| Review by b2rtch | posted 1107 days ago | 2534 views | 1 time favorited | 28 comments | ![]() |
- Kreg precision fence
- Brand: Kreg | Category: Bandsaw Accessories
I went to buy this fence last Thursday to mount it on my HF band saw.
I mounted it Saturday and yesterday Sunday.
I am mechanic by trade and it is my job to make stuff work, no matter what.
Well, this fence was a challenge.
I was expecting an easy and straight forward installation, the installation was anything but——
The table had two threaded holes in the front which lined up with fixation holes in the fence but contrary to what it is supposed to be , when using these holes the fence did not clear the miter slot; it was way too high and the fence itself was seating a 3/8’ above the table.
After contemplating different routes to go , I decided to drill and tap two new holes but lower.
This is what I did.
Now the fence clears the miter slot but it seats crocked compare with the surface of the table.
If the fence touches the front of the table, it is now about 1/2” high in the rear.
I shimmed the front of the table so that the fence will be parallel to the table, it kind of work but this is mickey mouse and I do not like it.
The next step is to take the table out and to get front machined square with the top, not a huge issue but a pain in the rear nevertheless.
-- Bert
28 comments so far
dbhost
home | projects | blog
4748 posts in 1401 days
#1 posted 1107 days ago
You got pics?
FWIW, I HATE my Craftsman Professional fence on my HF Band Saw, but at least aligning it is a no brainer… Just had to make shims, and use their clamps (Would have been better off drilling & tapping some bolt holes, but oh well…).
Harbor Freight USED to sell a “prescision band saw fence” that has dropped out of the catalog in the last year. I should have grabbed that one…
b2rtch
2954 posts in 1217 days
#2 posted 1107 days ago
“Harbor Freight USED to sell a “precision band saw fence” that has dropped out of the catalog in the last year. I should have grabbed that one…”
I tried t get this one but very unfortunately it is no longer available.
-- Bert
PurpLev
7751 posts in 1817 days
#3 posted 1107 days ago
sounds more like an incompatibility issue with the HF bandsaw more than a faulty fence.
the Kreg fence description does say that it works with MANY bandsaws out of the box, and requires some modification to work with others. this one would be the “others”.
give us an updated review once you actually have experience with the fence as to how it performs :) and good luck with the installation. money saved, is work earned sometimes ;)
b2rtch
#4 posted 1107 days ago
” sounds more like an incompatibility issue with the HF band saw more than a faulty fence”
The issue is that the mounting surface for the fence, on the table, is not square with the top of the table.
-- Bert
PurpLev
#5 posted 1107 days ago
So if I understand you correctly, the problem here is the bandsaw’s own table that is not machined well enough right? this has nothing to do with the fence?
b2rtch
#6 posted 1107 days ago
Correct, unless I find more problems later.
If you notice , I did not say anything about the fence being the cause of my issues.
I wrote that I have issues installing this fence and not because of the fence.
-- Bert
williams
53 posts in 1186 days
#7 posted 1107 days ago
This is typical of things. Fences rarely square in all directions, only the working ends. Circ saw bases rairly parallel to blade, etc.
-- William, Brighton, MI
woodsmithshop
918 posts in 1714 days
#8 posted 1107 days ago
I installed this fence on a Taiwan made bandsaw and later on my Powermatic with no problems with either one, it has been a very good fence, much better than the fences that came with either saw.
-- Smitty!!!
tunk valley custom woodworks
133 posts in 1274 days
#9 posted 1107 days ago
i learned a loong time ago you buy from harbour freight you get what you pay for.nothing but junk.
-- i wonder if obama stood in a wind storm with them big ears of his would he start spinning like a drill bit
b2rtch
#10 posted 1107 days ago
I always have been very satisfied with what I bought at HF and I have been buying tools from HF for 20 years or so.
I went home tonight and I took the table out of the saw and I sanded the fence mounting surfaces square to the table on my Rigid sander .
Now everything is fine and the fence fits very well.
End of the story.
-- Bert
Enthalpy
44 posts in 1211 days
#11 posted 1107 days ago
Pardon my French…but you bought a 10$ saw and a 200$ fence????
b2rtch
#12 posted 1107 days ago
I am afraid you are wrong, I paid $100.00 for the saw and $127.00 for the fence.
By the way this very same saw is sold under different names for up to $800.00 (Jet)
-- Bert
ericandcandi
152 posts in 1687 days
#13 posted 1107 days ago
Good fence. I have one on my Delta and it works like a charm. Sorry to here you are having problems.
-- ericandcandi in Louisiana- Home of the "LSU Tigers"
b2rtch
#14 posted 1107 days ago
Thank you , the problems very easily fixed.
-- Bert
3808 posts in 2191 days
#15 posted 1107 days ago
I wonder if you had “clamped” the fence in place and then drilled the mounting holes if your problems would not ahve been less?
If I would not fit on the table when clamped in place you might have saved yourself a lot of grief.
View all comments »
showing 1 through 15 of 28 comments
