solid joiner for the price
Review by KDL posted 664 days ago 1343 views 0 times favorited 11 comments Add to Favorites Watch
solid joiner for the price No-picture-s No-picture-s Click the pictures to enlarge them
I bought this joiner two years ago after talking to a few woodworkers/salesmen I trust. I have used it on two large cabinets, a small table, and a small sideboard. On the whole, I think it’s a good machine for a very fair price. There are higher-end joiners that are, I’m sure, really slick. But for the money, this is a good tool, and when I bought it, it was definitely the best in its class.
It comes with: The joiner, dust bag, wrenches, regular and face-frame blades, manual, and a carrying case.
The blades: They do the job. The cut is quick and accurate. You’ll get a much better cut if you hold the tool steady. If you wobble, you’ll make a wider slot, which defeats the purpose.
The grips: The handle placement is excellent. As I understand it, many joiners are based on grinders, which have different handles. Happily Porter-Cable went to the trouble of putting a nice handle on the fixed head and a grip on the plunging base. Some other brands have both handles on the plunging part. Control is good.
Dust collection: The tool is small, so it’s easiest to use without a dust bag or vacuum. However, joiners make a lot of chips, and without a bag or vac, you’ll make an airborne mess. The bag works, but it’s small, so it will fill fast.
Which bring us to vacuums: My 1.25” Shop Vac hose is too big for the joiner’s dust port. My regular home vaccum fits TIGHTLY over the dust port—the only problem is that it’s awkward to have such a stiff hose attached to a small tool. What does work really well, is my Bosch sander vacuum hose. The hose is narrow and flexible, however, it doesn’t quite fit the jointer. So I cut a 1” long piece of 1” copper tubing and slid that over the joiner’s dust port, then my Bosch hose slips over that.
Noise: It’s loud; wear your ear protection.
Guides: The fence comes with a face frame accessory and has lots of adjustments over a wide range of depths and angles. Along with the handles, this was a major selling point for me. In addition to the fence, the joiner’s body has a height adjustment and another for different size biscuits. Everything works great. My only complaint is that I can’t use the small face-frame blade with the fence in the vertical position—the joiner’s body hits the fence. So no plunging into the middle of a wide board with the little blade, the cuts have to be near an edge. I guess that’s fair, it’s a face-frame blade, but I was trying to get creative. If I could change one thing, that would be it.
The case: The case is very rigid, but the joiner has to be folded just right to get everything back inside. That’s good for travel, but really annoying for day-to-day use. I leave the joiner out until I’m done for the day.
The manual: It is illustrated and easy to follow. It has directions for several different biscuit joints, as well as information on the tool itself. As with most manuals, it’s not perfect, but I’ve switched blades with no problem.
View KDL's profile
KDL
31 posts in 667 days
11 comments so far
View GaryK's profile
GaryK
9555 posts in 888 days
posted 664 days ago
I got a model 556 when they first came out, and I use it for one thing only now. Miters.
That’s because of the fence that came with it. It rests perfectly on the board for perfect
placement.
I have seen that one, but haven’t felt the urge yet.
View lynxsg's profile
lynxsg
8 posts in 679 days
posted 657 days ago
I’m trying to decide between the Dewalt and the PC 557. I’d be interested in your experience with either of these joiners.
-- Steve G., Kelowna, BC, Canada
View KDL's profile
KDL
posted 657 days ago
Steve G, to answer your question:
As I said in the review, I quite like the PC 557. I’ve never used the Dewalt and it’s been a while since I held one, so I don’t know exactly how the current ones look and feel. I did look at a picture of the Dewalt on Amazon, and I can’t tell how the handles are arranged. One of the things I like about the PC is that there’s a fixed handle on the head, and a grip on the plunging base. I think this helps me control the tool better than if both handles are on the plunging base. The fences look similar, which was another PC selling point at the time I bought mine. My guess is they are about the same quality.
View capsfan's profile
capsfan
12 posts in 645 days
posted 645 days ago
I’ve been using the 557 professionally for 3 yrs and it has not let me down yet. I have used the Dewalt plate joiner many times as it is the one supplied by my employer. The 557 has many more features and the fencse stays square to the blade.
The Dewalt model has plastic fence adjustment shaft that twists along it’s length and causes the fence go out of square. It is only a small amount but that small amount gets multiplied when you try to put two pieces together.
-- We can't all be heroes, somebody has to sit on the curb and clap as they go by. (Will Rogers 1879-1935)
25871 posts in 1300 days
posted 645 days ago
Thanks for the review. I’ve got the Dewalt and a Ryobi plate jointer. I use the Dewalt more because it’s to the front of the shop. The Roybi is at the back and burried.
View Sheepman's profile
Sheepman
25 posts in 401 days
posted 401 days ago
I have the 557 Type 2 and would not give any thought to even looking at another brand(maybe Festool if I hit megabucks)
-- Carpenters make some of the finest firewood there is !
View CessnaPilotBarry's profile
CessnaPilotBarry
1292 posts in 602 days
posted 401 days ago
This review points out why paper towel tubes and duct tape are important to have hand in the workshop.
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
View rwyoung's profile
rwyoung
167 posts in 372 days
posted 369 days ago
You can remove the angled fence entirely when using the 2” blade but it is a hassle.
So far I’ve been using mine on a few small projects and it has performed very well.
The chip extraction is a bit hokey unless you use a vacuum. The port seems to clog quite easily. This could in part be due to the wood type as I’ve noticed it more when practicing on pine and poplar and less so on some oak.
I wish I had bought this one first instead of trying out a $50 job and discovering that while it did work, the base on the cheap model would flex as I plunged the joiner. With the PC557 the base is very rigid (as is the whole unit) and so far the only problems I’ve had have been of my own making!
-- Don't sweat the petty things and don't pet the sweaty things.
View RalphB's profile
RalphB
25 posts in 265 days
posted 232 days ago
Reviews on Amazon have complained about a plastic part – I think it was the pivot – on the fence that did not last long in use. Anyone know if this is still a problem, or has P-C seen the light and gone back to metal??
View KDL's profile
KDL
posted 228 days ago
<reviews>
There is a plastic piece that guides the fence, and if it broke, it would be a problem. However, I have had no problems in a couple years of very light use. I haven’t seen the newer models.
View glassyeyes's profile
glassyeyes
31 posts in 229 days
posted 228 days ago
I’ve got an older Porter-Cable model 555. I haven’t used one of the newer ones (OR any other brands), but the 555 is really sturdy and has been very useful. It’s got both the fixed and adjustable fences.
-- Now, where did I put those bandaids?
