10 piece Router Template Guide Set
Review by Dick, & Barb Cain posted 03-11-2010 03:46 PM 6754 views 3 times favorited 12 comments Add to Favorites Watch
10 piece Router Template Guide Set No-picture-s No-picture-s Click the pictures to enlarge them
I have had this set for quite a few years now, & I highly recommend this set.
It comes with an adapter, so if you want to make your own router plate, or table,
it will be 100% accurate if installed correctly.
The fine threaded nut makes for easy hand tightening, & I’ve never had them come loose.
Fits any router that accepts standard 1-3/16” OD threaded guide bushing
Machined solid brass construction
Includes 7 template guides: 1/4” ID x 5/16” OD; 9/32” ID x 3/8” OD; 11/32” ID x 7/16” OD; 13/32” ID x 1/2” OD; 17/32” ID x 5/8” OD; 21/32” ID x 3/4” OD and 5/8” ID x 51/64” OD Plus 2 lock nuts and adapter
1.25 mm threads
20 threads per inch
ITEM 95160-2VGA
-- -** You are never to old to set another goal or to dream a new dream ****************** Dick, & Barb Cain, Hibbing, MN.
Dick, & Barb Cain
8693 posts in 4232 days
12 comments so far
View Woodwrecker's profile
4128 posts in 3508 days
#1 posted 03-11-2010 03:58 PM
Thanks for the tip Dick. That’s something I can actually afford!
-- Eric, central Florida / Utor praemia operibus duris
35112 posts in 4333 days
#2 posted 03-11-2010 04:41 PM
Thanks Dick: I have that set also, I question the length of some of the adapters and have hads to grind some of mine a little shorter because the template was not as thick as the guide was designed for.
Overall a great set.
-- I've been blessed with a father who liked to tinker in wood, and a wife who lets me tinker in wood. Southern Delaware soon moving to Virginia †
Dick, & Barb Cain
#3 posted 03-11-2010 04:57 PM
You’re welcome Eric.
I think I only paid about $12.99, it was so long ago.<(;O}#
I had to shorten up some of mine also for the application I needed them for.
View Tony's profile
983 posts in 3962 days
#4 posted 03-11-2010 06:50 PM
$19.99 for this set sounds pretty good – just wish we had a HF or that they would ship internationally. – thanks for posting the information
-- Tony - All things are possible, just some things are more difficult than others! - SKYPE: Heron2005 (
View rwyoung's profile
409 posts in 3404 days
#5 posted 03-11-2010 06:54 PM
+1 on this set, especially when it goes on sale or you have a 20% off coupon. Having more than one set is a good idea because you can grind down the length as Karson suggested and have a lot of choices when you need a bushing.
The one thing missing from the kit is a centering cone but those are pretty easy to make or you can use a dovetail bit as a makeshift centering cone.
-- Don't sweat the petty things and don't pet the sweaty things.
Dick, & Barb Cain
#6 posted 03-12-2010 01:04 AM
It’s a pretty good deal isn’t it?
I’ve been thinking of getting another set.
View TemplateTom's profile
93 posts in 3213 days
#7 posted 03-12-2010 01:44 AM
One of the problems I have with not only this set but other makes as well; the largest guide will limit the number of cutters that can be used. Most people would use the guides with a straight cutter inserted; where most of the cutters I wish to use are Face/Edge cutters and one in particular was 32mm wide, where the majoriiy are 25mm wide
-- Getting more from my router with the aid of Template Guides Selection of Projects listed on You -Tube "Routing with Tom O'Donnell"
View bigike's profile
4053 posts in 3221 days
#8 posted 03-12-2010 02:18 AM
i need one of these thanks for the review
-- Ike, Big Daddies Woodshop,
View bake's profile
384 posts in 3610 days
#9 posted 03-14-2010 04:19 AM
I bought one to use with my dovetail jig. It worked great, seems like a good addition to any router.
-- I love the smell of Home Depot in the morning, it smells like.......carpentry. Bake, Bar Lazy U Woodworks, Lehi,UT.
View Abbott's profile
2570 posts in 3236 days
#10 posted 03-14-2010 05:42 AM
Ya, I also like this kit.
-- Ohh mann...pancakes and boobies...I'll bet that's what Heaven is like! ♣ ♣ ♣ ♣
View Broglea's profile
684 posts in 3023 days
#11 posted 04-27-2010 04:36 AM
Got them for Christmas. Love them.
View Pinkylabmouse's profile
8 posts in 762 days
#12 posted 05-31-2016 07:52 PM
I am having a problem concerning the Harbor Freight template guides, or my ineptness, I suspect it is my ineptness.
Never having used a Router before, I purchased the HB guide set and installed. I did use a centering pin and everything looked copacetic. (Copacetic? I’ve been working around navy guys for too long.)
Anyway, I had a 3/4” plywood pattern and was cutting 3/4” plywood (Bases for a Paulk Miter Say station, see Youtube). I cut a couple of the large bases and then the router bit ate the template guide. The ring that holds the template guide was loose. Was the ring loose because the bit ate the template guide or did the ring come loose and cause the bit to eat the guide? I don’t know.
I went back to HB and bought a 2nd set of guides. This time I centered the guide and torqued the ring that holds the guide in place to “Tim the Tool Man specifications”. Within 12 inches of routing the bit ate another guide.
Is it possible that I didn’t have the bit deep enough in the collet and the bit deflected enough to grab the guide?
The bit is a 1/2” shank with 1-1/2” cutting surface, which is also 1/2” in diameter.
