| Review by sIKE | posted 642 days ago | 1527 views | 2 times favorited | 15 comments | ![]() |
- Harris International Labs Evapo Rust
- Brand: Harris International Labs | Category: Other
I posted up a project about refinishing an old plane and Mark Mazzo refered to a product on his sites blog for removing rust. In my best Hank Hill voice…I tell you what. This stuff just works! I had to let it soak for a couple of days but man, all I had to do was rinse off the pieces then lightly use a stainless still brush to remove the remaining paint. I have used navel jelly, wire wheels, WD 40. They all pale greatly in comparison. If you have something small that is heavily rusted and can be submerged this is what you want.
15 comments so far
Blake
home | projects | blog
2763 posts in 773 days
posted 642 days ago
Wow, very interesting. I come across small hand planes and other metal tools all the time that I don’t know what to do with. Thanks for the review. I will definitely try this! Is it easy to find and readily available at a hardware store or where do you have to order it from?
GaryK
9539 posts in 887 days
posted 642 days ago
That’s what I was going to ask. Where do you get it?
sIKE
1094 posts in 652 days
posted 642 days ago
I found it at Autozone. The website is www.evapo-rust.com
cajunpen
5968 posts in 964 days
posted 642 days ago
Sounds like a magic elixir – if it works as good as you said, it will make a great addition to the arsenal of needed supplies for cleaning and grooming the tools.
Zuki
1234 posts in 976 days
posted 641 days ago
I believe that LV also carries it. It is also pretty environmentally friendly as well.
scottb
3402 posts in 1225 days
posted 641 days ago
... and it’s fairly environmentally friendly too? Awesome. Thanks for sharing this magic elixer!
25806 posts in 1299 days
posted 641 days ago
You betcha. Thanks for the posts.
jcees
553 posts in 697 days
posted 641 days ago
Lee Valley also carries it in their new catalog.
always,
J.C.
-- "Imagination is more important than knowledge" -- Albert Einstein
rikkor
11335 posts in 773 days
posted 641 days ago
I went to two different AutoZones to get some. Neither person I talked to was aware of it, but the store had it. I wanted a gallon, but the largest size they carried was a quart.
USCJeff
901 posts in 967 days
posted 441 days ago
I’ll have to give this a shot. I messed up and left a benchtop scrollsaw in my apparently not so moisture free car trunk for a few weeks. Naturally, the top is very much in need of some TLC. Haven’t tried any other method yet. Suppose I should give the old WD-40 a shot as it’s on hand. I wonder if this is a decent chemical for small carbide bits and blades. Always worth a shot in battling rust in South Carolina. My garage shop might as well not have walls with our humidity.
-- Jeff, South Carolina
Dick, & Barb Cain
7045 posts in 1198 days
posted 278 days ago
I asked these questions on another thread.
I got my answer here.
Does the temperature affect the use of it?
Do you wash it off with a water hose?
sIKE
posted 278 days ago
I normally pull it out and just let it dry, as it seems to prevent the flash rusting. Once I am done re-working the metal I wash it off with soap and water and then immediately move to the finishing process.
Once the stuff gets nasty I do rinse and then dunk into clean solution.
PurpLev
2763 posts in 547 days
posted 115 days ago
Thanks, needed that. gonna go pick some up at autozone.
17063 posts in 476 days
posted 115 days ago
This is great stuff
sIKE
posted 115 days ago
Sharon,
You will be very pleased with how easy this stuff works.
