Wow, what a great tool!
Review by copythat posted 02-25-2018 06:25 AM 1481 views 0 times favorited 14 comments Add to Favorites Watch
Wow, what a great tool! No-picture-s No-picture-s Click the pictures to enlarge them
I bought the Supermax 19-38 drum sander with optional casters and folding infeed/outfeed tables during Black Friday. It was delivered on a pallet in multiple boxes and looked to be well packaged. When I opened everything up, there was no damage at all. That is always a plus!
I set the machine up as per the instructions and found the process to be painless but slow. Also, it is heavy and I’m not in the shape I use to be so it was a bear to lift it onto the stand. I used the sander for the first time on some drawers I made. I was hesitant to use it because the drawers were assembled with dovetail joints and they were not made out of the strongest material. I ran them through with very light passes and they came out exceptionally well.
I always wanted a drum sander and I’m very happy that I purchased the Supermax.
-- Rob
View copythat's profile
copythat
128 posts in 628 days
14 comments so far
View Bumpy's profile
Bumpy
40 posts in 503 days
#1 posted 02-25-2018 12:52 PM
I am happy to hear you are pleased with yours.
I bought the same machine almost 6 months ago and I have been less than pleased. It is a nightmare to keep it sanding consistent. Customer service is terrible, they will not return calls, the lady that answers the phone knows jsut enough to create more problems. When I finally did get to talk with the “manager” his ultimate response way “well I guess you may have received a lemon” Not what I expected for $1500.00
View wrenchhead's profile
wrenchhead
182 posts in 3186 days
#2 posted 02-25-2018 02:13 PM
Thanks for the review. This is my next purchase. Been saving for a while now and when i finally get the money, my local store has been out of them for the last few weeks. Good to hear that it is packaged well. Maybe its time to just order it on line and have it delivered.
-- https://www.youtube.com/channel/UCkRuFxW8HhRfyhbTP4SY5UA I could quit if I wanted
copythat
#3 posted 02-25-2018 04:23 PM
- Bumpy
Wow, sorry to hear that. My greatest fear when ordering a machine over the Internet is getting a Friday machine. You know, the machine employees throw together in a hurry on Friday afternoon so they can start their weekend early. Will Supermax send you a replacement machine since the manager identified it as a lemon?
-- Rob
View ScottKaye's profile
ScottKaye
648 posts in 1975 days
#4 posted 02-25-2018 08:34 PM
Ive had my 19/38 for the the better part of 4+ years now and couldn’t be more pleased with the machine. The only flaw I’ve experienced with the sander is with the stand. I have the stock open stand. I’ve had both tangs (for lack of a better word) where the casters are mounted to the stand, bend up (on the heavy cast iron and motor side of the machine) The bend was so severe that it caused tracking issues as you rolled the unit across the floor. You basically had to muscle it around. I called SuperMax customer service and all they told me to do was to bend the tabs back. Well duh! Guess what happened within a month? I ended up taking the sander off the stand and taking the stand to my buddies shop where he welded a brace across the tang and leg to keep it from bending again. To be fair, I do roll the machine out of the garage on nice days and use it outside and there is a small lip that probably caused the machine to create extra undo force on the tangs.
One piece of advice get yourself some 1-2-3 blocks They will help you align your roller bed to your sanding drum should the need ever arise. Like an idiot I messed with mine and changed an in spec machine to an out of spec machine and struggled trying to get it back to spec. those 1-2-3 blocks were just the ticket! Plus you will find all sorts of uses for them.
enjoy the machine!
Scott
-- "Nothing happens until you build it"
117114 posts in 3599 days
#5 posted 02-25-2018 08:43 PM
I’ve had a 25-50 for close to a year , no problems yet.
View richimage's profile
richimage
42 posts in 1752 days
#6 posted 02-26-2018 02:36 PM
I have used my 19-38 for over a year (as a hobbyist) without any issues, other than my difficulties figuring out the back clamp for the sandpaper rolls… I have been happily amazed by it’s ability to sand very thin material, then (with a LOT of handle twirling) breakout-free edges on the same material, as long as it’s bundled together with a clamp or hot glue. The lever for the instant two-pass adjustment is genius!
Rich
-- "Women are like modern paintings. You can't enjoy them if you try to understand them." Farrokh Bulsara (Freddie Mercury)
View Woodmaster1's profile
Woodmaster1
980 posts in 2609 days
#7 posted 02-27-2018 06:56 AM
I use the 19-38 at my woodworking clubs shop they have two that are used daily. The only maintenance done after five years of heavy use is a new clips for sandpaper, new platen belts, and one had a controller issue. I feel they are great considering the use they get. I like the supermax so well I bought the new 16-32 and so far it has been great as well.
View moke's profile
moke
1179 posts in 2798 days
#8 posted 02-27-2018 06:03 PM
Just the guys above, I have one too. It is 4 or 5 years old. I couldn’t be happier. And Scott…..thanks for the 1-2-3 block tip…I got some about 6 months ago and I keep finding uses for them….and now another! Thanks! Someone on here set me to using it to surface drawers too…it works awesome. Also the old sandpaper is great to cut up and use on the lathe…..even on my metal lathe, I flip it over and use a little oil to polish.
-- Mike
View playingwithmywood's profile
playingwithmywood
418 posts in 1619 days
#9 posted 02-28-2018 02:47 AM
- Bumpy
maybe it would be more helpful if you explained what is happening with yours…. its a drum sander not sure how it could be a lemon
View kathy50's profile
kathy50
15 posts in 106 days
#10 posted 03-06-2018 03:31 AM
A couple things about this sander:
1) It is 110V only (cannot rewire motor for 220V)
2) To fully expunge all dust you need at least 1200CFM dust collector (tried a small portable collector that was 800CFM it would not cut it)
3) This unit is not made in the USA
-- https://drillly.com
playingwithmywood
#11 posted 03-06-2018 05:35 AM
- kathy50
1) 110 is fine for it if you are in the Merica were 110 is the standard you are taking off little bits of material 110 is fine
2) seriously dust collection is no fault of the sander and by the time someone normally would buy a sander like this they would normally have lots of other bigger tools along with the dust collector
3) not made in the USA what is made in the USA if it was made in the USA your price point would be 3x what you paid …. again what is your issue
I am sorry but I hate stupid reviews for things that live on the internet for eternity. My drum sander is great it is the old model but I will trade my old for for the new one
View Dedvw's profile
Dedvw
174 posts in 2903 days
#12 posted 03-07-2018 01:35 AM
I’m on the fence about mine. Sanding is inconsistent, I either sand too much material and the material bogs the machine or I sand too little and the belt slips. It’s VERY touchy for me. I’ve gone as light as 1/20 cranks on the control. If you miss either way it groves the wood and creates a lot additional sanding, with pushing the wood through manually with my hands.
Also, I have broken 4 rolls of sandpaper lately (some only running for only 60 seconds or so). I don’t know if its a recent manufacturing batch, but at $12 a roll, something is weird. I’ve used this machine for 3 plus years and never had it break sandpaper until recently.
At this point, Id give the 19-38 3.5 stars.
playingwithmywood
#13 posted 03-07-2018 06:12 AM
- Dedvw
Try KLINGSPOR has been manufacturing abrasive technologies since 1893 https://klingspor.com/
they also have woodworking stores
http://www.woodworkingshop.com/abrasive-rolls/
Dedvw
#14 posted 03-07-2018 08:24 PM
- Dedvw
- playingwithmywood
I will give them a shot! Thank you.
