| Review by Sam Yerardi | posted 654 days ago | 887 views | 0 times favorited | 10 comments | ![]() |
- Dremel Hand-held Motosaw
- Brand: Dremel | Category: Scroll Saws
| Latest Projects | Latest Blog Entries | Latest Forum Topics
10 comments so far
FrankA
home | projects | blog
135 posts in 678 days
posted 654 days ago
That the first one I’ve ever seen. I looks interesting.
-- Frank Auge---Nichols NY----"My opinion is neither copyrighted nor trademarked, but it is price competitive."
14932 posts in 750 days
posted 654 days ago
Like Frank, thats a new one on me too.
danny
20 posts in 670 days
posted 654 days ago
that is a dremel scroll saw they made a base for it. so that it could be used as a true scrollsaw. the tool was made in the 50’s. the item is in the mar.2005 creative woodworks&crafts mag. when you use this free hand try to use it as if it is a coping saw ? hope this helps
-- danny s "the first to lose are the first to give up"
Sam Yerardi
236 posts in 794 days
posted 653 days ago
It’s funny about this tool. I never saw my dad use it in all the years he was with me. It wasn’t until after he passed away that I plugged it in a tried it. The first time you squeeze the trigger it scares the daylights out of you because it is such a loud buzzing sound. Like a hair trimmer on steroids.
-- Sam
3710 posts in 878 days
posted 653 days ago
Wow;
Looks like a rib spreader. ouch!
jude
147 posts in 848 days
posted 653 days ago
That is cool. I think I would need a base to use it though or in the very least, a lot of practice first.
-- life can always be weaved into a song.
Sam Yerardi
posted 653 days ago
Everytime I have ever used it I always broke a blade.
-- Sam
carlbigman
17 posts in 279 days
posted 279 days ago
Hi all,
I just bought one of these off of eBay for around $8 dollars and then the seller sent me about a dozen blades a week later that he found kicking around. It looks and works as if new. I bet it had minimal use and then was just left in a toolbox and not used again. I noticed the loud buzzing sound could be toned down a lot by adjusting the set-screw under the lower magnetic jaw plate as I observed the vibration from the actual stroke from a side view. It is important to find that equilibrium point just where it stops buzzing loudly but don’t turn the adjusting screw any further as it will diminish the actual vibratory stroke length. With that stroke length set to be at least around 1/4 inch it will allow at least about 4 teeth per 1/4 inch of blade length on a 15 tooth per inch blade to oscillate enough to get a fairly good cut in a normal range of pine, poplar, or other softer wood stock. I cut a fairly thick piece of a cigar box with it as a test cut and it did fine. I recommend supporting the stock on a piece of scrap-stock to prevent any thinner woods or veneers from vibrating the wood itself. It cut fine without breaking blades when adjusted properly but the blade should never be force-fed into the workpiece. Slow and steady wins the race. Carl
edward2
1 post in 275 days
posted 275 days ago
I have one of these and the loop of wire at the top under the magnet got brittle and broke in to, I thought I could replace with a new cord, WRONG, the original cord has a 2 inch piece of resistance wire in the line, without that it just blows the fuse. They no longer make inductance type anymore. When it worked it was great and the later Models of Dremel saws like this are still available I think.
carlbigman
posted 271 days ago
Although I am not an expert Electronics guy, I believe you could add a resister inline and a regular wire to get the same effect, Ed. I’m not sure of what resister value to use so ask one of your electronic geek buddies. Carl
