Busy Bee Vs. Canadian Wood Worker Drum Sander
Review by Joinerjordan posted 07-05-2018 02:42 PM 1639 views 0 times favorited 4 comments Add to Favorites Watch
Busy Bee Vs. Canadian Wood Worker Drum Sander No-picture-s No-picture-s Click the pictures to enlarge them
We put these two Sanders up against each other to duke it out. It seems as though the little guy works faster than the Mac Daddy drum sander, which could be due to the mechanics push/pull of the machine itself. Anway, have a look for yourself https://www.youtube.com/watch?v=ox-dQC4t47c&feature=youtu.be and let us known what you think in the comments section. Thank you for your time!
View Joinerjordan's profile
Joinerjordan
1 post in 230 days
4 comments so far
View Underdog's profile
Underdog
1248 posts in 2275 days
#1 posted 07-05-2018 06:04 PM
So neither machine has a variable speed feed?
And what about stock removal settings? Isn’t there some kind of indicator to show how much stock you want removed?
I don’t know how you can compare fairly unless you know how much stock you intend to remove. As for feed belt speed, I would assume that it’s the same.
Most widebelt sanders have variable feed speed, and digital thickness indicators.
You might want to invest in a real widebelt sander if you’re in production…
-- Jim, Georgia, USA
View Desert_Woodworker's profile
Desert_Woodworker
1674 posts in 1454 days
#2 posted 07-07-2018 03:06 AM
And what about stock removal settings? Isn t there some kind of indicator to show how much stock you want removed?
I don t know how you can compare fairly unless you know how much stock you intend to remove. As for feed belt speed, I would assume that it s the same.
You might want to invest in a real widebelt sander if you re in production…
- Underdog
+1
will the price increase with the new tariffs?
-- Desert_Woodworker
View JADobson's profile
JADobson
1335 posts in 2350 days
#3 posted 07-10-2018 09:04 PM
Both companies are Canadian no? Tariffs shouldn’t be a problem.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View diverlloyd's profile
diverlloyd
3288 posts in 2097 days
#4 posted 07-11-2018 11:24 PM
Would be nice to have a written review since most on here don’t click on self promoting YouTube channels.
