veritas scraper plane
Review by gardentiger posted 1071 days ago 2990 views 1 time favorited 7 comments Add to Favorites Watch
veritas scraper plane No-picture-s No-picture-s Click the pictures to enlarge them
A beautifully crafted tool. Blade was sharp and did a great job on an end grain cutting board i’ve been trying to smooth. Sharpening a tool like this has quite a learning curve. Corners of the blade need to be rounded. The plane is much larger than it appears in pictures. It’s gonna be a fun one.
View gardentiger's profile
gardentiger
50 posts in 1139 days
7 comments so far
View ChuckV's profile
ChuckV
1750 posts in 1696 days
#1 posted 1071 days ago
I recently purchased this plane. It is part of my ongoing effort to do as little sanding as possible, since sanding tears the wood fibers while planing or scraping cuts them. After sharpening the blade, I used it on a project for the first time a few days ago, and I had great results.
You mention rounding the corners of the blade. This is not needed if you are using the thin blade that comes in the plane and you are going to bow it slightly when using it, as you probably would with a hand scraper. This is from the instructions:
When sharpening a thick blade, we recommend that you round the corners of the blade to ensure they do not leave corner digs in the workpiece. (You may also do so on a thin blade, but it is unnecessary if you are going to bow the blade).
Enjoy the new plane!
-- "Too much hurry ruins the body. I'll sit easy … fan the spark" - I. Anderson
View OttawaP's profile
OttawaP
89 posts in 1895 days
#2 posted 1071 days ago
Funny thing… I bought one of these years ago for a piece of wood so nasty I thought no plane stood a chance against it. Turns out my LV bevel up smoother cut thru it like butter…..dam Rob Lee and his sweet tools all to heck. I’ve barely used it but would not give it up for a second….it is a nice plane.
-- Paul
87141 posts in 1746 days
#3 posted 1071 days ago
thanks for the review
gardentiger
#4 posted 1071 days ago
Chuck,
Thanks for the reminder on the bow adjustment. A great plane just got greater.
View Bovine's profile
Bovine
112 posts in 1496 days
#5 posted 1070 days ago
Maybe this is a better question for the forum, but when do you use a scraping plane? Also, when would you use a scraping plane instead of a card scraper?
-- Kansas City, KS "Nothing is as permanent as a temporary solution"
View Swede's profile
Swede
187 posts in 1187 days
#6 posted 1070 days ago
I went to there web site but did not find a price.
Would the plane work for removing paint from a flat surface such as window trim?
I need to repaint the trim in my garage and it is 3/4” x 3” if I rember correctly.
-- Swede -- time to make some sawdust
gardentiger
#7 posted 1070 days ago
I’m new to ww. But, I have used a card scraper. The Veritas sp is a card scraper on steroids. For example, I used the card scraper to shore up some glue lines in my Spagnuolo style end grain cutting board. It finished the glue joints fine but left the cb wavy and uneven. 5 minutes with the plane and the entire board was flat.
re: removing paint: I personally wouldn’t subject my plane to such a task. And I’m only guessing that the paint shavings would not flow nicely off the blade.
