Best kept cleaning secret
Review by Routerisstillmyname posted 04-04-2010 02:01 AM 3552 views 0 times favorited 24 comments Add to Favorites Watch
Best kept cleaning secret Best kept cleaning secret No-picture-s Click the pictures to enlarge them
Stop wasting your money on those so-called cleaners that require you to mortgage your tools just to get few ounces of water and soap in a fancy package.
EASY-OFF has been around a long time with a proven track record.
It comes in several different skin removing flavors and I guarantee you’ll be amazed at the results.
It’ll make your saw blades; router bits, forstner bits and anything that can’t be recognized anymore look like it’s brand new.
Oh yeah, make sure you wear gloves.
-- Router è ancora il mio nome.
View Routerisstillmyname's profile
Routerisstillmyname
763 posts in 3745 days
24 comments so far
View Dyidawg's profile
Dyidawg
51 posts in 3249 days
#1 posted 04-04-2010 02:35 AM
Sounds good…...maybe my wife could help me out with this.
-- Wow, that was easy. Just follow the directions and use some common sense.
View NBeener's profile
NBeener
4816 posts in 3410 days
#2 posted 04-04-2010 02:52 AM
At least one blade manufacturer—Freud—specifically recommends AGAINST using oven cleaner to clean table saw blades. IIRC, it slowly breaks down the brazing, leaving the carbide tips vulnerable to flying off—an unqualified Bad Thing.
I’ll stick with WD40, simple green, citrus degreaser, Lestoil, or … almost anything else.
My $0.02.
YMMV…..
-- -- Neil
View AaronK's profile
AaronK
1507 posts in 3700 days
#3 posted 04-04-2010 04:11 AM
i used a short soak in hot water followed by barkeepers friend with nylon bristle brush and it got my gunked up junker looking good as new.
AaronK
#4 posted 04-04-2010 04:11 AM
ie, the less skin removed the better! a general goal in woodworking and life :-)
View Tim_456's profile
Tim_456
172 posts in 3831 days
#5 posted 04-04-2010 04:17 AM
I used easy off once and it worked great, until I read about it breaking down the brazing and sending the carbide tips flying like shrapnel. I’ve since moved to simple green which works just as good enough;)
Beener’s right, you probably want to avoid this. I don’t have any data (such as shrapnel in my head) to back up that claim, but I prefer to be safer than sorry;)
Routerisstillmyname
#6 posted 04-04-2010 04:18 AM
NBeener, That’s good to know. thanks for the warning. what a shame.
Oh well, back to hot water and soap and nylon bristle brush and wd40.
Routerisstillmyname
#7 posted 04-04-2010 04:24 AM
I’ve heard bad things about simple green.
View bigike's profile
bigike
4055 posts in 3524 days
#8 posted 04-04-2010 04:26 AM
sounds good but do u have proof like pics of before and after?
Routerisstillmyname
#9 posted 04-04-2010 04:29 AM
Before and after cleaning pics or carbide tip flying off ?
NBeener
#10 posted 04-04-2010 04:58 AM
A little more info ….
http://www.woodbin.com/misc/sawblade_cleaning.htm
Simple Green—with a quick soak, scrub, and rinse, seems pretty darned okay.
I would recommend against long-term (let’s say …. overnight, to be safe) soaking of blades in almost anything that might clean it.
Simple Green has a bit more info, here
Some have even recommended that you go right past the original Simple Green, and—instead—use their Extreme Simple Green® Aircraft & Precision Cleaner, but … not only have I never SEEN the stuff … I’m just not going to bother ;-)
I soak for a few minutes, in a dilute mixture of the original SG, and then scrub with a nylon or brass-bristle brush.
Works fine.
More info … INCLUDING word FROM the horse’s (Freud rep) mouth … here
-- -- Neil
Routerisstillmyname
#11 posted 04-04-2010 05:26 PM
Well, if it’s not safe on saw blades and router bits, It’s safe for table saw cleaning.
View poopiekat's profile
poopiekat
4405 posts in 3970 days
#12 posted 04-04-2010 05:48 PM
Easy-Off is just lye, isn’t it?
View Jim Bertelson's profile
Jim Bertelson
4256 posts in 3400 days
#13 posted 04-04-2010 06:05 PM
All
The final word by the Freud rep was soak in kerosene, and scrub with a plastic bristle brush. I think the closest thing I have to kerosene is WD40. Haven’t I heard that mineral spirits would do the trick too?
-- Jim, Anchorage Alaska
Routerisstillmyname
#14 posted 04-04-2010 06:05 PM
lye is used in oven cleaner and drain openers..So I cant’ use this for cleaning table saw either? I give up ;-(
Routerisstillmyname
#15 posted 04-04-2010 06:09 PM
Ok, who and where is this Freud rep everyone’s talking about. did they spray the saw blade and leave it set there over a month or something..heck, that would dissolve anything let alone brazing.
showing 1 through 15 of 24 comments
