Central Machinery 14x40 wood turning lathe
Review by thefishingschool posted 05-30-2010 06:11 PM 26128 views 0 times favorited 6 comments Add to Favorites Watch
Central Machinery 14x40 wood turning lathe No-picture-s No-picture-s Click the pictures to enlarge them
I have had and used this very much and so far i am satasfied with it but the switch that comes with it broke so i just wired a light switch to it. the bed is made of square steel tubing and seems to have a decent but tolerable amount of vibration. only one compliant and that is when you tighten the tailstock the headstock will bend upwards
-- wood takes time and effort... just like women
View thefishingschool's profile
thefishingschool
41 posts in 3218 days
6 comments so far
View David Craig's profile
David Craig
2137 posts in 3310 days
#1 posted 05-30-2010 06:31 PM
Nice review. I have this lathe down the basement and have used it off and on. You are correct, the headstock does bend and there is a fair amount of vibration to it. Some of this can be controlled by weighting down the stand. Also, if you wish to upgrade to a chuck for small turnings or hollow vessels. you might want to check out the adapter manufactured by PSI here. The spindle is a strange 10tpi 3/4 configuration. Penn State industries makes an adapter for it so you can put a normal 4 jaw chuck on it. The tailstock will be out of synch with it but works well, by itself, when the piece has been rounded. You can use the HF faceplate to round the vessel then chuck it for further cuts.
Thanks for the review,
David
117328 posts in 3778 days
#2 posted 05-30-2010 06:34 PM
Good review
View tooldad's profile
tooldad
660 posts in 3916 days
#3 posted 05-30-2010 07:06 PM
Thanks for the review. I was going to look at a used Grizzly lathe built the same way. Someone else got to it first. Probably better that I didn’t get one with tube bed.
View thatwoodworkingguy's profile
thatwoodworkingguy
375 posts in 3131 days
#4 posted 05-30-2010 08:59 PM
hmmm thanks for the review. I was thinking of getting this.
-- thatwoodworkingguy.com ~Eagle America~ ~Woodcraft~
View William's profile
William
9950 posts in 3043 days
#5 posted 09-02-2010 09:40 PM
I had this same lathe. I bought it on sale for $69 at Harbour Freight. It lasted two weeks before the tailstock housing busted. Before I could get a chance to return it, I got my hand on another lathe and this just sat in my shop for about six months. Eventually I added padding and glued six inch sanding disks to the plates on the inboard and outboard sides, removed rail bed completely and started using it as a stationary disk sander. I’d have given this no stars as a lathe, but five stars as a disk sander.
View WoodworkingGeek's profile
WoodworkingGeek
181 posts in 2894 days
#6 posted 01-12-2011 12:55 AM
I was looking into buying this lathe but the following changed my mind. Have you seen a lathe with a sheet metal headstock? And have you seen a lathe that’s lathe bed with a tube design? the tube design would flex too much. I wouldn’t recommend getting this lathe.
