The Craftex Blue Tornado Dado Set........... a cut above the rest.
Review by Gord Graff posted 06-26-2010 07:06 PM 7944 views 3 times favorited 8 comments Add to Favorites Watch
The Craftex Blue Tornado Dado Set........... a cut above the rest. The Craftex Blue Tornado Dado Set........... a cut above the rest. The Craftex Blue Tornado Dado Set........... a cut above the rest. Click the pictures to enlarge them
(CBT017) 8”X24
Cutting dadoes and rabbets in sheet material such as veneer coated plywood or particleboard or melamine coated particleboard is a routine procedure in woodworking. What isn’t so routine is cutting splinter free dadoes and rabbets in this type of material but now that’s a thing of the past with the Craftex Blue Tornado 8” CBTO17 dado set. The Craftex Blue Tornado line of saw blades, router bits and shaper cutters is exclusive to Busy Bee Tools in Canada and contain all of the features found in “top of the line” woodworking cutting products without the premium price tag that goes along with such products. (See product features below)
The CBTO17 dado set I tested was specifically designed for use with veneer coated plywood (or particleboard) and melamine coated particleboard. Blue Tornado claims a splinter free cut in either materials…………….that’s a bold claim and I was eager to find out whether or not this dado set could meet this claim.
In my shop I have several pieces of what have to be some of the worst plywood and melamine sheet material I have ever worked with. These materials (maple plywood, oak plywood and melamine coated particleboard) will chip out when cut with even the best blades and cutters I own……………………..this stuff is just, bad material.
So I thought that if the Craftex Blue Tornado dado set could cut these materials with a minimum of tear out, I’d be very happy. Little did I know at the start of this test that this dado set would far exceed my expectations.
The Package:
This dado set comes in a well made wooden box that is foam filled to keep this set well protected against the bumps and bangs that may occur in a shop setting.
The set includes instructions, 2-24 teeth outside cutters, 6-chippers and a set of stainless steel shims. The two outside cutters feature an anti kickback design with plenty of C4 tungsten carbide. The outside cutters are clearly marked and identify this set for cutting plywood and melamine. This set will cut dadoes ranging in width from 1/4” to 15/16”.
The chippers that come with this set are all made with six wings providing a very smooth, flat bottom cut. Each tooth on these cutters features the same C4 tungsten carbide as found on the outside cutters and there is plenty of it, sharpened to a mirror finish with a razor sharp cutting edge. The six chippers sizes are clearly etched into each cutter. (4 X 1/8” chippers, 1 X 1/16” chipper & 1 X 1/32” chipper)
The set of stainless steel shims that are included with this dado set are 3 1/8” in diameter and their sizes are clearly marked on each shim. The shim set (5 shims) consists of 1X.020” , 2X .007” & 2X .005”. These stainless steel shims along with the different sized chippers allow the user to easily match the width of any material ranging from 1/4” to 15/16” and the stainless steel shims won’t break, tear or distort in use like some plastic shims.
The test was conducted with some of the worst veneer products I’ve ever come across. These materials were poorly made and no matter what method I used to cut splinter free dadoes across the grain of this material I always ended up with the same results…………….splintered edges. So what better material to test the claim of a splinter free cut? If the Blue Tornado dado set can cut these materials with a minimum of tear out, then I would have gone onto a better quality of samples and used them for the test. At that point in time I would have concluded that this dado set cut extremely well in good or better quality plywoods and melamines. But as you’ll see by the pictures below, this dado set performed flawlessly in the poorest material that I have ever worked with.
These are pictures of typical tear out that I experienced with my best dado set cutting across the grain of maple veneered plywood, oak veneered plywood and melamine coated particleboard.
As you can see in the picture below, cutting along the grain yields a clean cut with my favorite dado set but cutting this material across the grain ends in tear out.
Comparing all three materials and the cuts produced by the Blue Tornado dado set versus my favorite dado set the results are very clear. The Blue Tornado dado set does deliver on its claim of cutting splinter free dadoes in plywoods and melamines.
Conclusion:
This test was performed on a 3HP cabinet grade table saw without the use of a zero clearance throat plate. The Craftex Blue Tornado CBTO17 dado set clearly and effortlessly meets and exceeds its claims of cutting splinter free dadoes in plywoods and melamines. The shoulders on the cuts produced by the Blue Tornado were sharp and square with no burning or splintering. The bottom of the cut was dead flat with no valleys or ridges which makes for stronger joinery. The stainless steel shims and the three different size chippers (1/8” 1/16” 1/32” ) allow for sizing dadoes of every conceivable size between 1/4” to 15/16”
And I specifically stacked the odds against this dado set by not using a zero clearance throat plate. This dado set is all that it claims to be and so much more……………………
Visit the Busy Bee website today and check out the new Blue Tornado CBT017 8”X24 dado set, it is without a doubt…............................. a cut above the rest.
-- Informing & Inspiring Today’s Woodworkers: http://www.gordgraff.com
View Gord Graff's profile
Gord Graff
140 posts in 4093 days
8 comments so far
View GMman's profile
GMman
3902 posts in 3896 days
#1 posted 06-26-2010 10:02 PM
Thanks Gord…the 6 tooth in my bisicuit jointner are set the same way.
View Eric_Somerville's profile
Eric_Somerville
21 posts in 3090 days
#2 posted 06-26-2010 10:36 PM
I bought their other dado set (for solid wood) about three weeks ago. This is my first dado set but everything works very well, good quality material and good price.
-- EDS
View skeeter's profile
skeeter
233 posts in 3540 days
#3 posted 06-27-2010 03:20 AM
now that is a damn review. Awesome job! I give you 5 stars.
-- My philosophy: Somewhere between Norm and Roy
View sikrap's profile
sikrap
1121 posts in 3558 days
#4 posted 06-27-2010 04:05 AM
Wow!!! That is impressive. Thanks for a great review.
-- Dave, Colonie, NY
Gord Graff
#5 posted 06-27-2010 04:19 AM
Hi All,
Glad you like the review, thanks for your kind words.
All the best
Gord
View swayze's profile
swayze
97 posts in 3287 days
#6 posted 07-04-2010 12:27 AM
Good review. Have you ever used any of there router bits?
Gord Graff
#7 posted 07-04-2010 01:39 PM
Hello Swayze,
I don’t own any Blue Tornado router bits but I’m going to give them a try soon.
After seeing what this dado set is like, I’m looking for the same quality in their router bits.
All the best
Gord
View Snoman42's profile
Snoman42
2 posts in 2252 days
#8 posted 10-11-2012 06:43 PM
Excellent review. The photos do a great job illustrating the differences between the quality of blades.
My question is related to the comparison of the solid wood dado set and the plywood dado set. My next projects involve both plywood and solid wood dado-ing. But finances dictate only one set of dado blades. Which would you recommend to do both? Would the plywood set perform better on the solid wood or rather the solid wood set’s performance on the plywood? Thanks.
-- Spencer - NS
