Great performer, should have bought it earlier
Review by JayT posted 08-20-2018 01:03 PM 2002 views 2 times favorited 20 comments Add to Favorites Watch
Great performer, should have bought it earlier Great performer, should have bought it earlier Great performer, should have bought it earlier Click the pictures to enlarge them
About a year and half ago, I was tired of having to leave the shop whenever my compressor kicked on due to the noise level. The compressor was one of the tried and true Porter Cable pancakes and it worked great for everything except my eardrums. Thinking about how I used a compressor, decided to downsize a bit and purchased a small one gallon unit from California Air Tools.
Pros
Noise Level. This thing is QUIET! I knew it was good from being at a show where CAT had a booth and talking with their people. Actually we were having a normal conversation standing right on top of the compressor while it was running. Even so, getting it into the shop and doing a side by side with the Porter Cable was amazing. I seriously used to leave the shop anytime the compressor kicked on. Now I can barely hear it over the low volume radio. I’ve demonstrated it to several people and every single one is totally shocked at the volume level.
Size & Weight The compressor spends most of the time in the shop, where it fits very nicely tucked under the bottom shelf of a tool stand. Its compact size is far easier to store than the previous compressor. When there is a need to move it to the house for a job, at less than 30lbs it is extremely easy to carry.
Fill & Recovery Time Fill time from completely empty is less than a minute and recovery takes about 15-20 seconds. As seen in the pics, I recently redid our living room floor and with a stapler, I would have to pause about every 10-12 staples to let the compressor catch up. It took just enough time to for me to stand up, stretch my back and then was able to go back to work.
Cons
The only con is that it is a very small compressor, so you aren’t going to be running a framing gun or roofing nailer with one, much less a high demand tool like an impact wrench or pneumatic sander. If being used as a compressor this size ought to be, there is no downside I’ve found so far. For a brad nailer, inflation, or dusting off projects, it works great.
After owning and using this compressor for the past year and a half, my only regret is not making the switch much earlier. For light duty use, I haven’t seen or heard anything else that compares.
View JayT's profile
JayT
6002 posts in 2445 days
20 comments so far
View Bill Berklich's profile
Bill Berklich
497 posts in 622 days
#1 posted 08-20-2018 02:11 PM
Great Review – Both my PC pancake and Craftsman 20Gal always requires hearing protection. 90% of my usage is 16ga or 18ga nailing and filling bike tires. So the CAT sounds like a good alternative.
-- Bill - Rochester MI
View MrRon's profile
MrRon
5258 posts in 3477 days
#2 posted 08-20-2018 03:08 PM
You did well. I have the same compressor for 2 years. I have 4 other compressors and the noise drove me crazy. It is the perfect size for the type of work I do, which is model building. My other compressors are used when I have to run a framing nailer or impact wrench. I can usually drive abou 20, 18 ga brads before it kicks back on.
View kocgolf's profile
kocgolf
373 posts in 2412 days
#3 posted 08-20-2018 03:10 PM
I need this. I would use my compressor SO much more for the “shop projects” if I could just stand the noise. Thanks for the heads up on a cool product.
View CharlesA's profile
CharlesA
3355 posts in 2032 days
#4 posted 08-20-2018 03:20 PM
+1. made the switch and really like it.
View jayseedub's profile
jayseedub
137 posts in 2199 days
#5 posted 08-20-2018 03:31 PM
I have the same one, and love the quietness. Though it’s the same size a my previous (non California branded one) air compressor, I think it turns on much sooner/quicker than the other one—it seems to cycle more often, in otherwords.
Still, since it’s so much quieter (it’s not QUIET—but much, much quieter) it doesn’t bother me much at all.
No hearing protection needed, so far as I can tell!
View builtinbkyn's profile
builtinbkyn
2677 posts in 1174 days
#6 posted 08-20-2018 03:38 PM
I have the 5.5gal version. It is much quieter than any other compressor I’ve owned. I was thinking of adding a 10gal reserve tank to it. It would be nice to have more capacity.
