Could be Better
Review by HankLP posted 10-22-2018 03:46 PM 757 views 0 times favorited 6 comments Add to Favorites Watch
Could be Better Could be Better Could be Better Click the pictures to enlarge them
I really like the Grizzly G0771 table saw, and have used it for several years now. I was pleased to discover
that Grizzly came out with an insert for the G0771, however, this rating lost two stars for the following:
1) The insert sits 0.020” higher than the original insert which means the leveling screws have to be readjusted when swapping the inserts. The ZC Inserts I make have oversized holes that fit over the screw heads. This allows a thicker edge on the insert, and the leveling screws remain fixed with Threadlock.
2) The Grizzly insert has 0.040” play side to side. This seems excessive if a 1/32” (+) trimmed piece can fall through and jam the blade in the insert.
View HankLP's profile
HankLP
84 posts in 743 days
6 comments so far
View WoodenDreams's profile
WoodenDreams
379 posts in 152 days
#1 posted 10-24-2018 06:50 PM
I also have the G0771Z. It’s nice to see Grizzly finally come out with a throat plate for zero clearance to fit the G0771Z. I’ve been making my own zero clearance from red oak. Doesn’t take much time to make your own from a scrap piece of red oak, and you don’t have to wait for shipping.
View JohnMcClure's profile
JohnMcClure
400 posts in 881 days
#2 posted 10-28-2018 12:27 PM
I recently bought the G0771Z and the ZCI to go with it. Haven’t used it yet to notice if it stands proud like you said, but I did notice the slop – 0.040” seems about right – side to side. That’s dangerous IMO. I plan to glue some plastic shim stock on one side until it is tight before I ever run the blade up through it. Any other suggestions about handling this?
Also, do most ZCI users keep the riving knife off or use a scroll saw to open up a slot for it?
-- I'd rather be a hammer than a nail
HankLP
#3 posted 10-29-2018 04:15 AM
John,
Not sure about the riving knife. If I need to use the knife I will probably go with the factory insert. Hope you enjoy your G0771Z as much as I do the “old” G0771.
View Mike_D_S's profile
Mike_D_S
557 posts in 2455 days
#4 posted 11-04-2018 01:02 PM
Hank, For the height issue, you might try sanding down a small area where each screw sits to reduce the thickness of the insert, essentially lowering it so it sits level with the saw top without having to change the screw position you normally use.
I have the Betterly insert for my saw and it has two ball catches on the side to keep the insert locked in side to side. You might be able to drill two holes on the stock side of the insert to keep it from moving around. Something like the ones below. This would serve to keep the waste side edge closed tight.
https://woodworker.com/14-solid-brass-cylindrical-ball-catch-mssu-163-688.asp
Mike
-- No honey, that's not new, I've had that forever......
HankLP
#5 posted 11-05-2018 07:32 AM
Mike, I’m thinking of using a small forstner bit to take off 0.020” where it sits on the levelling screws. Don’t know if I can maintain that tolerance on my drill press, but it may be worth giving it a try.
Mike_D_S
#6 posted 11-05-2018 03:36 PM
I’m guessing by looking at is that the insert is phenolic and I never had much luck drilling that stuff. So for me I think I’d go for the sanding to avoid chipping it out accidentally.
