Electric power hoist
Review by jerset posted 07-23-2010 02:39 AM 10192 views 0 times favorited 6 comments Add to Favorites Watch
Electric power hoist Electric power hoist No-picture-s Click the pictures to enlarge them
Electric Power Hoist
I needed a way to lift heavy loads in and out of my pickup. Table saw 600 # Band saw 275 # Drill press 140 #
I purchased this hoist from Cabela’s and the swing out hoist frame. I
Made in china sold by Cabela’s, Grizzly, Harbor Fright and others.
EM # 44006 MANUFACTURER: CHICAGO ELECTRIC POWER TOOLS
Description
decided to mount the hoist on a galvanized pipe, a 4’ section in the ground 2’ deep with 2 60# sacks of concrete, a coupling with a 10 section on this giving me a 12’ vertical support attached to the eve of the garage. The correct pipe size is 2 1/4’, with the line doubled, using nylon straps purchased from Grizzly I was able to unload the 600# saw with ease. I then set the saw on a mobile base and rolled into the shop.
This 880 lb. hoist helps you lift heavy, bulky items, and operates with a remote control that lets you stand safely away from the item you’re lifting. Electric hoist motor lifts at a rate of up to 33 ft. per minute.
5-ft. remote-control cord for power up/power down
Single-line capacity: 440 lbs.
Double-line capacity: 880 lbs.
Single cable length: 38 ft.
Motor: 1-1/8 HP
3400 RPM
8 amps
800 watts
Cabela’s Heavy-Duty Electric Hoist Frame
Overall Customer Rating: 4.5 out of 5
Read Reviews(8) | Write a Review
Mount your hoist anywhere
Swings out of way when not in use
Works with both the 400-lb. and 800-lb. models. Mounts to steel post and swings out of way when not in use. 1,300-lb. capacity. Extents to 29-1/2”. All hardware included (pole not included).
-- jerset
View jerset's profile
jerset
37 posts in 3103 days
6 comments so far
View rustfever's profile
rustfever
762 posts in 3546 days
#1 posted 07-23-2010 03:17 AM
You are getting wiser as you get old. THIS IS FANTASTIC. I have a bad back trying to do things the ‘Hard Way’
-- Rustfever, Central California
View Steven H's profile
Steven H
1117 posts in 3296 days
#2 posted 07-23-2010 03:47 AM
Looks like a good tool, I will need one.
Have you tried mounting it indoors, because
I don’t want my garage roof to collapse. LOL
View b2rtch's profile
b2rtch
4868 posts in 3284 days
#3 posted 07-24-2010 03:41 AM
This is what I am installing in my new shop
-- Bert
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3351 days
#4 posted 07-26-2010 09:36 PM
thank´s for the reminder of using a hoistsystem
I will make a note in my book I have to remember theese things in
Dennis
View poopiekat's profile
poopiekat
4405 posts in 3970 days
#5 posted 07-28-2010 01:49 PM
I use a 1-ton chain-fall hung from the beam above the garage door to lift loads out of my truck. Not nearly as nice as your installation, though! Great idea!
View GMman's profile
GMman
3902 posts in 3933 days
#6 posted 07-28-2010 02:04 PM
Give us some photos poopiekat maybe handy for others.
