Oneway Wheel Balancing System
Review by Padre posted 03-03-2010 11:18 PM 5023 views 1 time favorited 7 comments Add to Favorites Watch
Oneway Wheel Balancing System No-picture-s No-picture-s Click the pictures to enlarge them
I bought this Oneway Wheel Balancing System from Craft Supplies, it cost 62.99. I do a lot of wood turning tool sharpening. I have an inexpensive 2 speed grinder I bought from Woodcraft and it rocked, rattled and rolled, that’s for sure!!
I put this on this afternoon, and you would think I have a Baldor grinder with special balanced wheels. What a difference this has made.
I recommend this grinder attachment.
-- Chip -----------http://www.penmanchip.com-----------------Micah 6:8
View Padre's profile
Padre
930 posts in 3392 days
7 comments so far
View grub32's profile
grub32
213 posts in 2951 days
#1 posted 03-03-2010 11:36 PM
Chip…Some valuable info…Lots of us turners have that same grinder from the WC. I will definitely have to look into that.
Thanks,
Grub
-- Science Teacher by Day, Wood Butcher by Night!!
View dbhost's profile
dbhost
5686 posts in 3135 days
#2 posted 03-04-2010 12:19 AM
How does this work? I need to stop the shakes from my grinder that popped up when I swapped out the cheapie OEM wheels with a set of Norton Aluminum Oxides… I was thinking about springing for the Geigers Dressing and Truing solution, but want to make sure I am making the right choice…
-- My workshop blog can be found at http://daves-workshop.blogspot.com, YouTube Channel https://www.youtube.com/channel/UCoa-AgyeFWqnQfGIJwdzkog
Padre
#3 posted 03-04-2010 12:25 AM
It it really kind of simple. The outer wheel has a groove in it. Into the groove you put 3 nuts, and then from the front you screw in a screw with a washer. Then you move these three nuts/washers/screws around until the wheel is completely balanced. The kit comes with its own balancing stand with ball bearing bearings on it. It took me about 10 minutes for each wheel because it’s the first time I did it. Next time it will be a lot faster!
It is really good, I just went out and sharpened my bowl gouge, and the difference in the ‘shakes’ is unbelieveable.
View bigike's profile
bigike
4053 posts in 3191 days
#4 posted 03-04-2010 01:41 AM
thanks for the review, i wanted to get one but was unshure untill now. THANKS
35099 posts in 4303 days
#5 posted 03-04-2010 02:16 AM
Sounds like a great system.
View John Gray's profile
John Gray
2370 posts in 3788 days
#6 posted 03-04-2010 05:22 PM
Chip,
Thanks for the review!!!! I’ve been looking at these balancers and your post has given solid advice toward a purchase.
John
View lepelerin's profile
lepelerin
490 posts in 2228 days
#7 posted 09-24-2012 09:18 PM
kind of an old post, but I have the same, It makes a huge difference, Night and day.
I found a dead variable speed bench grinder (0-3600 rpm). I spend time fixing it, works great now. I made a clone of the Veritas grinding tool rest jig. My chisel are sharp!
