Rockler Mortise Machine Table And Fence
Review by TheDane posted 12-23-2009 07:33 PM 7060 views 0 times favorited 2 comments Add to Favorites Watch
Rockler Mortise Machine Table And Fence No-picture-s No-picture-s Click the pictures to enlarge them
This table/fence solved a lot of problems, and really improved the performance of my Jet JBM-5 Mortising Machine. It provides a much larger work surface than the stock table, and comes with 2 of Rockler’s Rotary Guides that help secure the workpiece against the fence, but allow movements to the right or left so you can slide the workpiece as needed.
I made one small modification when I installed the fence.
I have never trusted wood screws in MDF for this type of fixture, so instead of using wood screws to attach the MDF fence to the machine’s cast iron fence, I used Teenuts (Rockler Item # 26054) and 1/4” #20×1” pan-head screws to attach the fence.
To do this, I marked the location of the holes in the cast iron fence on the MDF, the drilled a 1/16” hole through the MDF to server as a pilot hole. I then used a Forstner bit to drill a recess about 1/16” deep into the melamine face of the MDF fence (deep enough so the shoulder of the Teenut was flush with the melamine surface).
I then drilled a 1/4” hole through the MDF and bolted the modified fence in place.
View TheDane's profile
TheDane
5515 posts in 3778 days
2 comments so far
Rick Dennington
6080 posts in 3309 days
#1 posted 12-23-2009 09:22 PM
Greetings Dane:
I bought the exact table and fence from Rockler a month or so ago. I put it on my Delta Mortiser, and like you said, it works great. Big improvement over the small 8”x 13” that came on the mortiser. Don’t know why I didn’t do it a long time ago. I was going to do a review on it, but never got to it. Got too busy doing other projects, instead…..... lol. Thanks fore the review.
-- " It's a rat race out there, and the rats are winning....!!"
View richgreer's profile
richgreer
4541 posts in 3190 days
#2 posted 12-26-2009 04:24 PM
I also have the JBM-5 and I have known almost from the day I bought it that I had to do something about the fence, table and hold downs. I did not know about this Rockler option. Thank you.
I chose the Jet because it runs at a slower rpm than most other bench top units. With some real improvement in the table and fence this could become a pretty good machine.