-- Bill, Yo!......in Brooklyn & Steel City :)
View fivecodys's profile
fivecodys
1265 posts in 1870 days
#7 posted 08-20-2018 09:16 PM
I have the 5.5gal version. It is much quieter than any other compressor I ve owned. I was thinking of adding a 10gal reserve tank to it. It would be nice to have more capacity.
- builtinbkyn
If you do add a capacity tank, will you share with us how you did it?
I have been thinking about doing the same thing.
-- I always knew I would grow old, But I expected it to take longer!
View Peteybadboy's profile
Peteybadboy
566 posts in 2184 days
#8 posted 08-21-2018 03:49 PM
I will check that out
-- Petey
View Tim_456's profile
Tim_456
172 posts in 3829 days
#9 posted 08-22-2018 02:14 AM
Great review, I have the same compressor and I second that the noise level is almost unbelievably low. My Craftsman compressor freaks out the dog so I could never use it as much as I want. The dog doesn’t even flintch with this one. The capacity is small so I added a 5 gallon reserve tank. Takes longer to fill up (of course), but does last a bit longer. It doesn’t make it framing nailer capacity, but it does give me more nails between recovery.
View BurlyBob's profile
BurlyBob
6029 posts in 2499 days
#10 posted 08-22-2018 03:05 PM
Thanks for this. I’ve been hoping to replace my PC air compressor with something quieter.
View ArtMann's profile (online now)
ArtMann
1215 posts in 1050 days
#11 posted 08-22-2018 05:02 PM
With regard to increasing air storage capacity, it doesn’t really do any good and can compromise the life of the compressor. It takes a certain amount of run time time to deliver a certain volume of air at a certain pressure. That is true whether the tank capacity is large or small. With an auxiliary tank, the compressor will cycle less often but it will run longer when it does come on. Therein lies the problem. Compressor motors are not designed to run continuously due to heat buildup. The longer a compressor motor runs, the hotter it gets. More storage might just cause the motor to stay too hot for too long and damage it.
Has anybody besides me ever run a nailer for several hours at once? It takes only a very small amount of air to run one gun. I watched a team of Mexicans roof my house and they used 4 guns at the same time and used a tiny Porter Cable pancake compressor. It kept up just fine.
View Andybb's profile
Andybb
1599 posts in 837 days
#12 posted 08-22-2018 05:59 PM
Have it and love it. Allows me to work at night without waking the wife.
-- Andy - Seattle USA
View cpd011's profile
cpd011
91 posts in 3471 days
#13 posted 08-22-2018 06:05 PM
+1 This compressor is unbelievably quiet. The sound it makes is almost soothing. I wish I had found this thing 10 years ago.
View oldnovice's profile
oldnovice
7378 posts in 3602 days
#14 posted 08-22-2018 06:18 PM
I think I need one of these because I can’t hear anything when my Porter Cable pancake one is running, it has to be noisiest power tool I have!
I think my neighbors would appreciate that too.
View Rayne's profile
Rayne
1122 posts in 1774 days
#15 posted 08-23-2018 02:30 AM
If anyone is on the fence about getting a California Air compressor, Home Depot and Amazon both have the 8 gallon ultra quiet compressor for sale $156. Almost the lowest ever. You have 4 hours left from the time of this posting to get it.
https://www.homedepot.com/p/California-Air-Tools-8-0-Gal-1-0-HP-Ultra-Quiet-and-Oil-Free-Electric-Air-Compressor-8010/206087284
https://www.amazon.com/California-Air-Tools-8010-Compressor/dp/B00WM1VPKE/ref=sr_1_3?ie=UTF8&qid=1534991323&sr=8-3&keywords=california+air+8+gallon&dpID=51tNdgsepCL&preST=_SX300_QL70_&dpSrc=srch
