| Review by Rick | posted 1247 days ago | 1612 views | 0 times favorited | 9 comments | ![]() |
- Incra Precision T-Rule - 6''
- Brand: Incra | Category: Measuring Tools
This is used nearly every time my pencil is used. It’s just great. Perfect layouts are so much easier in every way now. I don’t really have much else to say. The picture is pretty self explanitory.
Oh, I use the 6 inch because I usually make smaller things. Even if you make large projects most of the layout is at the end of the board for joinery and what not so the 6 inch should be fine for that too.
Get one. I can’t imagine you’ll wish you hadn’t.
9 comments so far
ErikB
home | projects | blog
14 posts in 1416 days
#1 posted 1247 days ago
I have the 12” model. It’s my go-to measuring device in my shop.
Douglas Bordner
3907 posts in 2233 days
#2 posted 1247 days ago
Been using the 12 incher for years, so long in fact that I could read the 64ths easily when I bought it. Not so much these days without bifocals.
I still use a 12˝ Starett combo often; as the Incra is floppy, but between the two things are covered pretty well.
Tim
1292 posts in 1735 days
#3 posted 1247 days ago
Have it, wouldn’t be without one, use it all the time.
87201 posts in 1747 days
#4 posted 1247 days ago
A super measuring device
Dusty56
10515 posts in 1858 days
#5 posted 1247 days ago
These are great rules….the 3” is also very handy : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
jack1
1806 posts in 2197 days
#6 posted 1247 days ago
I’m convinced. I’ve been putting off buying these but I will.
BobD
49 posts in 1583 days
#7 posted 1247 days ago
Great layout tool but must use a 5mm pencil.
-- Bob, San Diego
sparks
32 posts in 1259 days
#8 posted 1247 days ago
Where’s the best place to order one?
-- Sparks
Greg The Cajun Box Sculptor
3777 posts in 1478 days
#9 posted 1247 days ago
The are excellent. You can’t go wrong with anything made by Incra. Their tools are as much addictive as they are accurate. I bought numerous Incra products from www.incrementaltools.com and from www.woodpeck.com
I just received my Incra Incra LS positioner super system and Incra router table today and will spend time setting it up in the next couple of days. Their products are not cheap…but top quality never is cheap but I figure I will not have to replace these products.
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
