| Review by alnandy | posted 1057 days ago | 4677 views | 2 times favorited | 7 comments | ![]() |
- Grizzly G0453Z 15" Planer
- Brand: Grizzly | Category: Planers
Just got mine in earlier this week. I’d been using a Delta 13” planer, which was doing a very good job. However, Delta got bought out and no longer produces this planer, so parts will be a problem in the future. Also, I’ve got several hundred board feet of curly maple to work through, and that would overwhelm the Delta. So, I bought the Grizzly. My experience was exactly the same as the previous review, except that my machine arrive without problems. The caster mechanism is awesome; I can move a 650 lb machine around easily and safely. I ran some curly tigerwood (goncalo alves) through and there was ZERO chipout. A tiny bit of snipe, which can probably be eliminated by lowering the table rollers. I’m not sure how to adjust the feed roller pressure; if anyone knows, give a holler.
As for the grease, UGH. Man, they slopped grease over everything; it took me hours to degrease the cutter head, feed rollers, etc. I still get an occasional spot. What a mess. The cutterhead is very impressive.
At $1400, plus shipping, this machine is a very, very good deal.
-- Allan
7 comments so far
Jim Bertelson
home | projects | blog
3335 posts in 1330 days
#1 posted 1057 days ago
Grizzly keeps getting good reviews here, especially for support and service. Glad it got there in one piece, seems like that is an issue at times…...
Alaska Jim
-- Jim, Anchorage Alaska
Brad_Nailor
2449 posts in 2123 days
#2 posted 1057 days ago
Nice looking machine! Helical cutter head?
alnandy
15 posts in 1063 days
#3 posted 1056 days ago
The cutterhead on the GO453Z is composed of about 70 small carbide squares, rather than 3 or 4 knives. It is called a helical cutterhead because the carbide inserts wrap around the cutting cylinder in helical fashion. This type of cutterhead is also called a Byrd or Shelix head, or other names. This cutting arrangement virtually eliminates chipout. I planed over 200 bd. ft. of curly maple on a planer with this type of cutterhead and had ZERO chip out, despite the fact that we were hogging the material off.
-- Allan
Dusty56
10496 posts in 1853 days
#4 posted 1056 days ago
This is where I get torn between buying the DeWalt 2-speed portable planer for nearly $700 and a real planer such as this one for twice the money but it has the Helical head and also takes 2” wider boards or panels.
For now , finances dictate that I stay with my present machine . Congratulations on your new planer : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
alnandy
#5 posted 1055 days ago
The Dewalt is a very good planer. For that matter, so was my 13” Delta (the 12 1/2” Delta is junk). Both machines will do a good job, even on curly woods, if you take a light cut.
I switched to the Grizzly, because I need to run hundreds of board feet, something the Dewalt and Delta machines aren’t designed for. The have universal motors, not induction motors; which means the will run hot if used hour after hour, leading to burn out.
As for the helical head, for the extra $400, it was a no-brainer. You might also want to check and see if Dewalt offers a helical cutterhead for their 13” planer, they might. You still can’t run hundreds of board feet through at a time, but, if you are an occasional user, this shouldn’t matter.
The 13” “lunchbox” planers are real planers; I’ve had no problems using my Delta for 5 years. Don’t upgrade to the Grizzly, unless you have a legitimate need to. I’m not much on bragging rights.
-- Allan
Dusty56
#6 posted 1055 days ago
Thanks and have a great day : )
markplusone
62 posts in 1120 days
#7 posted 1029 days ago
Alnandy, I have a 453Z and love the way it cleans up reclaimed lumber. Just needs a little more hitch in its getalong. The feed roller pressure is controlled by four 1”Dia. screws you access from the top of the machine. They take an allen wrench that was supplied by Grizzly with the machine (or one of your own). Im working pretty rough lumber so mine are tightened to where the tops of the screw are 1/16 above being flush with the top of the head. I also have my bed rollers at .020” too. It does create a big snipe but it reduces wear on the motor that can ill afford it. I think for smoother stock Grizzly recommends 0-.010” on the bed rollers. I had it like this and it made beautiful snipe free cuts. Just not good for rough lumber and hogging. (i have to take1/2”-5/8’ OFF EACH BOARD!) After all the lumber Ive put through this thing, about 4-5 thousand linear ft., I just rotated the teeth for the first time. Didnt truly need it but thought it would help with the load on the motor. Alson I have found you need to clean that head with pitch and gum remover whenever you notice any buildup. Buy stock in papertowels. Youll need it. LOL.
Despite my issue with the power, I do like running this machine
-- Dont carry that which you dont hold with.
