Freud RTS5300 Router & Router Table Kit
Review by CharlieD posted 02-01-2010 11:09 PM 5630 views 0 times favorited 11 comments Add to Favorites Watch
Freud RTS5300 Router & Router Table Kit No-picture-s No-picture-s Click the pictures to enlarge them
Woodcraft has this combination on sale at a good price. I have assembled everything but have yet to use the router. I did turn it on and was impressed with the soft start feature. The plunge mechanism is smooth and works well.
So far I’m impressed with the workmanship of the table and fence (nice and heavy) and everything fit together well. The installation instructions could easily be improved but I got through it without too much angst. However, I was missing parts. The flat topped countersink 6 mm bolts that hold the router to the router table insert plate were missing. The above table “Depth Adjustment Wrench” and 1/4 collet were missing as well. I called Freud and they are shipping them to me with no questions asked. Very nice. The customer service was as good as I have experienced and I was impressed. I didn’t want to wait on the missing screws and couldn’t find them locally so I filed flat the round head counter sink bolts from the routers original base plate. Also they were too long so I cut them of with my Dremel. Sounds like more trouble that it really was. You don’t need them if intend to keep the router dedicated to the router table.
-- Charlie - Texas
View CharlieD's profile
CharlieD
96 posts in 3916 days
11 comments so far
View stephen's profile
stephen
58 posts in 3250 days
#1 posted 02-02-2010 12:28 AM
Hi Charlie, thanks for the review. I was at my local HD last week and one of the guys told me that Freud is getting out of the tool business and focusing only on blades, bits etc and that all their tools are going on sale. The bench top table with router is on sale at $199 canadian. The router table that you have with router is not yet on sale but is going for $399. Mind if I ask what you paid?
Thanks
CharlieD
#2 posted 02-02-2010 01:49 AM
The Woodcraft price is $399. I got a Woodcraft flyer in the mail and ordered it online from Woodcraft. I thought it was a good deal considering the price of some router tables.
I’m planning on building a cabinet to go around the bottom of the open frame. Otherwise just wasted space and I don’t like the look.
-- Charlie - Texas
117328 posts in 3777 days
#3 posted 02-02-2010 01:59 AM
Thanks for the review
stephen
#4 posted 02-02-2010 05:38 AM
Thanks Charlie. I like the idea of a cabinet. Love to see what it looks like when your done.
View richgreer's profile
richgreer
4541 posts in 3274 days
#5 posted 02-02-2010 03:28 PM
Thanks for the review.
For what it is worth – I think the Freud fence is outstanding for people like me who are obsessed with precision. Each side of the fence is adjusted independently and each side has a micro-adjustment provision. It may take a little longer to set the fence exactly how you want it but, for me, it is worth it. If I want to move one side of the fence exactly 1/512th of an inch, I can.
By the way – If Stephen is right and Freud is getting out of the tool business, maybe their doweling machine will be on sale soon.
View Obiwan's profile
Obiwan
20 posts in 3250 days
#6 posted 02-02-2010 04:36 PM
Charlie,
I got the same unit awhile back. As you stated, the instructions were a lot to be desired. Esp. the table assembly. Fortunately, I got all my parts. I like several things about this unit. The above table bit changing with one wrench, soft start and the micro adjusting fence. I did add a hex key ratchet for raising and lowering the collett. A lot faster than the twist knob. I also found out it is much easier to remove the router from the table by lowering the router all the way down in the table before lifting out. I also added a power switch to the table for convenience.
-- Obiwan
View TxYoda's profile
TxYoda
3 posts in 3289 days
#7 posted 02-02-2010 07:42 PM
Freud isn’t getting out of the tool business; they are simply shaving their line. They produced some very good tools, but it became increasingly difficult for them to compete with other lines. They would offer wrenches, collets, and dust collector shrouds as a part of the tool, when everyone else was offering these things as accessories. This concept caught on and everyone started following what Freud. Freud simply couldn’t compete with the prices these other companies were charging. For now, they are keeping a few of their tools: a 3-1/4hp router, doweling jig, and I believe a biscuit joiner—-at least this is what a Freud rep told me less than a month ago.
stephen
#8 posted 02-02-2010 08:59 PM
Thanks Tx.
View Enthalpy's profile
Enthalpy
44 posts in 3241 days
#9 posted 02-03-2010 02:28 AM
I bought the same setup. No problems with assembly, I have an 8 YO neighbor…2 screws where too long for the router plate mount….damn the French….I don’t like the split fence….absoluty no need for one…tomorrow a solid fence will be made….
After turning off the saw, count to ten
View chrisstef's profile
chrisstef
17761 posts in 3206 days
#10 posted 03-03-2010 07:49 PM
I just picked up the same unit on sale from Woodcraft myself. Just got around to tryin it out the other night and had it setup to use as a jointer for soem reclaimed lumber. The micro adjust on the fence worked great and it beat the heck out of my old craftsman 4” jointer. Plenty of juice behind the 3 1/4 HP motor. Only downfall is that once the fence is set adjusting the depth of the bit requires you to remove the fence or slide it back.
CharlieD
#11 posted 03-04-2010 05:25 AM
Yep, design error by Freud. I callled and talked to them several times. No matter what hole you put the fence in it doesn work right. I had Freud send me the table insert screws (sorry don’t know the correct name) and I drilled holes and installed the inserts between the first and second set of holes. that solved the problem but I should not have to fix their error on a $400 purchase. Otherwise, I’m happy with it. I will say the guys I talked to were very nice and cooperative. But the did admit that it was a problem.
-- Charlie - Texas
