Rohm 871053 Type 136 Supra 13 Keyless Drill Chuck
Review by PPK posted 06-11-2018 06:28 PM 1669 views 0 times favorited 13 comments Add to Favorites Watch
Rohm 871053 Type 136 Supra 13 Keyless Drill Chuck No-picture-s No-picture-s Click the pictures to enlarge them
I have a WEN drill press, that came with a Chinese no-brand chuck. The chuck was wobbling and I had enough run-out that it would shake the whole work piece and vibrate like nobody’s business. I knew this could be a possibility with the DP I bought, but that’s another topic; I’m reviewing the chuck not the DP. (I really like the DP now that I have a good chuck, in case you were wondering)
This chuck is about 1/2” capacity (It’s Geman, so it’s all Metric). It’s keyless, and is machined superbly.
I’ve run large 2” forstner bits at low speeds (lots of torque) and had no slippage on the bits, even though it was just hand-tightened. The jaws on the chuck are different from what you’d see in a Standard Jacobs chuck. Wish I could describe it better, but they seem to move much smoother and grip much better. German engineering at its finest, I guess!
I have not been able to see or feel any run-out now. I don’t have a good way to measure, but it tell you what, it drills really nice clean holes!
Fitting the chuck to the drill press was easy; I got the J33 to MT2 arbor adapter, and it went together with a few taps.
For about $115, (Chuck + arbor adapter) I’m very pleased with the results.
Link below to where I purchased it:
https://www.amazon.com/Rohm-871053-Diameter-Clamping-Capacity/dp/B00DD7NVUI/ref=sr_1_1?ie=UTF8&qid=1528741246&sr=8-1&keywords=Rohm+871053+Type+136+Supra+13+Keyless+Drill+Chuck%2C+J33+Mount%2C+46mm+Diameter%2C+1-13mm+Clamping+Capacity
-- Pete
View PPK's profile
PPK
1095 posts in 889 days
13 comments so far
View ralbuck's profile
ralbuck
4815 posts in 2345 days
#1 posted 06-11-2018 06:47 PM
Very glad it works for you.
Thanks for the tips.
-- Wood rescue is good for the environment and me! just rjR
View Redoak49's profile
Redoak49
3394 posts in 2068 days
#2 posted 06-11-2018 10:32 PM
That is a nice chuck. What is the runout with it installed?
View Mainiac Matt 's profile (online now)
Mainiac Matt
8252 posts in 2408 days
#3 posted 06-12-2018 12:37 PM
Prices have come down on the Rohm chucks quite a bit. I’ll have to save up my pennies to get one for the drill press.
I have one on a Bosch hammer drill and agree that they are very high quality.
-- I yam what I yam and that's all what I yam
View kocgolf's profile
kocgolf
333 posts in 2257 days
#4 posted 06-26-2018 02:11 AM
I am about to pull the trigger on a WEN DP. Nothing fancy, just a 10 inch (or maybe 12) benchtop version. Hadn’t considered a different chuck, but maybe. It’s appealing. Would this be a benefit on smaller press like this or is there a lighter duty, less expensive upgrade that would be worth it? I do mostly smaller projects and there isn’t a 2 inch forstner bit even in my shop:)
View PPK's profile
PPK
#5 posted 06-27-2018 04:06 AM
Id sure not get a different chuck until you see how well the one performs that comes with it. THe QC is simply just hit and miss. Sometimes you get a good one, sometimes you don’t. I didnt! :-)
-- Pete
View Wuu's profile
Wuu
3 posts in 401 days
#6 posted 07-06-2018 03:46 PM
nice what brand of adapter did you get? hate to get one and have it add/ create runout. thanks
View PPK's profile
PPK
#7 posted 07-06-2018 03:52 PM
View Wuu's profile
Wuu
3 posts in 401 days
#8 posted 07-06-2018 03:55 PM
awesome. this will make my wen dp sweet. thank you so much.
View HankLP's profile
HankLP
61 posts in 581 days
#9 posted 07-10-2018 01:56 PM
I have a Craftsman 12 inch drill press and the runout is about 0.03 inches at about 3 inches from the chuck. Can you identify the problem as the chuck or the machine before you spend the $$ on a new chuck? I guess getting a keyless chuck would be another reason to swap out the chuck. And will the Rohm chuck take a bit as small as 1/16”?
View PPK's profile
PPK
#10 posted 07-10-2018 02:59 PM
- HankLP
Hmmm…. well, since you’ve got a way to measure run out, I’m assuming that you chucked up a bit and measured the runout on a bit or rod? The way to determine if the runout is on the chuck or the quill (drill press) would be to measure the runout on the quill shaft itself when fully extended down, I think. I know that some drill presses, you can actually tighten up/adjust the quill. Other times, I think it’s just that there’s slop in the main bearing, and there’s not much you can do. Can’t say for yours specifically.
As to the 1/16” bit, I have not tried it yet, but it’s advertized as going down to 1mm which is 0.039” which is a little less than 1/16”, so I don’t think you’ll run into any issues there. It does close down really tight. Hope that helps!
-- Pete
HankLP
#11 posted 07-10-2018 03:56 PM
Thanks Pete. I had difficulty installing dot markers in the fret board on my banjos. Finally determined it was the runout. Guess I’ll bite the bullet and order a new chuck. It will be useful as well to be able to use the smaller bit size.
HankLP
#12 posted 07-19-2018 04:05 AM
Got the Rohn chuck yesterday, and put it to work today. Problem solved! And bit changes are sooo slick and easy with the keyless. I’ll hang on to the old chuck because it will clamp 5/8”, and it will go with the drill press if I ever decide to upgrade… hmmmm…
View PPK's profile
PPK
#13 posted 07-19-2018 01:30 PM
Hank LP, glad you liked the chuck. It really does make bit changes very quick.
-- Pete
