Makita BO5030K
Review by Steven H posted 06-03-2010 06:34 AM 6391 views 0 times favorited 4 comments Add to Favorites Watch
Makita BO5030K Makita BO5030K Makita BO5030K Click the pictures to enlarge them
UPDATE:
I end up returning it, due to manufacture’s defect . The sander pad was scratched and had dents in it.
The second is way worse.
More vibration than the first one, and way louder.
I shouldn’t even return it in the first place.
I had $70 to spend, I had a choice should I get the ridgid R2600 or Makita B05030k. I leaned toward to Makita.
It comes with a abrasive disc (#120;794520-1),dust bag(166078-4) and plastic case.
Speed
The product description said
“Pad control system for controlled pad speed upon start-up”
You would have to put it on the wood before spinning at full speed.
When you take it off the work-piece, it starts spinning fast at full 12,000 OPM.
Other people had problems with it that it creates gouges in full power.
But I don’t have any problems with mine.
Vibration
This is a well made sander and very comfortable in your hand with almost no vibration.
Dust Collection
What I like about this sander is, that it shoots dust air into the cloth bag without having any leaks. But The dust port is so small, hooking up a vacuum is more difficult to do.
Noise
I have to say this is way quiter than Porter cable 343k sander.
Pro
- Comfortable grip
- Lightweight
- Stops smoothly
Con
-Dust collection port too small: I don’t think it was designed for connecting to vacuums.
View Steven H's profile
Steven H
1117 posts in 3300 days
4 comments so far
117420 posts in 3817 days
#1 posted 06-03-2010 06:39 AM
Thanks for the review
View dustinkester's profile
dustinkester
32 posts in 3415 days
#2 posted 12-22-2010 07:00 PM
Good review. Too bad you had to return it, and then had even worse luck. Most of the time Makitas do not disappoint like this.
-- http://www.orbitalsanderreviews.com | http://www.detailsanderreviews.com | http://www.alltablesawreviews.com
View 559dustdesigns's profile
559dustdesigns
633 posts in 3408 days
#3 posted 12-22-2010 07:25 PM
I recently picked up a Makita sander at OSH because it was a clearance item. The sander was only 32.34 with tax and everything. This sander works great and vibrates less than the Porter Cable I spent 69 bucks for. Please don’t write off Makita tools.
-- Aaron - central California "If you haven't got the time to do it right, when will you find the time to do it over?"
Steven H
#4 posted 12-22-2010 08:06 PM
559dustdesigns
Not all tools coming from the factory are the same.
I made a mistake by buying from Big Box store. should have been bought from Bob’s store.
It is not the same.
