Who needs a lift?
Review by CharlieM1958 posted 658 days ago 1453 views 1 time favorited 23 comments Add to Favorites Watch
Who needs a lift? Who needs a lift? No-picture-s Click the pictures to enlarge them
After starting a forum topic recently to solicit opinions about what type of variable-speed router I should buy to leave mounted in my table for the most part, I eventually decided to go with the Trtion MOF001KC 2 1/4 HP plunge router. I thought hard about going with a more powerful motor, but I decided that my needs at the present time just didn’t justify it. If I decide I need something bigger later on, I figured the 2 1/4 would still be a dandy machine to have around for handheld work.
The main factors in choosing this particular model were the excellent reviews it has received (top rated in its class by Fine Woodworking magazine), and the convenience of above-the table bit changes. I purchased it through Amazon for $199, which included free shipping. It came with an edge-guide/circle cutting attachment (haven’t figured that out yet), and complete set of guide bushings, in a heavy-duty plastic case.
I unpacked everything this morning, and saw right away that it was not going to mount on my little old Ryobi table without some modifications. I had to drill a new set of holes in the table, and go to the hardware store for some slightly longer 1/4-20 machine screws than the ones that come with the router. I also had to drill a hole for the winder attachment to raise and lower the router. None of this proved to be any big deal, and I was up and running pretty quickly.
I immediately proceeded to fall in love with this router! Everything works exactly as advertised. It runs very smoothly at all speeds, and is quieter than my little PC690. But the thing that really makes my heart flutter is how easy it is to crank this sucker up and change the bit above the table, with one wrench, in seconds. The winder also moves the router in small enough increments to allow very accurate height adjustments. The only slight downside is a safety feature that requires you to reach under the table and flip the power switch off in order to be able to crank the router up all the way. This is really not a big issue at all, becausae the switch is large and easy to locate by touch.
I have wanted a router lift for a long time, but was put off by the cost. This router allows me to cross that lift off my wish list and start thinking about what other tools I can buy with those dollars. I’m totally impressed with the ease of operation, and the quality of construction on this tool.
7675 posts in 1117 days
23 comments so far
View mrtrim's profile
mrtrim
1698 posts in 779 days
posted 658 days ago
ok charlie , does the wife know you have this ??? lol nice review , glad your happy with it . im hearing so much about this unit i may have to get one
3055 posts in 920 days
posted 658 days ago
See Charlie, I told ya so. Great product!
Enjoy the heck out of it!
posted 658 days ago
There is much to be said for dual incomes and seperate checkbooks!
View MinnesotaMick's profile
MinnesotaMick
15 posts in 658 days
posted 658 days ago
Now to replace the ity-bity table….
20784 posts in 721 days
posted 658 days ago
I agree with MinnesotaMick with this router now you can justify building a table.
This is a nice router. I am sure you will be happy with its performance. Now that you have a bigger router how’s the budget for more router bits?
View GaryK's profile
GaryK
9549 posts in 887 days
posted 658 days ago
Nice review Charlie.
View cajunpen's profile
cajunpen
5968 posts in 965 days
posted 658 days ago
Nice Charlie – I like that router. Good review.
Douglas Bordner
3427 posts in 963 days
posted 658 days ago
Good to hear that the pundits got it right about this tool. I will be getting one in the near future. Enjoy, Charlie!
View rikkor's profile
rikkor
11335 posts in 773 days
posted 657 days ago
I was thinking about that Porter Cable 3 1/4 HP router, but maybe I won’t have to go that big. Thanks for the review.
posted 657 days ago
From what I’ve seen, rikkor, the Trton has the edge in convenience, but the big PC would probably be just the ticket if you were planning to do a lot of raised panels or similarly demanding work.
Dick, & Barb Cain
7045 posts in 1198 days
posted 657 days ago
You made a wise purchase Charlie, I bought the larger Triton, but I think I could have gotten by with the 2 1/4 HP.
You should check out about having to turn off the switch before raising for bit change.
