worksharp 3000
Review by degoose posted 1211 days ago 7352 views 2 times favorited 29 comments Add to Favorites Watch
worksharp 3000 No-picture-s No-picture-s Click the pictures to enlarge them
I know that there have been a few reviews of this sharpening system… but I got one a while back and I just wanted to review it and let all my fellow Aussies that it is available here now..
This is the easiest way to keep your hand tools…. chisels and plane irons … sharp… Also great for turning tools and carving chisels… curved as well as straight..
“Work Sharp” is an innovative grinding & sharpening system for sharpening Chisels, Plane Blades, Scrapers, Axes and much more with speed & precision. Work Sharp offers 3 easy ways to grind and sharpen: The Chisel and plane iron port, freehand on top for larger flat blade tools, and the Edge-Vision port, which allows you to see the cutting edge of carving tools, lathe tools and more as you sharpen or grind. The 2 sided grinding wheel allows you to quickly and easily switch between coarse and fine abrasive disks.
I had been looking at the Worksharp sharpening system for some time… on the web… I had read every review and watched every video… over and over again. Every one of these reviews was favourable and many of my friends on Lumberjocks have one and have commented on them… I knew i wanted one but it was pointless trying to import one into Australia… different voltage..oh well..back to sandpaper glued to a granite slab..I had even tried all the jigs and stones… but I am not really into all the work that is required… I am after Lazy Larry…as for the water wheels… either they are messy or terribly expensive.. Even though the Worksharp 3000 is a little on the costly side the speed and proficiency of the machine in sharpening all tools with minimum effort makes this worth the money..
And then lo and behold I was looking again and saw that they were being imported into Australia… Industrial Tool & Machinery Sales are Importers & National Wholesalers of a wide range of quality engineering machinery & equipment. So I went to their website and could not find any resellers or prices… So I rang them up to find out where I could buy one of these machines..and how much one would set me back..
.After talking to one of the guys at Industrial Tools, I decided that as a small shop I should probably get the Workshop 3000.. it has a few features not available on the 2000 which is still a great little machine in its own right. At 10 o’clock the very next morning a big courier truck arrived at my workshop with a big box… the Worksharp 3000 was here..Inside the large box was the machine itself, a wide blade attachment for plane irons larger than 2 7/8 inch and all the accessories… 2 glass wheels to atttach the self adhesive sandpaper … a different grit on each of the 4 sides.. a slotted plastic wheel and slotted paper for under the wheel sharpening…curves chisels and gouges…plus several sheet of various grit sandpaper.. and a replacement sheet for the sharpening port.. You can see the ins and outs of this machine on the video
but I will be making a short video when I get my camera.. Just to show how a bloke like me can get chisels scary sharp fast and easily with little if no effort…in almost no time at all…I got one of my trusty rusty old bought at a flea market chisels and after less than 10 minutes had flattened the back and sharpened the chisel so sharp I could shave the hairs on my arm… and it had a mirror finish..and I did not have to do much… the machine seemed to do all the work for me…Just had to turn over the glass wheels a few times and voile done… next came a near new chisel which took so little time to bring it up to par I was really amazed.
-- Drink twice... and don't bother to cut... @ lazylarrywoodworks.com.au For lovers of all things timber...
View degoose's profile
degoose
6620 posts in 1552 days
29 comments so far
27253 posts in 2019 days
#1 posted 1211 days ago
This is a nice review, Larry. Until I got mine I struggled with getting a sharp edge on my chisels and irons. To me it is the next best thing since sliced bread.
View woodworm's profile
woodworm
14105 posts in 1788 days
#2 posted 1211 days ago
I’ve been reading a lot of reviews on this decent sharperner., and mostly or almost all gave a thumb up judgment. However due to motor voltage & frequency issue, I put on hold my decision to buy one. Now I’m in dilemma of choosing between Tormek T-3 Water Cooled Sharpening System and Worksharp 3000. So I’ll be gathering more plus & minus points for these two syatems before I finally make decision.
Thank you Degoose.
-- masrol, kuala lumpur, MY.
View richgreer's profile
richgreer
4472 posts in 1272 days
#3 posted 1211 days ago
Good review – thank you. I have a one of these and I agree completely that it is a great way to sharpen chisels and irons.
I will disagree with you on one minor point you made. I do not think this tool is great for curved turning tools (i.e. gouges). There is no way to maintain a consistent bevel with a curved tool. I don’t think it would be very hard to make an accessory for the worksharp that would enable one to sharpen curved tools well. Maybe someone will do that some day.
12169 posts in 1538 days
#4 posted 1211 days ago
ay mate ,
just got me one too .
must say ,
it’s the dingos dingus !
all me tools is SHARP now !
Beginningwoodworker
13238 posts in 1870 days
#5 posted 1211 days ago
Thanks for the review.
