| Review by Dave | posted 194 days ago | 593 views | 1 time favorited | 6 comments | ![]() |
I have a Delta 10” Compound Mitre saw. I bought the Freud LU88 saw blade for my Craftsman table saw a couple weeks ago, and WOW, what a difference it made when I cut some test pieces. Buying the LU88 was a HUGE step up for me, and I really noticed the improvement on my cross-cuts. Nice and smooth, hardly bogged down at all (Craftsman 10” 2.5hp TABLE SAW) on 3/4” oak, at least not like my old blade. My question is, will the LU88 blade also work in my compound mitre saw ? Thinking about getting another one of these LU88 blades, or is there one better for a compound mitre saw.
Dave
-- You gotta laugh a little...
6 comments so far
Dave Herron
home | projects | blog
210 posts in 221 days
posted 193 days ago
For a miter saw or radial arm saw I’d look at a blade in the LU91 series. These blades have a negative hook angle which give you a little more control.
http://www.freudtools.com/p-20-thin-kerf-sliding-compound-miterbr-nbsp.aspx
-- Dave Herron, Boise, ID -- How hard can it be? It's only wood!
Dave
23 posts in 221 days
posted 193 days ago
Dave,
Thanks for your post.
My comp mitre doesn’t have the sliding feature. Is this still a good choice for non-sliding saws ?
Dave Herron
posted 193 days ago
I’d mount the blade you have on the miter saw and see how you like it. If you don’t have a sliding miter saw then you could run just about any blade.
Dave
posted 193 days ago
Guess I don’t know enough about sliding mitre saws to understand why, but I do know I’m no expert.
I also posted the question in a forum, I think my post here is in the wrong place.
Thanks Dave, I’ll give that a try.
USCJeff
791 posts in 511 days
posted 191 days ago
While I’m no expert on the physics of the sliding miter action versus the chop action, I would think that the angle of the teeth would be a factor. The sliding action is being pushed through the width of the board, whereas the pivoting chop action is being pushed down through the board. This might make little difference, however. I’m stationary, so I couldn’t say. I’m using a Dewalt stock crosscut blade on the miter as this is what it does. Works well. All mitersaws will have a degree of runout compared to a tablesaw. I use a Freud Combo TK blade on the TS for most applications. I have a plywood blade that is great, but doesn’t get used unless I’m doing a ton of plywood. Good experieces with Freud. Love to try the Glue-Line blades.
-- Jeff, South Carolina
Dave Herron
posted 191 days ago
Negative hook blades reduce the chances of grabbing or overfeeding on radial arm and sliding miter saws. Gives you more control.
