If you want a great miter gauge
Review by Jacksdad posted 07-20-2018 07:25 PM 943 views 0 times favorited 7 comments Add to Favorites Watch
If you want a great miter gauge No-picture-s No-picture-s Click the pictures to enlarge them
I got the Kreg Miter gauge for my birthday, it’s great. I taught a segmented turning class at Woodcraft and I was going to show how to fix if your segments are not perfect, 1 cut 16 pieces and put them together and no gap, so much for that idea. It comes perfect from the factory, if you aren’t getting perfect angles your saw needs adjusting. It cuts accurately to a tenth of a degree, I highly recommend it.
View Jacksdad's profile
Jacksdad
201 posts in 565 days
7 comments so far
View recycle1943's profile
recycle1943
2291 posts in 1763 days
#1 posted 07-20-2018 07:31 PM
It is no doubt a great tool, kreg makes good stuff but I have 5 Incra miter gauges, too late to switch over
-- Dick, Malvern Ohio - my biggest fear is that when I die, my wife sells my toys for what I told her I paid for them
View Woodmaster1's profile
Woodmaster1
1041 posts in 2728 days
#2 posted 07-20-2018 10:45 PM
I have this miter gauge and find very accurate and it makes segments for rings perfect. This cuts out that step of gluing the ring into two halves and sanding the halves to meet. The miter gauge is worth the price.
View Woodknack's profile
Woodknack
12369 posts in 2521 days
#3 posted 07-21-2018 04:17 AM
Sounds like a good thing to own.
Jacksdad
#4 posted 07-21-2018 09:54 PM
UPDATE, the only downfall to the miter gauge is the pin that holds the gauge at preset angles is loose and can fall out and get lost. After I dug through the sawdust under my table saw I found the pin. I modified it by drilling a small hole and attaching a piece of string to hold it to my miter gauge.
Woodmaster1
#5 posted 07-22-2018 01:15 AM
Not a bad idea I had to look for pin a couple times myself.
View NormG's profile
NormG
6251 posts in 3145 days
#6 posted 07-22-2018 06:55 PM
How dare Kreg send out a a miter gauge that requires no adjustment. That just takes away from frustration level a tad bit. Congrats, I have considered the purchase of one.
-- Norman - I never never make a mistake, I just change the design.
View Andre's profile
Andre
2056 posts in 1947 days
#7 posted 07-24-2018 07:13 AM
Have the same miter gauge, sure increased the accuracy of Old Delta TS!
