Hand sanding that I actually like doing...really
Review by Tim Dahn posted 07-11-2010 01:23 AM 4881 views 4 times favorited 22 comments Add to Favorites Watch
Hand sanding that I actually like doing...really Hand sanding that I actually like doing...really Hand sanding that I actually like doing...really Click the pictures to enlarge them
Bill Bush was at the Chantilly Va. wood show this spring demonstrating his finishing products, so I had a seat, watched and listened as he showed how he finishes his projects. I did not purchase the kit but rather the Bush oil, some PSA (pressure sensitive adhesive) sand paper, fiber pads and a DVD. I have since called to order additional sand paper and a couple sanding blocks, so this review is for the sanding products and the technique he uses, and well I use it now too. First the PSA sand paper (carborundum) is quality stuff; the open coat, aluminum oxide grit cuts aggressively, resists clogging and seems to last quite a long time.
But it’s not just the sand paper, the technique is what really made sense to me and there are a couple of key points to make here;
1. The PSA sand paper does not slide around so there is no wasted effort. The foam sanding block cushions just enough to keep from damaging the sand paper under pressure.
2. The addition of a trimmed 2” natural bristle paint brush for cleaning the wood surface helps get the dust out of the way when changing to the next higher grit and cleaning the sand paper also helps it last even longer.
The 80 and 120 grits do most of the work leveling the wood and then usually just a few passes with 180, 220 and 400 before moving on to the ultra fine fiber pad to remove any embedded saw dust and last the non abrasive fiber pad burnishes the surface, at this point you have a completely flat smooth as glass surface. The sanding blocks are a little expensive ($20ea) for me so I just purchased two, for the 80 and 120 grits and made my own from MDF and some foam material I found locally for the 180, 220 and 400 grits.
The finish seems to be a mix of oil and poly and can be mixed with oil base stains. I will post a review of the oil finish after I complete the clock I’m working on but I can tell you after using it on some test pieces, I like it too.
View Tim Dahn's profile
Tim Dahn
1562 posts in 3434 days
22 comments so far
13594 posts in 3210 days
#1 posted 07-11-2010 01:29 AM
where do i send my work ?
how soon can i have it back (LOL) ?
good review , thanks .
23434 posts in 3720 days
#2 posted 07-11-2010 03:21 AM
Thanks Timbo
View jplhomes's profile
jplhomes
12 posts in 2903 days
#3 posted 07-11-2010 09:30 AM
Good review. Do they have a web site or where can you buy the products?
-- John
View degoose's profile
degoose
7227 posts in 3224 days
#4 posted 07-11-2010 10:48 AM
Finishing is always the most fun….?
View stefang's profile
stefang
15697 posts in 3203 days
#5 posted 07-11-2010 12:22 PM
Good review Tim. I do a lot of hand sanding, mainly because it isn’t as difficult as many think. Good technique such as sanding at an angle across the grain form both sides first and then with the grain for each grade helps a lot and keeps things flat. I would be willing to do this on a drum sander if I had one though, lol.
View Jim Bertelson's profile
Jim Bertelson
4147 posts in 3033 days
#6 posted 07-11-2010 02:54 PM
I find I am doing more hand sanding since I made Norton, the fancy sanding block. But I think it is the new Norton 3x sandpapers that make it even easier to hand sand. Have to admit, though, haven’t had to sand anything difficult lately. Then I suspect, it is back to the machines. I will keep this in mind and have favorited it for reference.
-- Jim, Anchorage Alaska
View Dusty56's profile
Dusty56
11814 posts in 3557 days
#7 posted 07-11-2010 04:45 PM
I also saw Bills presentation at the W.Springfield,MA show this past January, AND gave him a good amount of my money afterwards .LOL…I had been using the Bush Oil previously with good results , but after learning his sanding techniques , it made an even nicer end result : ) Those sanding blocks are pricey , but certainly very comfortable to use…..Nice review : )
Tim Dahn
#8 posted 07-11-2010 09:00 PM
John The products are available at Curiouswoods and lakeshorehardwoods.
Mike Thanks for the tip, I will give the “sanding at an angle” a try with the 80 grit to see if it is any faster/easier.
Jim The Norton may be the same or similar abrasive with the open coat to allow the grit release the saw dust easier.
Dusty56 The presentation was convincing, in retrospect I should have bought the kit.
Dusty56
#9 posted 07-12-2010 03:21 AM
I bought a kit plus some “extras” ” : )
View Don Alexander's profile
Don Alexander
14 posts in 3558 days
#10 posted 07-12-2010 09:29 PM
Woodcraft sells the yellow foamy sanding blocks and I love mine. They are very comfortable and do a great job. They are pricey however, but worth it.
-- Don Alexander, Jacksonville, Florida
View DonFaulk0517's profile
DonFaulk0517
131 posts in 3355 days
#11 posted 07-13-2010 01:51 AM
Good review… I purchased the sandpaper and sanding blocks over a year ago and have used them since. They are great! I was at Lakeshore Hardwoods this weekend (while on vacation in Central NY) and picked up more sandpaper… there are no equals when it comes to these blocks and sandpaper. I have blocks for all grits and it makes sanding easy.
Great review!
Enjoy!
-- DonFaulk0517@gmail.com
View jtash's profile
jtash
30 posts in 2952 days
#12 posted 07-14-2010 04:52 AM
The sanding blocks are from 3M and they are called stikit sanding blocks. I think the number is 5442. You can find them on the internet for a lot less then they sell them for at the shows. Just watch out for shipping.
I used the sanding method for one project so far. Actually I hand planed and started with the 220 grit. Using pencil scrible to tell you when to stop sanding and move to the next grit is a huge time saver. The hand sanding to 600 grit followed by the gray and white pads leaves a super smooth surface and the Bush oil is a high quality oil varnis blend. In other words I had good results.
View Ken90712's profile
Ken90712
17537 posts in 3058 days
#13 posted 07-14-2010 02:18 PM
Great review but I still dont like sanding. Cool product though.
Tim Dahn
#14 posted 07-14-2010 10:19 PM
Don I can’t find these at woodcraft, what do they call them?
jtash I have found the 3M products but I’m not completely convinced they are the same.
Dusty56
#15 posted 07-15-2010 12:54 AM
Bill Bush had told us at the show that his sanding blocks were custom made .
I saw that 3M has a “hard” and a “soft” version of these blocks.$18 Hard and $17 Soft
showing 1 through 15 of 22 comments
