The best sanders you will ever use.
Review by GaryK posted 202 days ago 465 views 1 time favorited 20 comments Add to Favorites
View GaryK's profile
GaryK
8410 posts in 437 days
The best sanders you will ever use. The best sanders you will ever use. No-picture-s Click the pictures to enlarge them
I first saw these at a woodworking in California about 8-9 years ago and bought a set that included three
grits. I was first attracted by the way they sanded endgrain. Using the coarse grit you can sand a 1/4”
radius on the end of a 2×4 in about 30 seconds. They are incredible. They work best on the edges of
wood but can also be used on flat surfaces.
They have a sanding surface made of tungsten carbide and will almost last you a lifetime. After 8-9 years the
center of my fine grit one is clogged beyond repair. The medium and coarse grit are still going strong.
They each come with a brass brush for cleaning them, and it stores in the handle which also fits perfectly
in your hand.
Since then, they have been bought put by Midwest Products which is basically a wooden model company
and not into woodworking or furniture, so you don’t see them advertised to us.
I bought another set, not only to replace the fine grit one, but to have another meduim and coarse grit ones
laying around so I don’t have too far to go to reach one. I use them on every project I make.
The set of three inculding shipping costs less than $26, but will last you years!
The best price I have found is from here:
http://h1072840.hobbyshopnow.com/products/description.asp?prod=MID1130
You can’t go wrong with these and I would VERY highly recommend them.
20 comments so far
View RobS's profile
RobS
1083 posts in 756 days
posted 202 days ago
Hmm, I’ll have to check them out. I swear by those foam sanding blocks, always keeping them handy, these seem to be a few steps above.. Thanks!
-- Rob (A) Waxahachie,TX
1822 posts in 471 days
posted 202 days ago
Thnks for that Gary. It these secrets that take a lot of the pain out of woodworking.
3975 posts in 667 days
posted 202 days ago
Thanks, Gary. For such a small amount of money and your glowing recommendation, I will definitely order a set of these.
View Tim Pursell's profile
Tim Pursell
189 posts in 231 days
posted 202 days ago
This is a perfect example of why I love this site. I bought & tried a simmilar product for use on a ROS. They tore up the wood so bad, skipped around, clogged up and generaly were a total waste of $’s. I swore I’d never try the carbide “sandpaper” ever again. Gary is well respected here & if he says they work then I’ll have to give them a try. Thanks.
-- http://www.grandprairiewoodworks.com
4905 posts in 300 days
posted 202 days ago
I like the idea Gary. Can you add a photo of an opened one?.
GaryK
posted 202 days ago
Good idea Grumpy. I should have thought of that.
View cajunpen's profile
cajunpen
5352 posts in 515 days
posted 202 days ago
Good review Gary. It is so refreshing to hear about a product that is low in cost AND work well – the fact that it will last almost indefinitely is frosting on the cake. Good review and thanks for sharing your bounty.
View Blake's profile
Blake
1876 posts in 323 days
posted 202 days ago
Interesting. Never heard of them. I would like to try these.
-- Dust collectors suck.
2595 posts in 429 days
posted 202 days ago
Hey Gary;
How do you plug em in?
View grovemadman's profile
grovemadman
541 posts in 221 days
posted 202 days ago
Thanks Gary, I’ll check ‘em out.
-- --Chuck
GaryK
posted 202 days ago
Lee – I guess I forget to mention that the power cord was inside, huh?
View Tomcat1066's profile
Tomcat1066
556 posts in 245 days
posted 201 days ago
Great review Gary. I’ll definitely have to pick up a set!
-- "Give me your poor tools, your tired steel, your huddled masses of rust." Yep, I ripped off the Statue of Liberty. That's how I roll!
View sharad's profile
sharad
290 posts in 254 days
posted 200 days ago
Nice review.
Sharad
-- patanjali
View rikkor's profile
rikkor
7177 posts in 324 days
posted 200 days ago
Thanks for the review Gary.
-- Maplewood, MN
View Alin Dobra's profile
Alin Dobra
316 posts in 337 days
posted 199 days ago
Gary,
Do you have any idea how they compare with a Shinto rasp? I just got one and I really like it.
Alin
-- -- Alin Dobra, Gainesville, Florida
GaryK
posted 199 days ago
Alin – I have seen but never used one, so I can’t compare them.
Why don’t you post a review? I am curious what you think.
View USCJeff's profile
USCJeff
793 posts in 517 days
posted 191 days ago
I’m a sucker for anything that might make sanding less work. I’m also cheap! If they truly never wear, both needs are met. For the price, I gotta give it a shot. Thanks
-- Jeff, South Carolina
View NDwoodworker's profile
NDwoodworker
48 posts in 184 days
posted 183 days ago
I have a set of these myself, when soap an water dosen’t clean them muratic acid brings them back to almost new condition. And they are cheap for the amount of use you get out of them. Good post Gary.
-- Stuart, North Dakota
View Toolz's profile
Toolz
174 posts in 191 days
posted 183 days ago
Thanks Gary for the great review. Now I need to go order a set (after I read the Woodworkers Journal that just arrived in the mail.
-- Growing older but not up!
GaryK
posted 183 days ago
Stuart – I will have to remember that muratic acid tip. Maybe I can restore my fine one.
Bookmark And Share This Page
