Jet 6" joiner
Review by DougZ posted 11-13-2018 10:59 AM 961 views 0 times favorited 5 comments Add to Favorites Watch
Jet 6"  joiner No-picture-s No-picture-s Click the pictures to enlarge them
I purchased this joiner new in 2016 and like the 8’ version it came in two boxes. Although I did not have to mess with the motor or electric as you explained. Two people are needed to properly and safely assemble the unit. Take your time as there are many steps. Once completed the unit works flawlessly. It has a 4” dust port and soft wood produce bigger chips than hard woods. I am a Jet guy and have several pieces off this brand in my shop. Safety is always necessary in both operating any machinery as well as knowing the wood your working with.
-- Douglas, Virginia
View DougZ's profile
DougZ
3 posts in 34 days
5 comments so far
View fivecodys's profile
fivecodys
1228 posts in 1840 days
#1 posted 11-13-2018 04:15 PM
I have the same model. It has performed flawlessly for almost 20 years.
-- I always knew I would grow old, But I expected it to take longer!
View Rich's profile
Rich
3888 posts in 793 days
#2 posted 11-14-2018 04:43 AM
- fivecodys
Ditto. I bought mine locally back in around 2000 and brought the two boxes home in my 1985 Mazda Rx7 GSL-SE. I managed to assemble it by myself too. Just a matter of assembling it on its side and then lifting it up.
Great little jointer.
View Jacksdad's profile
Jacksdad
212 posts in 628 days
#3 posted 11-16-2018 09:21 PM
I have the same model, my only complaint is I can’t take a fine cut, I’d like to take a 1/16” or lighter but It won’t allow me to
View Rich's profile
Rich
#4 posted 11-16-2018 09:41 PM
I have the same model, my only complaint is I can t take a fine cut, I d like to take a 1/16” or lighter but It won t allow me to
- Jacksdad
It sounds like something’s not set up right (see below). I use a Oneway Multi-gauge to set the offset of the in feed to the out feed (the blades are level with the out feed of course), and keep it set most of the time to 1/64” (0.016). If I have irregular boards that require a lot of material to be removed I’ll crank it up to 1/16”, but almost never higher.
Here’s something to check. There’s a round knob about the size of a marble on the back on in feed side. Pull it and see if you can turn the handle to raise the in feed bed higher for a shallower cut. You might have to lower it first if the bed has the pin frozen. It engages automatically when you go down towards 1/8” and you have to pull it outwards to get back.
View ScottStewart's profile
ScottStewart
120 posts in 2336 days
#5 posted 11-17-2018 04:14 PM
I had one of these that I never could get the tables coplanar. Was unable ever get it dialed in and eventually sold it in frustration.
