Oshlun 8" stacked dado review
Review by cliffton posted 02-10-2010 03:05 AM 13098 views 0 times favorited 26 comments Add to Favorites Watch
Oshlun 8" stacked dado review Oshlun 8" stacked dado review Oshlun 8" stacked dado review Click the pictures to enlarge them
Let me preface this review with the only other dado i have used was a very old sears “wobble” dado that i used once and refused to put back on my saw. I bought this last week as rockler had it on sale for 59$ and all the reviews I saw of the 6” set said it was a good buy. Its a stacked set with full blade chippers which i like better than the wing chippers. I used it on a scrap piece of pine and had no tear out and flat bottoms. The cutter blades are made so that they put a groove along each edge to help tear out and glue up. overall i would say this is an excellent buy at a good price.
View cliffton's profile
cliffton
117 posts in 3317 days
26 comments so far
View Routerisstillmyname's profile
Routerisstillmyname
763 posts in 3745 days
#1 posted 02-10-2010 03:17 AM
I just picked up a set from Amazon. It sure has a lot more carbide than my DeWalt DW7670 Dado set.
Although when I measured each blade, none of them seem to be 100%. Despite that, all the reviews give it 4- 5 stars.
-- Router รจ ancora il mio nome.
View rsmith71's profile
rsmith71
269 posts in 3278 days
#2 posted 02-10-2010 03:22 AM
I nought the 6” set last fall and I am really pleased with it. Considered the 8” but the 6” was $20 cheaper at the time and goes more than deep enough for anything I’m working on. For the price it can’t be beat, compared to $150+ for others I checked out.
-- Robert - Haven Wood Crafts
View Kristoffer's profile
Kristoffer
675 posts in 3452 days
#3 posted 02-10-2010 03:32 AM
Thanks for the review. Sounds like you got a great deal to. I used a dado set for the first time a few days ago and enjoyed the heck out of the experience (which is a good thing, because the project I was working on had 42 dados and 8 rabbets).
Is there a upside to full blade chippers over the wings or is it just a preference?
-- Cheers and God Bless
117417 posts in 3813 days
#4 posted 02-10-2010 03:47 AM
thanks for the review
cliffton
#5 posted 02-10-2010 04:46 AM
Two things that i think make full blade chippers better are that they can have more teeth and to me it would seem like they would not be as prone to vibration. though this is completely without research into it, and i have been wrong before.
View KayBee's profile
KayBee
1083 posts in 3482 days
#6 posted 02-10-2010 08:02 AM
I picked one up from Rockler while they where on sale. Used it on both ply and solid already. I was really surprised by the quality of the cut. No tear out on the plywood at all.
-- Karen - a little bit of stupid goes a long way
View John Gray's profile
John Gray
2370 posts in 4121 days
#7 posted 02-10-2010 08:50 AM
Thanks for the review I have been considering a set of these.
View lou's profile
lou
343 posts in 3678 days
#8 posted 02-10-2010 01:42 PM
great set.and that price means i need to got one.
View Robert Herring's profile
Robert Herring
38 posts in 3615 days
#9 posted 02-10-2010 03:46 PM
Toolcity.com has them for $51.99. Anyone had dealings with them?
-- Robert M. Herring
View 8iowa's profile
8iowa
1591 posts in 3997 days
#10 posted 02-10-2010 04:04 PM
My saw falls under the “underpowered” classification, so I purchased Oshlun’s 6” set to gain more cutting torque at the teeth of the blades. The set comes with metal spacers of different thicknesses making it possible to fine tune the dado’s thickness to match the thickness of your wood. this is especially important when using plywood.
It’s really great to see a reasonably priced high quality accessory that is made in the USA. Oshlun deserves our support.
View SouthpawCA's profile
SouthpawCA
272 posts in 3469 days
#11 posted 02-10-2010 06:28 PM
BEWARE!!! I also purchased the Oshlun 8” Dado. My impression was a bit different. I did like and expected the tight fit on the arbor. When started it up it ran very smooth. But that’s about where the love story ended. I initially cut a 9/16” dado to see how it ran with multiple chippers and the 2 saws. Everything worked well – it cut like butter, but when I looked at the bottom – IT WAS NOT FLAT. The 1/16” dado left a groove. OK, I figured I had it set up wrong in some way. I rearranged the blades but had the same results. Then I checked each of the blades individually on a piece of oak. First just using the 2 saw blades alone and then each individual chipper blade sandwiched between the 2 saw blades. I found the 1/16”, the 3/32”, and one of the 1/8” chippers left a groove on the bottom. This one is going back to Rockler and I’m going to get the Freud that I wanted to get in the first place.
-- Don
View Jim Bertelson's profile
Jim Bertelson
4256 posts in 3400 days
#12 posted 02-10-2010 06:31 PM
I have this product, and have not used it much, but it seems to work very well. The 6 inch product reviewed well here also.
-- Jim, Anchorage Alaska
cliffton
#13 posted 02-10-2010 07:24 PM
wow southpaw, that is odd that your chippers were so far out of spec, that is definitely a return! see what rockler will do for you, they have been nothing but helpful to me.
I apologize I miss labeled my review this is the OSHLUN SDS-0842 set, I don’t know what the heck i was thinking.
I have never dealt with toolcity.
I went with the 8” for three reasons over the 6”
1: I use a sled so i lose about 1/2” of cut capacity.
2: It was cheaper than the 6”
3: I have a 1.5 HP R4511 and was always taught that “underpowered” meant the direct drive benchtop type of saws
I went out and tested it cutting a 2 inch dado in a stack of Jatoba and it didnt even flinch.
rsmith71
#14 posted 02-10-2010 07:55 PM
Southpaw, You got a bad one alright, but don’t let it burn you on the Oshlun. That’s really wierd that they were so far out.That’s the first time I’ve heard of that happening with these. My 6” sets works great.
rsmith71
#15 posted 02-10-2010 07:55 PM
showing 1 through 15 of 26 comments
