REMOVED
Review by Rick S... posted 05-20-2010 10:48 AM 3817 views 1 time favorited 8 comments Add to Favorites Watch
REMOVED No-picture-s No-picture-s Click the pictures to enlarge them
Gone
-- I Chose "The Road Less Travelled" Now I'm Totally Lost! (Ontario, CANADA)
View Rick S...'s profile
Rick S...
10913 posts in 3233 days
8 comments so far
View Ken90712's profile
Ken90712
17594 posts in 3389 days
#1 posted 05-20-2010 11:56 AM
Very good review, Thx
View Greedo's profile
Greedo
473 posts in 3160 days
#2 posted 05-20-2010 12:16 PM
nice review, didn’t know this existed.
but how exactly does it work to clean the pad? i wipe mine with turpentine and it removes all the sticky parts, but it seems that after doing that the pad gets full 2 times faster!
View rance's profile
rance
4266 posts in 3360 days
#3 posted 05-20-2010 01:17 PM
Some stores sell a cheap stick of rubber to clean sanding belts, drums, etc. They make your sandpaper last 50 times longer. You can also use your old(or someone else’s new) tennis shoe.
117328 posts in 3777 days
#4 posted 05-20-2010 05:59 PM
thanks Rick
View HighRockWoodworking's profile
HighRockWoodworking
182 posts in 3179 days
#5 posted 05-20-2010 06:41 PM
Thanks Rick. Great review!
-- Chris Adkins, http://highrockwoodworking.com/
View CreekWoodworker's profile
CreekWoodworker
409 posts in 3498 days
#6 posted 05-21-2010 02:04 AM
Thanks Rick, I’ve had my eye on that product. I use a sanding stick to clean my DP sanding drums. The salesperson at Woodcraft told me they are made out of the same material as Hush Puppy shoe soles.
-- Mike ...Success is often the result of taking a misstep in the right direction
Rick S...
#7 posted 05-21-2010 02:13 AM
Thanks Guys: Your Comments are ALWAYS Welcomed and if further Clarification is needed I’m Pleased to do so.
Greedo: I’m not sure what you mean by “pad”. I’ll assume you mean the Sanding Disc. Do NOT wipe it with Turpentine. If you mean the actual CREPE Pad that sits in the base…. same thing. Turpentine will ”Eat” them both!! If you go to the Link at Lee Valley they will tell you everything about how it works and how it should be Cleaned. A CREPE Pad (AS Here) or a CREPE block when applied to a Moving piece of Sand Paper REMOVES the accumulated Imbedded Sanding Debri from the Sand Paper. Crepe can be cleaned, with Soap & Water, then left to dry. LINK To Manufacturers Instructions is HERE
RANCE: You’re right. they do. What you MIGHT be reffering to is MOST LIKELY (Not 100% Sure) a Crepe Block and some Tennis Shoes, in my case Squash Shoes do have Crepe Soles. I just found it to be a pain in the BUTT, putting them on and ”Running” all over my Sanding Stuff!! (Just Kidding). Lee Valley also has the Crepe Blocks. Link is HERE
Cessna: TERRIBLE?? Removes the reason for its existence? Not EVERYONE uses a Hose attached to there ROS. However, I have a Hose attached to mine also.
I made a QUICK little Jig to Solve that Apparent Problem. A piece of 3/4”” Ply, 6”x6” as a base. Then I Attached the Unit to the Wooden Base. Screwed a piece of 1/4” Ply to one side of the Wooden base, about 3” Wide, ran it up to a Height that allowed me to cut a Notch in it (about 2” down, with a rounded bottom) that you Sit the Hose in at a height that sits the sander in Perfectly Level with the Crepe Pad. You can also Attach the Unit as expained at Lee Valley by Screwing it to your Worbench or a Larger Piece of Wood to “Enlarge” the Base and thereby preventing “Tipping”.
Also as mentioned above and on the LINK there is a Small Screw under the Crepe Pad that allows you to Adjust the Amount of “Run On” to a Degree that is suitable for your use.
As for the “Cleaning Aspect”? I stand by what I said above. If Crepe works for your other Sanders why would it NOT work here. My Norton 3x’s Discs last a LOT longer than 10 minutes. I also find that even with my Very Powerfull Vac, it removes only a Portion of the Dust created. The “Imbedded Debri” needs a more “Aggresive” Approach. The Crepe does that. Perhaps that’s the reason your Pads don’t last as long as they should i.e. you’re depending on the Vac to do ALL the cleaning.
The ”Arm” you asked about is also explained on the Lee Valley Page. However…. That is the 6” Base. It’s intended to hold the Handle of a ”Barrel Handled” ROS’s as Shown in the Enlargment of the First Picture Above. The Arm is also Adjustable in Height.
I have the 5” Base and a 5” ROS. I don’t feel it would be appropriate for me to comment on the 6” base and if it does or does not work in a ”Tool Review” as I’ve never used it.
All I can say, once again is that I’ve had mine for 3 YEARS, (Test Of Time) I also bought an Extra Crepe Pad, but am Still Using the Original one, and I’m VERY Pleased with it!! Of course we all have are reasons for Liking or Disliking ANY type of Woodworking Tool.
Rick
PS: I have NO Finacial Ownership in OR Receive any type of Compensation From Lee Valley …LOL…
TopamaxSurvivor
18390 posts in 3876 days
#8 posted 05-27-2010 06:49 AM
Good info, thanks
