3M™ SandBlaster™ Flexible Abrasives
Review by leonmcd posted 288 days ago 300 views 0 times favorited 3 comments Add to Favorites
View leonmcd's profile
leonmcd
177 posts in 511 days
3M™ SandBlaster™ Flexible Abrasives No-picture-s No-picture-s Click the pictures to enlarge them
I just discovered these and used them on my Valentine’s Box 2008 project. Because of the small size of the box and the rounded bottom made by the bowl/tray router bit, I needed something flexible to follow the curves. I also need something that I could agressively work some problem areas left by the router.
My regular sandpaper didn’t seem agressive enough and foam backed sanding pads are too stiff on the sanding surface to smoothly follow the tight curves. These pads are much more flexible on the surface than the standard foam backed. They also have a lot of bite. I worked my biggest problem areas with the 120 grit and it really cut through the material.
I liked these a lot. Flexible and fast cutting.
-- Leon -- Houston, TX - " I create all my own designs and it looks like it "
3 comments so far
View gizmodyne's profile
gizmodyne
1486 posts in 630 days
posted 288 days ago
I love these too. I use the 320 for sanding finishes.
9950 posts in 362 days
posted 288 days ago
I have never used these but will have to try them. Thanks for the post.
View sharad's profile
sharad
384 posts in 344 days
posted 287 days ago
Thanks for the new information. Will be useful one day
Sharad
-- patanjali
Bookmark And Share This Page
