Milescraft blade changer
Review by kosta posted 01-18-2010 06:37 PM 2579 views 0 times favorited 5 comments Add to Favorites Watch
Milescraft blade changer No-picture-s No-picture-s Click the pictures to enlarge them
Yo whats up everybody I wanted to do a review of the milescraft blade changer. I have had this blade changer for about 2 weeks and it works pretty good. The way it works is you put it next to the blade and you raise the blade. It has to be lined up straight with the blade. Then you keep raising the blade until the changer lifts off the table that means that its locked in. Then you take the blade off. I have always had problems using a second wrench on the left side of the blade so this is much easier then using a second wrench. Make sure you put the changer on the left side of the blade. http://milescraft.com/product/3401.htmlhttp://milescraft.com/product/3401.html
View kosta's profile
kosta
946 posts in 3259 days
5 comments so far
View richgreer's profile
richgreer
4541 posts in 2979 days
#1 posted 01-18-2010 07:44 PM
Interesting. Can you lift the blade out of the saw with this tool and avoid handling the sharp blade directly with your hands? Does this work if you have a stabilizer on your saw blade?
View RedShirt013's profile
RedShirt013
219 posts in 3566 days
#2 posted 01-18-2010 08:21 PM
For a blade changer I would also like to see it cover at least half of the blade. When changing blade I always need to be super careful to not ding the carbied teeth on the iron top as I pull it out, as even then it still happens from time to time. Would be nice if a blade changer can prevent that.
-- Ed
kosta
#3 posted 01-18-2010 09:43 PM
It covers the entire blade no teeth are exposed except the ones in the saw.
You cant lift it out without toughing it but using this lowers the chance that you can slip and cut your hand or that the blade gets messed up. I am not sure if it works with a stabilizer
View Derek Lyons's profile
Derek Lyons
584 posts in 3472 days
#4 posted 01-19-2010 12:28 AM
If the teeth ‘in the saw’ are exposed, then it doesn’t cover the whole blade.
-- Derek, Bremerton WA --
kosta
#5 posted 01-19-2010 01:32 AM
Im talking about the teeth under the table
