| Review by JJohnston | posted 178 days ago | 1618 views | 0 times favorited | 12 comments | ![]() |
- . "Lumber core" plywood
- Brand: . | Category: Other
I thought I’d try a new (to me) product I found at my local “good” lumberyard – “lumber core plywood” – to build a few utility-grade shop projects. It’s made of solid lumber pieces laminated with thin face veneers. The core pieces are tongue-and-groove joined along their edges, which you can see in the first picture (if you can’t make out the part in focus, look below and to the right at the piece in the clamps. You can see the contrast between a light and a dark piece).
This seems great at first glance, but there’s a problem: only the pieces on the edges are the full length of the sheet. The interior pieces are of random lengths, and the ends are simply butted – there are even little gaps. See the second picture with a utility knife for scale. This edge is parallel to the long dimension of the sheet. The edge below it is the factory edge, which looks continuous and beautiful.
This construction method SERIOUSLY compromises the bending strength. The piece in the second picture was going to be a shelf, but with those two gaps, which are typical, I have serious reservations about using it – in fact, I’m not going to. Since the core pieces are of random lengths, and are edge-jointed, the problem isn’t so bad on a wide piece (more continuity), but it gets worse as you rip it narrower. About the only suitable application I can see for this material is as big pieces subject to edge-to-edge compression, like sides for a base cabinet or a cabinet-style bench.
There is one upside: it’s light, probably because it isn’t all soaked through with glue, like conventional plywood.
-- Measure twice, then try to figure out which one was right.
12 comments so far
live4ever
home | projects | blog
289 posts in 193 days
#1 posted 178 days ago
Timely post. Lumbercore ply is making a comeback – all the orange BORGS in my area have started stocking it in 1/4 sheets. It is very light, and I suspect you may be right – it won’t be as high quality as the lumbercore ply of old, with possibly much less bending resistance.
And at $15 per 24×48” sheet, the borg version is not exactly cheap.
JJohnston
605 posts in 474 days
#2 posted 178 days ago
This was $40/sheet for 3/4”.
Dusty56
4928 posts in 871 days
#3 posted 178 days ago
It appears to be Pine used for the core from here , which might explain the light weight …Possibly Radiata Pine
I’ve seen some that also resembled Mahogany in color and texture as well. Back in the 80’s , the Lumber Core plywood that I handled was a hardwood ,fingerjointed core and at the very least they used Poplar. Either way , the plywood should have to meet strict codes and should have a stamp on it on the lesser face or the edge if it is finish grade plywood.
-- When my Grandmother became 60 years old , she started walking 5 miles a day...She's 97 now , and we have no idea where she is ! Ellen Degeneres
sdmref
6 posts in 390 days
#4 posted 178 days ago
Did anyone notice that the manufacturer used wood with the pith included in the core? How dimensionally stable is that? They need to be called out on their processes. Its one thing not buy it, but another to let them know why we won’t buy it.
shopguryl
328 posts in 180 days
#5 posted 178 days ago
Plus, look how wide the filler pcs are.
Quality lumbercore of the day I believe was made with boards only around 2” wide. I never saw any with pine, maybe spruce though.
-- A craftsman IS what their tools AIN'T !!!
Chris Wright
473 posts in 664 days
#6 posted 178 days ago
The maple lumber core I’ve got in my shop is pretty good, and it’s pretty heavy. And a lot more expensive.
-- "At its best, life is completely unpredictable." - Christopher Walken
araldite
167 posts in 587 days
#7 posted 178 days ago
Thanks for the education. I’ve never seen it before but now I’ll know what it is and avoid it when it pops up in my store.
-- Failure is the road to success if you learn to learn from your mistakes - Vince, Greenville, SC
489tad
39 posts in 194 days
#8 posted 177 days ago
Thanks for the info. You’ll have to a strong edge with a groove to make that piece usefull.
-- I.G.N.
FunnelStudio
30 posts in 501 days
#9 posted 177 days ago
I thought the great thing about standard, multiply plywood was that it was fairly more sustainable, what are the benefits of this material?
-- -Shaun M. Baer, http://www.craftedphiladelphia.com
308Gap
97 posts in 186 days
#10 posted 177 days ago
Whats the outside veneer like?
3/4 or 23/32 ?
-- Thank You Veterans!
Dusty56
#11 posted 177 days ago
FunnelStudio….You can put screws / hinges into/onto it on the edges for doors etc….And it is supposed to be more ridgid for shelving and panels etc..
JJohnston
#12 posted 177 days ago
It’s more rigid only if all the core pieces run the full length of the sheet, and that’s the problem with this stuff. Each face has two thin veneer layers, one transverse and one longitudinal. It’s pine, grade B on both sides. It’s 23/32.