-- CJIII Future cabinetmaker
#6 posted 1211 days ago
the one thing not mentioned anywhere ,
when i do the first sharpening ,
it takes more to bring it to square ,
i noticed that if you push to much ,
it makes
steel wool , that can spark .
keep it away from open sawdust .
after the initial sharp ,
there is no problem with this ,
just do as they say ,
don’t hog it !
View Kent Shepherd's profile
Kent Shepherd
2693 posts in 1483 days
#7 posted 1210 days ago
Great review Larry
Thanks
View GaryBuck's profile
GaryBuck
268 posts in 1423 days
#8 posted 1210 days ago
Hey Larry thanks for the post. I was impressed by this set up and I realize it’s for hand tools but was wondering if they have an attachment for saw blades? And it showed using plane blades can you do something larger like a lawn mower blade on this just to get the nicks and such out? And what’s the price for one? Thanks
GaryBuck
#9 posted 1210 days ago
I use my grinding wheel for the lawn mower blades but was just courious on that part
View mikethetermite's profile
mikethetermite
367 posts in 1463 days
#10 posted 1210 days ago
Great review, looking forward to your video review Larry.
-- Mike The Termite ~~~~~ Working safely may get old, but so do those who practice it.
View reggiek's profile
reggiek
2236 posts in 1467 days
#11 posted 1210 days ago
Cool…Larry…glad to hear you guys down there are finally coming into the 21st century….J/K. Great review…I wanted to mention that this month’s Woodcarving Illustrated has a great article on various sharpening systems…and a good one on sharpening tools….I like and use diamond stones myself…but I hear that they have a diamond wheel for the worksharp now? I don’t know if I can change my spots after many years of manual sharpening (I haven’t joined the 21st century either)...but they are getting close to making a machine I might be comfortable with.
degoose
#12 posted 1210 days ago
Gary, around US$200 in the states but AU$600 there abouts over here… but then everything that come across the pond is dearer here.. Still and all not bad to get the tools sharp.
GaryBuck
#13 posted 1210 days ago
I was shocked by the way it cut across grain like that pretty impressive there it made it look like cutting butter, what about an attachment for like T.S. or skill saw blades is there away of doing those on that? Thanks
View Gary Fixler's profile
Gary Fixler
1000 posts in 1579 days
#14 posted 1210 days ago
I’ve had good luck with mine, too. I’ve had it for about a year or so. My biggest trouble up front was that I couldn’t get it square. There’s a way to tilt the ramp you slide chisels into up and down around one edge. I had to set it all the way to one end, and it still seemed just a hair off square. It’s good enough that I don’t really notice anymore, but I wanted to be able to adjust around square, not have to fight up against the edge of the range. I couldn’t find a way to adjust more. There weren’t any things to shim or loosen and tap with a hammer.
Too, as was said before, too much aggressive sharpening will create a kind of steel wool under the wheel in a pocket in the back. I had this catch fire. It’s beautiful to watch, but super hot. Don’t sharpen around flammables or wood dust. The wool fire isn’t so much an open flame as it is an ember that ripples all through the wool like a cooling lava line. Again, pretty, but frightening.
I’ve gotten halfway decent at sharpening curved tools, like bowl gouges under the slotted wheel, which you can see through (better if you shine a bright light down through the slots from above. Oh, and as for the “without losing momentum” statement – quite true. I was filming a time-lapse of some work, and the chisel I was using was dull, so I just walked over to the unit, turned it on, pushed the chisel in a few times like I was sharpening a pencil, and came back to the video I was making probably 30 seconds later. I keep it plugged in and ready to go all the time.
Final note: I’ve used this to bring back a rusting chisel with a point not only very dull, but chipped and badly pitted with little bites taken out of the whole tip. It took a little while, but I have 2 glass wheels with a grit on each side, so I started with the 80 to reshape the tip to sharp and clean again, then worked up to finer grits and got that thing like a razor blade. Yesterday I salvaged a husky scraper tool that I’d left next to 2 gallons of muriatic acid for a few years. It was not just rusted, but chemically rusted. I used a metal wire wheel in my drill press to grind the butt of the tool down to the original metal, then the WS3k to smooth up the faces of the tool, true the edges, and sharpen the tip to a point. It was actually square before, but now it’s like a heavy duty glass scraper. I used it to scrape some labels off of Home Depot wood.
-- Gary, Los Angeles, video game animator
Craftsman on the lake
2028 posts in 1635 days
#15 posted 1210 days ago
I did a review here awhile back.. still liking mine.
-- The smell of wood, coffee in the cup, the wife let's me do my thing, the lake is peaceful. http://gagnerwebsite.com/Deceiver/Craftsman_on_the_lake/Craftsman_on_the_lake.html
showing 1 through 15 of 29 comments
