Finesse Table Saw Alignment with PALS
Review by Jack Barnhill posted 719 days ago 3062 views 3 times favorited 11 comments Add to Favorites Watch
Finesse Table Saw Alignment with PALS Finesse Table Saw Alignment with PALS Finesse Table Saw Alignment with PALS Click the pictures to enlarge them
The Contractor Saw Precision Alignment & Locking System (PALS™) from IN-LINE INDUSTRIES is just that, an alignment upgrade for a contractors table saw. It provides a significantly easier and more precise way of aligning the table saw blade to the miter slot than the manufacturer’s suggested method of pounding on or prying on the trunnion.
PALS consists of 2 each threaded studs, flat washers, nuts, lock nuts, L-brackets with adjustment screws and lock nuts, and 1 Allen Wrench or hex key for the adjustment screws. The size of the studs and corresponding components vary depending on the kit you need for your model of contractor saw.
Additional wrenches are needed to remove the old trunnion bolts and for installing the new mounting and lock nuts but, they’re common sizes. A non-permanent thread-locking liquid is also recommended to help prevent loosening of the threaded studs while the saw in operation.
Unfortunately I did not take any pictures of the kit before I installed it so I included a SketchUp drawing of the components that come with the kit and a couple of pictures of it installed on my Delta contractor saw.
The installation was done in less than 10 minutes and the alignment took maybe another 5 minutes. In less than 15 minutes, I had perfectly aligned the blade to the miter slot and locked it in. No longer do my cuts show signs of the blade being out of alignment. I give the Contractor Saw Precision Alignment & Locking System a 5-Star rating.
-- Best regards, Jack -- I may not be good, but I'm slow -- www.PixelsandSawdust.com
View Jack Barnhill's profile
Jack Barnhill
346 posts in 1171 days
11 comments so far
View Lee A. Jesberger's profile (online now)
5812 posts in 1784 days
#1 posted 718 days ago
Hi Jack,
Great review.
View DannyBoy's profile
DannyBoy
521 posts in 1670 days
#2 posted 718 days ago
This is a pretty interesting upgrade.
~DB
-- He said wood...http://hickbyassociation.blogspot.com/
56311 posts in 1382 days
#3 posted 718 days ago
A new one on me Thanks for the super review
-- W James Brokenbourgh Custom furniture maker http://artisticwoodstudio.com
View mnguy's profile
mnguy
103 posts in 1203 days
#4 posted 718 days ago
I installed this same system on my Jet contractor saw ~2 years ago, and I also heartily endorse the product. Once you have it installed, you set it and forget it.
View ElmoSr's profile
ElmoSr
175 posts in 831 days
#5 posted 718 days ago
very interesting i sure need something,,,
-- ElmoSr,Ga. Life is Hard by the Yard,,,But a Cinch by the Inch
View dfdye's profile
dfdye
372 posts in 842 days
#6 posted 717 days ago
I have seen this product and figured it must be a good upgrade over a dead-blow mallet. Thanks for the review.
-- David from Indiana --
View Todd Clare's profile
Todd Clare
67 posts in 790 days
#7 posted 708 days ago
I have one of these on my Delta contractor saw and agree 100% with the review. Took no time to install, was simple to adjust (that’s lefty-loosey, right?), and locks it in perfectly within a few minutes.
-- Todd (Denver, CO -- Highlands)
View Rick's profile
Rick
336 posts in 1015 days
#8 posted 685 days ago
I’ve got these on my tablesaw. It’s a Jet contractor style. They did help me bring it into a reasonable alignment. I think they would have been more helpful if I just didn’t have to contort my arm just to get to my trunion bolts.
View PflugervilleSteve's profile
PflugervilleSteve
95 posts in 847 days
#9 posted 684 days ago
I’ve used these as well. For around $20, it’s one of the most knuckle saving, best additions to a contractor saw I can think of. Trying to align trunnions by whacking it with a block of wood or by hand is no fun.
View bch's profile
bch
125 posts in 494 days
#10 posted 202 days ago
I just used these as well and am very pleased. I would recommend them to anyone with a contractors saw. Why these don’t come with every contractors saw is beyond me. I only have negative comments on their instructions, which I comment on in my blog.
-- --bch
View ajosephg's profile
ajosephg
1503 posts in 1366 days
#11 posted 202 days ago
I have these on my saw, and I recommend them.
-- Joe
