Surprisingly Simple
Review by pintodeluxe posted 05-01-2018 04:11 PM 1929 views 1 time favorited 9 comments Add to Favorites Watch
Surprisingly Simple No-picture-s No-picture-s Click the pictures to enlarge them
This style of freestanding template jig has been around for a long time, but this one focuses on box joints. You can make 1/2” or 3/4” box joints, and the kit comes with just about everything you need. Just add an MDF fence, and you’re off to the races.
Chuck the included router bit in your router, and install the eBush, then rout your first workpiece. Then flip the little green tab and rout the mating workpiece. The offset is automatic!
I started with the eBush set at “5”, and made one minor adjustment to “4.5” and the joints have fit perfectly ever since. Compared to a tablesaw based box joint jig, the beehive jig benefits from almost no tearout. The Leigh bit is extremely sharp and well made, and the MDF fence prevents any tearout on the back.
I have 4 or 5 other router-based box joint jigs, as well as a tablesaw based jig. I will say this is the easiest to setup and produce snug-fitting joints. Plus it comes at a much lower price point than some of my other jigs. The one negative point is there is no dust collection available. If you’re willing to let the chips fly, this jig really does the trick.
View pintodeluxe's profile
pintodeluxe
5816 posts in 3051 days
9 comments so far
View kdc68's profile
kdc68
2692 posts in 2514 days
#1 posted 05-01-2018 10:06 PM
Good review…..Thanks for the info !
-- Measure "at least" twice and cut once
View NormG's profile
NormG
6378 posts in 3241 days
#2 posted 05-02-2018 01:51 AM
Awesome jig
-- Norman - I never never make a mistake, I just change the design.
View KTNC's profile
KTNC
89 posts in 493 days
#3 posted 05-02-2018 03:47 AM
Thanks for your review.
View Arcola60's profile
Arcola60
100 posts in 2621 days
#4 posted 05-02-2018 05:32 AM
Thanks for the review. I have purchased the Jig, also. I have not had a chance to set it up yet. Moving has caused some shop setup issues.
pintodeluxe
#5 posted 05-02-2018 06:03 AM
- Arcola60
I think you’ll like the beehive jig. Setup was quite easy.
Good luck setting up shop!
View Albert's profile
Albert
518 posts in 3827 days
#6 posted 05-02-2018 02:48 PM
Thanks Neighbor, I think I might have to get one of these!
View Mainiac Matt 's profile
Mainiac Matt
8612 posts in 2566 days
#7 posted 05-02-2018 04:01 PM
I wonder if you could use a setup like this on a router table…..
Hmmmmmm….
-- I yam what I yam and that's all what I yam
pintodeluxe
#8 posted 05-02-2018 04:03 PM
Hmmmmmm….
- Mainiac Matt
Yes, you sure can. You just need a router table insert that accepts standard P.C. style guide bushings.
View japanesewoodworker's profile
japanesewoodworker
75 posts in 3289 days
#9 posted 08-28-2018 12:53 AM
Hello Pintodeluxe,
I’m not sure if I am placing this link in the correct location. But here is a LINK FROM THE LEIGH BOX JOINT & BEEHIVE JIG.
https://www.leighjigs.com/b975-overview/
Hmmmmmm….
- Mainiac Matt
- pintodeluxe