On mine, the switch automatically locks for safety, when you raise it for bit changing.
You’d think they’d have the same feature on yours.
When you compare Triton with the other brands, I think Triton is a Rolls Royce.
posted 657 days ago
After reading your comment, Dick, I went back and double-checked. I guess the two ARE a little different, because mine definitely does have to be switched off becore it can be cranked up fully. Then, once it is all the way up, the switch is locked out until you lower the bit some. I reread the instructions, and that is how it is supposed to work.
Dick, & Barb Cain
posted 656 days ago
Sorry, but you were right all along Charlie.
Mine is the same as yours.
I spoke to soon, because now I remember the first time I tried changing bits,
the shaft wouldn’t lock up until I turned the switch to off.
I have an auxiliary switch too.
View toyguy's profile
toyguy
725 posts in 736 days
posted 652 days ago
Nice review, and I couldn’t agree with you more. I also have bought the 2 1/4 hp Triton recently. I didn’t have a table to put it in but I am just about done one now. In fact, I just made a couple of trial cuts with it. Now just to finish off the storage cabinets. The above table bit adjustment and changing is what sold me as well. I just can’t believe how simple it is to use. I think this is a winner for sure.
View Jim Brown's profile
Jim Brown
14 posts in 667 days
posted 652 days ago
The switch/collet lock means you have to reach under the table when you change bits, which disappointed me a little, but it’s a safety feature and I won’t argue with that. This router lives in my table and I couldn’t be happier with it.
View abie's profile
abie
112 posts in 670 days
posted 650 days ago
the triton router is a beauty but it’s changing mechanism is hard to understand changing can be a challenge when used in a community workshop. it locks up when the router is lifted too far and will not unlock unless you crank it down a small amount. then and only then will it release. many in our shop for that reason refuse to use it.
-- Bruce
posted 650 days ago
I know what you mean, abie, but that is just the way a single-wrench self-releasing collet works. It would have been confusing if I had not read a review prior to purchasing mine where the reviewer explained it. Knowing what to expect, I found it to not be a problem at all….just the opposite because you only need one wrench.
View Ad Marketing Guy - Bill's profile
314 posts in 697 days
posted 648 days ago
I purchased this router and could not be happier. Dollar for Dollar it is the best router in its class. Variable speed to handle the larger bits with slow speeds and soft start feature——anyone considering a new under table router should look into the Triton.
-- Bill - - Ad-Marketing Guy, Ramsey NJ
View Bruce's profile
Bruce
91 posts in 674 days
posted 641 days ago
I WANT ONE!@ ,.... where do ya buy em?
posted 641 days ago
Bruce, as I said above, I got mine on Amazon,com for $199 and fee shipping. Thgat was the best price I found anywhere.
View RTKVILLE's profile
RTKVILLE
3 posts in 773 days
posted 639 days ago
Whoa, Good article! I was about to post a request for suggestions on a 3+ HP router for my table but after reading your review along with these comments I think I’ve made up my mind or at least 98%. That the 2 ¼ HP Triton sounds like it will do what I want without having to spend the big money.
Thank you,
Richard
-- Life is too short... Enjoy Each Day!
View CedarFreakCarl's profile
CedarFreakCarl
566 posts in 952 days
posted 618 days ago
Great review Charlie!
-- Carl Rast, Pelion, SC
View Mark Shymanski's profile
Mark Shymanski
1555 posts in 611 days
posted 602 days ago
I bought my Triton a couple of months ago (Sears on their web page $199 Canadian no delivery charge). I also am very impressed with this tool. I had been shopping around for quite a while for a quality tool in my price range. I couldn’t quite scratch up enough for the PC or Frued (which came in second in the FW review, where I first heard/read about the Triton routers. Now that it is warm enough here in sunny Brandon to go out to the garage and start working with it I am very pleased with the soft start and the variable speeds. It is also much quieter that my old B+D fossil (which is too good to throw out but now seems so much crankier to work with). Good review.
