| Review by Mick | posted 640 days ago | 547 views | 0 times favorited | 1 comment | ![]() |
- Remington M30016AS 3.0 HP, 16" Electric Chainsaw
- Brand: Remington | Category: Chainsaws
I purchased one of these at a local hardware store for trimming limbs in my yard and doing rough cut of logs for the rustic furniture I build.
It does have plenty of power and minimizes weight. I actually used it to cut down an entire (dead) 15ft apple tree in my yard. The apple wood is drying in my “bone yard”.
The chain tension will not hold for more than a few minutes.
The chain that comes with it has such a low tooth count compared to chain speed that it chews through the wood rather than cutting it. I have to replace the chain before I can use it very much even for trimming trees. The cutting action is so rough (due to the chain) that it makes it very uncomfortable to use for very long.
The oil reservoir continually leaks a small amount out the cap if the saw is hung by the built in handle hook.
If you’re going to buy one of these electrics I would recommend buying a used one. Then throw away the chain that comes with it and get one made at your local hardware store. Store it in horizontal position only, don’t hang it.
-- The name is "Splinter"... I'm the son-of-a-son-of-a-carpenter
1 comment so far
Andrew
home | projects | blog
108 posts in 98 days
posted 83 days ago
Hey, nice job. I have one of these too, bought it for $20 on sale. I agree with all you have said, my bar oil even leaks in horizontal, I only add enough oil for the job at hand. Does cut rough, but It is quieter than my 20” gas saw, so I geuss every tool has a place where it shines.
-- As the Saw Turns
