| Review by funchuck | posted 1220 days ago | 1952 views | 0 times favorited | 10 comments | ![]() |
- Delta TS200LS 10" Saw with Stand
- Brand: Delta | Category: Tablesaws
This was my first major tool purchase about 5 or 6 years ago. It was a whopping $100 from Lowes. At the time, I thought that was a lot of money!
This saw has some limitations:
- The miter gauge slot is not standard, so you can’t upgrade to a better one.
- The table is very small
- The insert is just a thin piece of metal, which will make it hard to create an insert.
I found the fence to be surprisingly good. When I lock it down, it doesn’t slip, and it locks down at 90 degrees. Don’t know if I got lucky on that or not.
I always got a lot of chip-out when cutting certain woods, especially plywood. As mentioned above, I also felt very limited by the small table.
This led me to a decision: New blade, or new table saw?
I posed this question in the LJ forums and _bp pointed me to a HD sale. $299 for a Ridgid granite top saw! I went to HD the next day and scheduled for a delivery!
After assembly, I put the 2 saws next to each other. It was a night and day difference! The Ridgid’s table was huge! Everything about this saw was so much better! It felt more like a precision instrument. I am also going to buy a blade (probably a freud), make some ZCIs, and add fence faces.
I decided to put the old Delta away. I disassembled the stand and to my amazement, I found that 3 of the 4 bolts holding the saw to the stand were completely loose! I am sure glad I didn’t hurt myself. This thing could have toppled over while I was using it! I guess all the vibration caused the bolts to loosen. But, the stand did not come with any lock washers, so that is probably a reason for the loose bolts. Most of the bolts holding the stand together were loose too.
With that said, I will still miss my old Delta. Crappy as it was, it served me well for ~5 years.
-- Charles from California
10 comments so far
thekingofspain
home | projects | blog
20 posts in 1225 days
#1 posted 1220 days ago
Got the $299 saw as well. Going to retire the craftsman limited edition soon which included a stand for $140 like 5 years ago.
-- tkos
Bob Kollman
1779 posts in 1362 days
#2 posted 1220 days ago
Glad you got a good saw. I think those little deltas are extremly——-not safe——
-- Bob Kenosha Wi.
PeteMoss
186 posts in 1642 days
#3 posted 1220 days ago
I agree, I had the $100 Delta myself as a first tablesaw. I guess you probably can’t get any better for $100 though. I put a decent thin kerf blad on mine and it made a huge difference in relative power and cut quality. You’re right, the fence wasn’t bad, except for a max rip width of something like 11 inches (if I remember right) and the miter gauge did stink. The worst part for me was the noise and lack of dust containment. Anyway it sounds like you got a great upgrade, enjoy yourself.
-- "Never measure......cut as many times as necessary." - PeteMoss
dbhost
4748 posts in 1403 days
#4 posted 1220 days ago
Glad you got the Ridgid saw on that screaming deal of a price… Good saw, not a lot of money… I have had friends with that particular Delta table saw, and they burnt them up in less than a year. Some folks wonder why I don’t have any Delta in my shop… That saw is a good reason… Delta should know better than to slap their name on something like that.
woody57
639 posts in 1599 days
#5 posted 1216 days ago
I used a delta contractors saw for many years and it did a good job. It was about $700. A few years ago I got a powermatic 66 for about $2000. Its great and will probably be my last saw.
In short. You get what you pay for. Especially with table saws. I always tell people to buy the best saw you can afford. It is the foundation of most shops. Skimp on clamps or something.
Anyway, sounds like to got a huge upgrade. Happy sawing and don’t cut yourself.
-- Emmett, from Georgia
87312 posts in 1749 days
#6 posted 1216 days ago
A $100 saw is better than no saw.
jp93274
17 posts in 1224 days
#7 posted 1214 days ago
I also Bought the $299 Ridgid Granite TS at the Home depot! This is a Definite Upgrade to my $69 Clearance price Firestorm Table saw (all Plastic) and i am sure i will either Donate the B&D TS or find a good use for it!
P.S any ideas for the B&D Firestorm Saw?
-- I Now Bleed Orange! Thank You HD For the Clearance Sale!
funchuck
99 posts in 1229 days
#8 posted 1214 days ago
jp93274: I’ve been thinking about what to do with my old saw too.
One idea would be to install a sanding disk and use it as a sander. This would be very easy to do.
You can also take the motor out to build a tool such as a sander or sharpener. There was a post on the forums about building a nice looking stationary belt sander.
BTW, I used the Ridgid saw for the first time tonight, to cut some plywood sheets. It is just a wonderful saw. It cut through the plywood like nothing else! That 30” rip capacity is something else too! I still need to make some ZCIs for it though.
ladiesman217
74 posts in 1386 days
#9 posted 795 days ago
Hahaha…I bought the same saw when I became interested in woodworking in 2003-it’s a total piece of junk. The miter slot gauge is off, the slots have too much play, the fence is awful…yet I spent so many hours with that saw that I still keep it as a memento….and to use for outdoor projects that require no accuracy. I’m thinking that it could be turned into a dedicated sander with one of those kits Grizzly or Rockler sell.
-- Rock Chalk Jayhawk!
ic3ss
197 posts in 948 days
#10 posted 684 days ago
I have to second ladiesman217 on all counts. I bought the same saw from Lowes to finish a trim job in my house and while it worked for what I bought it for, it was junk right out of the box. The miter gage would catch in the slot as I moved it, the fence didn’t move when locked down but it would move from it’s position when I locked it down. Then I had to unlock it, re-measure both ends to the blade while leaving enough error in anticipation of it moving and then try locking again. What a pain in the ass. The list goes on. . . it was too small, underpowered, too light, too noisy, too much runout, too much vibrtation, too ugly . . . . .
I used it for only a couple of small things after that, and then I rebuilt an old Unisaw. I put the P.O.S on craigslist before the Unisaw was up and running. I couldn’t get rid of it fast enough.
Ok, it was a $100 table saw. It was cheap and I got what I paid for. Lesson learned.
-- "I am endeavoring, ma'am, to construct a mnemonic memory circuit using stone knives and bear skins."
