Grizzly 6" low-speed grinder (Shop Fox)
Review by glassyeyes posted 06-25-2010 01:29 AM 7231 views 2 times favorited 10 comments Add to Favorites Watch
Grizzly 6" low-speed grinder (Shop Fox) No-picture-s No-picture-s Click the pictures to enlarge them
This item is currently on sale at Grizzly for $49.99 plus shipping, listed at about $110. It runs at 1725 rpm, and the motor is rated as 1/4 hp, totally enclosed and fan-cooled. It ran quite smoothly right out of the box. The left wheel is 3/4” wide, and coarse grit. The right wheel is 1 1/2” wide, and is white aluminum oxide medium grit. I did the rough grinding on several chisels with the wider wheel, and was very pleased. A number of my chisels and plane irons are in need of regrinding and more careful sharpening, and I think this is just what I need to speed up the process. I may replace the left wheel with a hard felt wheel for honing; the right wheel removes metal rapidly enough for my needs. I bought a better tool guide to go with it, but haven’t installed that yet. Obviously I can’t report on longevity at this time, but so far it seems like a very good deal.
-- Now, where did I put those bandaids?
View glassyeyes's profile
glassyeyes
137 posts in 3414 days
10 comments so far
View Dusty56's profile
Dusty56
11819 posts in 3773 days
#1 posted 06-25-2010 11:57 AM
Those are the cheapest tool rests that I’ve ever seen ! Where did you find the replacement ones ? The price is certainly right ….nice review : )
View wch's profile
wch
45 posts in 3043 days
#2 posted 06-25-2010 10:39 PM
I just got one of these a couple days ago. I replaced the narrow wheel with a Norton 3x wheel, which is supposed to cut faster and run cooler than the stock wheels. Despite the relatively low speed (1725 rpm) and the upgraded wheel, I think I may have blued one of my chisels. I guess I got a little overconfident. :( But I agree that this grinder is a good deal – it’s the least expensive slow grinder I could find.
I built a tool rest like this one:
http://aquadoodiloop.com/how-to-make-a-bench-grinder-tool-rest/
glassyeyes
#3 posted 06-26-2010 03:12 AM
I got the hard felt wheel, and honing compound, from Lee Valley. $29.80 for the felt wheel. Not cheap. I got the tool rest from Grizzly; it seems adequate, but I’ll probably swap my Veritas from the old grinder to the new. I got the Grizzly rest because it WASN’T slotted for the wheel, and the right wheel is pretty wide. And it had a tiny little miter gauge; I haven’t tried it out yet.
View Jim Bertelson's profile
Jim Bertelson
4192 posts in 3249 days
#4 posted 06-26-2010 04:55 AM
You know, grinders don’t change much in appearance over the years. I have an inexpensive 1/4 hp grinder purchased over 30 years ago from a catalog. It looks just like that one. Yours is probably better, but who knows. I suspect it will be the only grinder I will ever buy. It doesn’t get a lot of use, but it is indispensable for some things.
Thanks for the review….....
Alaska Jim
-- Jim, Anchorage Alaska
117179 posts in 3662 days
#5 posted 06-26-2010 05:06 AM
thanks for the review
Dusty56
#6 posted 06-26-2010 06:23 PM
wch , thanks for the link…pretty nice idea : )
glassyeyes thanks for the additional info : )
View Abbott's profile
Abbott
2570 posts in 3389 days
#7 posted 06-27-2010 02:02 AM
That looks like a good one.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
Dusty56
#8 posted 06-28-2010 02:11 AM
I went with the JET “white” ....it does brighten the shop and I think the tools just look more expensive in that color : )
glassyeyes
#9 posted 07-01-2010 02:01 AM
UPDATE: FELT WHEEL—
I put the felt wheel on today. I have been busy polishing the stains off of my one good plane, and honing the edges of several plane blades. VERY NICE! I just shaved a patch off my arm to test the skew plane blade. I feel like a kid with a brand-new Erector set. (I guess that reference dates me a bit.)
GRINDER: The felt wheel instructions noted that many grinders can rotate the guards, to make sure you don’t run the blade edge-first on the felt. The guard has three screws—and six holes, neatly aligned to permit 180 degree rotation of the guard. I keep finding things to like on this little grinder—
My wife came out to the shop as I way testing the edge—she thought I’d lost my mind. Again.
View unisaw's profile
unisaw
92 posts in 4218 days
#10 posted 10-12-2013 02:55 PM
Apparently Shop Fox no longer makes this slow speed grinder. You can buy the Grizzly 8” for $495. WTH?
