tools I buy have some accessory like the outfeed tables or a dust collection adapter that you have to buy seperately. These things are ALWAYS special order items!
-- Tony - Anchorage, Alaska
View Cato's profile
Cato
642 posts in 1479 days
#9 posted 1017 days ago
I brush my wood with a wire brush to get off silica and debris that might damage the thin blades. So far so good.
Chip blower coupled with the DC is awesome.
I ordered the extension tables and matching cart from Grizzly to make it easily portable in the shop. I found that if I adjust the outer ends of the extension tables up a little bit it will take the snipe out, so that all you have to do is start it in the feeder and catch it on the outfeed end or make sure it gets on the roller stand correctly.
I too only take minimal passes, usually a little less than 1/32.
View lanwater's profile
lanwater
2417 posts in 1100 days
#10 posted 1017 days ago
I have one with the extension tables. It’s great!
I take light passes and have not noticed any snipes.
the integrated chip blower coupled with a dust collector take care of every chip.
Love it.
View Gerry's profile
Gerry
228 posts in 1407 days
#11 posted 1016 days ago
I have one with the extension tables, and have had no instaces of snipe. What a great tool! For the chip generation, I’ve connected this and all my tools to my DC, with a thein baffled 30 gallon garbage can, with extraordinary results.
I made mine very tight to the side of the can, and sealed the MDF top after I grooved it. The result is i get NO dust or particles in the DC bag, but have filled the can twice now. An additional benefit is there is little dust escaping into the air. You can find details on the baffle design here: http://www.cgallery.com/jpthien/cy.htm
Hope this is of help.
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
View Howie's profile
Howie
2449 posts in 1089 days
#12 posted 1016 days ago
I’ve had my 735 for four years and have had very good luck with it. If there was anything I dislike it’s like everything else DeWalt has, the repair parts are expensive. A set of blades is 54 bucks! A bit pricey for three little strips of metal. In spite of using a wire brush AND a metal detector I managed to wipe out a knife.
-- Don't rollerskate in a buffalo herd
View Ken90712's profile
Ken90712
12660 posts in 1355 days
#13 posted 1011 days ago
I have the single speed model and love it. Going to have to order the replacement blade Chrisforheor mentions.
View ray470's profile
ray470
20 posts in 1007 days
#14 posted 999 days ago
I HAVE THE DEWALT 735 AND IT A GREAT PLANER BUT HEAVY.
-- ohio
