| Review by scopemonkey | posted 1166 days ago | 2224 views | 0 times favorited | 19 comments | ![]() |
- Rockler Bench Hold-Down Clamps
- Brand: Rockler | Category: Clamps
I bought these bench hold fasts from Rockler. One moderate tap with my mallet and it broke. I had another one, same issue. Extremely poor quality and not worth a cent. I expect better from Rockler than this PoS. I think the Taiwan stamp says it all.
-- GSY from N. Idaho
19 comments so far
dbhost
home | projects | blog
4743 posts in 1430 days
#1 posted 1166 days ago
I bought the Workbench Accessory set from them, and use them rather abusively one day with no issue. The next day I went to lightly tap it in place and it broke in exactly the same spot.
I called Rockler Customer service and they sent me a pair of holdfasts that are a darker blue color, and feel quite a big heftier (I have not put them on the scale to make sure).
I agree. Rockler should be embarassed that their name is associated with this junk.
Routerisstillmyname
605 posts in 1707 days
#2 posted 1166 days ago
made in china at the harborfreight factory most likely.
Thanks for the warning.
-- Router è ancora il mio nome.
PCM
124 posts in 1243 days
#3 posted 1166 days ago
This is not only inexcusably poor quality, but potentially dangerous. Rockler should recall this product.
JJohnston
1401 posts in 1489 days
#4 posted 1166 days ago
That has all the look of a brittle fracture, and that says “cast” to me. I thought these were supposed to be forged. Next set you buy, try to make sure they are.
-- My broker promised me he would treat my money as if it were his own. Trouble is, he did.
jerryz
164 posts in 1476 days
#5 posted 1165 days ago
Holdfasts should be made of steel that has been tempered, it should be springy, those pictures show a metal that was hardened but they did not anneal it afterwards.
The cristalline structure is coarse and therefore prone to cracking.
Also the break point is consistent with the exact point where you would expect the maximum stress for that particular application.
By the way that is a quality control issue, they painted the holdfast, it is important as the annealing process consists of heating the piece at a certain temperature dependent on the steel alloy that was used and let it cool to room temp over a pre-set time. You would paint the pieces after this process not before…
The tempering of the steel is taking the piece again to a set temperature (dependent on the alloy used) and rapidly cooling it by quenching it in water or oil….
Cast iron will never work for a hold fast, it is not springy at all due to the cristalline structure of it..
live4ever
980 posts in 1208 days
#6 posted 1165 days ago
This probably explains why their workbench accessory set is discounted 50% right now. 2 of these holdfasts, some dogs, and a rubber mat for $12. I was going to order it but after seeing this not so sure anymore. Thank you for saving me the headache.
richgreer
4472 posts in 1272 days
#7 posted 1165 days ago
I had exactly the same experience with these hold down clamps. They are worthless. I bought mine about 3 years ago. If Rockler is still selling them, they should be ashamed of themselves.
Chris Pond
63 posts in 1245 days
#8 posted 1165 days ago
Hello, I saw this and thought cheap casting but also me with a un-heat shop could this be a problem in waiting? Thanks for the heads up.
-- Chris, Summerland BC
Greg The Cajun Box Sculptor
3833 posts in 1506 days
#9 posted 1165 days ago
Usually Rocckler sells some good stuff..I have bought frequently from them some good products and some bad… but these are garbage. But people can get them now on sale for 50% off to help rockler pay for their bad merchandise clearance.
I would call them and ask for a refund. Usually they are pretty good about repalcements or refunds…most of the time.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
bigike
4021 posts in 1486 days
#10 posted 1165 days ago
dam to think i was gonna buy these too thanks for the review! sorry you had to go through the poor quality tools to post, but i guess it helps us.
sparky52
6 posts in 1218 days
#11 posted 1165 days ago
I quite buying anything from Rockler. If I want crap I go to harbor freight.
-- Amateure wood worker,I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Hawkins
5 posts in 2025 days
#12 posted 1165 days ago
Same thing happened to me. Bought the Gramercy ones from “Tools for working wood” and they are amazing. However Rockler was very good about the refund.
scopemonkey
182 posts in 2361 days
#13 posted 1165 days ago
I am sad to see that I am not alone, but glad some of you won’t suffer the same mistake I did. I am going to try to get a replacement of refund from Rockler on Monday.
Jon Spelbring
199 posts in 2451 days
#14 posted 1164 days ago
Another vote for the Gramercy ones – they’re excellent!
-- To do is to be
PurpLev
7819 posts in 1846 days
#15 posted 1164 days ago
Another one for Gramercy… they are really not that much more expensive, but nothing on the market can come close to their quality – seriously.
View all comments »
